Alan de Enfield Posted December 30, 2019 Report Share Posted December 30, 2019 46 minutes ago, markeymark said: saves 3amps/hr as well. That's handy - useful units. Link to comment Share on other sites More sharing options...
WotEver Posted December 30, 2019 Report Share Posted December 30, 2019 2 hours ago, cuthound said: Result 103dBA with one running and 106dBA with both running. Indeed. As I wrote... On 29/12/2019 at 11:53, WotEver said: Decibel measurement is a complex subject, often mis-quoted, and differs whether referring to subjective loudness, SPL, or power. 1 hour ago, markeymark said: saves 3amps/hr as well. I wonder how many volts it saves... 1 Link to comment Share on other sites More sharing options...
MtB Posted December 30, 2019 Report Share Posted December 30, 2019 2 hours ago, markeymark said: and saves 3amps/hr as well. How many Amps does it save in two hours? Six? Link to comment Share on other sites More sharing options...
IanD Posted December 30, 2019 Report Share Posted December 30, 2019 2 hours ago, cuthound said: I once fitted two 1000kVA generators into a basement power room. They were two metres apart. I measured the sound pressure level one meter from each generator with a calibrated meter. Result 103dBA with one running and 106dBA with both running. However with ear defenders on, the noise level I perceived didn't sound much louder than with one running. I suspect that if I had installed a third generator the SPL would have been 109dBA with three running. Speaking as someone who (among other things) runs PA systems with music and instruments that some would class as noise, a 3dB difference in level is certainly noticeable but not enough to turn an acceptable noise level into an unacceptable one. 6dB will probably make this change in perception, 10dB certainly will. Bear in mind that A weighting (usually used for specifying noise levels) is intended to roughly compensate for the response of the ear to different frequencies so that different sources have the same "apparent volume" if they have the same dBA level. However annoyance and volume aren't the same thing, A weighting rolls off low frequency noise (which the ear is less sensitive to) like exhaust drone but these are the most likely to penetrate inside adjacent boats -- this is the same problem as thumping bass as a noise nusiance in houses. The quietest marine generators are in the 52dBA-55dBA region (measured at 7m) -- a 65dBA generator is in no way "quiet" no matter what the blurb says... Link to comment Share on other sites More sharing options...
cuthound Posted December 30, 2019 Report Share Posted December 30, 2019 9 minutes ago, IanD said: Speaking as someone who (among other things) runs PA systems with music and instruments that some would class as noise, a 3dB difference in level is certainly noticeable but not enough to turn an acceptable noise level into an unacceptable one. 6dB will probably make this change in perception, 10dB certainly will. Bear in mind that A weighting (usually used for specifying noise levels) is intended to roughly compensate for the response of the ear to different frequencies so that different sources have the same "apparent volume" if they have the same dBA level. However annoyance and volume aren't the same thing, A weighting rolls off low frequency noise (which the ear is less sensitive to) like exhaust drone but these are the most likely to penetrate inside adjacent boats -- this is the same problem as thumping bass as a noise nusiance in houses. The quietest marine generators are in the 52dBA-55dBA region (measured at 7m) -- a 65dBA generator is in no way "quiet" no matter what the blurb says... Indeed, a common specification for a standby generator in an urban environment would be 65dBA at one metre from noise breakout points (exhaust outlets and air inlet and oulet louvres) and 50dbA at the site perimetes, measured at 03:00 to minimise background noise. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 30, 2019 Report Share Posted December 30, 2019 26 minutes ago, IanD said: The quietest marine generators are in the 52dBA-55dBA region (measured at 7m) My little Honda EX650 is apparently 54Db Link to comment Share on other sites More sharing options...
WotEver Posted December 30, 2019 Report Share Posted December 30, 2019 20 minutes ago, Alan de Enfield said: My little Honda EX650 is apparently 54Db Is that 54dBA? At what distance? Both of those questions make the figure relevant. Without those answers you could just as easily say it’s 1dB; just move further away. Link to comment Share on other sites More sharing options...
