Sign in to follow this
Boater Sam
Fly tipping vandals again or God?
Latest from CRT.
Notice Alert
Dee Branch (Shropshire Union)
Starts At: Lock No 1, Graving Lock, Dee Branch
Ends At: Lock No 1, Graving Lock, Dee Branch
Monday 23 September 2019 06:00 until further notice
Type: Navigation Closure
Reason: Structure failure
Original message:
Please be advised that the towpath and lock are closed at Lock 1 on the Dee Branch of the Shropshire Union canal due to a large hole appearing overnight in the towpath adjacent to the lock.
Our teams and engineers will be onsite today to investigate large hole which has resulted in the damage to the towpath.
Navigation will not be possible at this moment. We politely request customers to approach the area with caution and to listen to any advice that may be given onsite.
An update will be provided tomorrow (Tuesday) afternoon following an inspection from our engineers
Vandals again, now they are fly tipping holes overnight, where will it end?
Share this post
1 minute ago, Graham Davis said:
What on earth has flying tipping got to do with it?
I think the idea is the hole got there because somebody dumped it there.
Share this post
58 minutes ago, Graham Davis said:
Perhaps some have escaped from the Polo factory.
Or Blackburn, they wouldn't miss the odd one or two. ?
Share this post
Holy M'holey!
They are delivered in the emergency water hoppers CRT use, when they are empty of course. Someone tipped it out onto the towpath by mistake.
You can't put a hole in a water hopper, it would let the water out. Could you plug it with a hole though?  Too much sun......................................
Share this post
that's a whole new way of looking at holy matters - may I be the first to commend you on your grasp of the matter.  I hope you don't find that too patronising or condescending.  But of course you can plug one hole with another hole, providing you make sure it has a tight fit.
Share this post
That is accepted but it relies on the structure of the hole. Is it a square hole or a round hole? A black hole of a white hole, Does it matter or antimatter?
When we are on a narrow canal the maximum dimension of a portable hole is of course 7',
Are there wide beam holes available?
Share this post
shape is often poorly defined because holes constantly evolve even while