WotEver Posted December 30, 2019 Report Share Posted December 30, 2019 (edited) Just to make life more interesting, the EU now mandate manufacturers and sellers of any noise-creating equipment to use LWA (sound power) instead of dBA (sound pressure) to determine how noisy the equipment is. They’ve even produced a handy 78 page document all about it... https://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:2000:162:0001:0078:EN:PDF Edited December 30, 2019 by WotEver Fixed the subscript Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 30, 2019 Report Share Posted December 30, 2019 (edited) 13 minutes ago, WotEver said: Is that 54dBA? At what distance? Both of those questions make the figure relevant. Without those answers you could just as easily say it’s 1dB; just move further away. I do realise that but its an '80s Genny and I cannot find the full specs for it. Its really, really quiet, I've been stood next to it and not realised its running. Edit - Found it : Manual states : 52 dB (A) at 7m. Edited December 30, 2019 by Alan de Enfield Link to comment Share on other sites More sharing options...
WotEver Posted December 30, 2019 Report Share Posted December 30, 2019 3 minutes ago, Alan de Enfield said: Manual states : 52 dB (A) at 7m. That’s pretty quiet Just to keep you up to date with the EU’s current rulings, that means it’s LWA77. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 30, 2019 Report Share Posted December 30, 2019 6 minutes ago, WotEver said: That’s pretty quiet Just to keep you up to date with the EU’s current rulings, that means it’s LWA77. My Kipor 2000i is 61dB (A) no load at 7m and 73 dB (A) at full load at 7m and at no load that is relatively quiet. Link to comment Share on other sites More sharing options...
WotEver Posted December 30, 2019 Report Share Posted December 30, 2019 2 minutes ago, Alan de Enfield said: My Kipor 2000i is 61dB (A) no load at 7m and 73 dB (A) at full load at 7m and at no load that is relatively quiet. That’s LWA 86 and 98 respectively... Link to comment Share on other sites More sharing options...
CompairHolman Posted December 30, 2019 Report Share Posted December 30, 2019 What is a constantly barking Alsatian LWA level ? Because there's one on the visitor mooring opposite us and we can't wait until they piss off. 2 Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 30, 2019 Report Share Posted December 30, 2019 15 minutes ago, CompairHolman said: What is a constantly barking Alsatian LWA level ? Because there's one on the visitor mooring opposite us and we can't wait until they piss off. Its now after 8pm so they should be turning it off now. Link to comment Share on other sites More sharing options...
CompairHolman Posted December 30, 2019 Report Share Posted December 30, 2019 7 minutes ago, Alan de Enfield said: Its now after 8pm so they should be turning it off now. They just started their engine about 10 mins ago so they don't give a toss. Link to comment Share on other sites More sharing options...
MtB Posted December 30, 2019 Report Share Posted December 30, 2019 35 minutes ago, CompairHolman said: They just started their engine about 10 mins ago so they don't give a toss. I reckon they must have been reading that thread about it. Y'know, the one where you maintained CRT were acting ultra vires putting the genny curfew into the T&Cs.... Link to comment Share on other sites More sharing options...
CompairHolman Posted December 30, 2019 Report Share Posted December 30, 2019 26 minutes ago, Mike the Boilerman said: I reckon they must have been reading that thread about it. Y'know, the one where you maintained CRT were acting ultra vires putting the genny curfew into the T&Cs.... Stupid comment. Link to comment Share on other sites More sharing options...
MtB Posted December 30, 2019 Report Share Posted December 30, 2019 Just now, CompairHolman said: Stupid comment. Accurate though! Link to comment Share on other sites More sharing options...
CompairHolman Posted December 30, 2019 Report Share Posted December 30, 2019 1 minute ago, Mike the Boilerman said: Accurate though! No not at all, you have just totally misunderstood what I said in that thread. Link to comment Share on other sites More sharing options...
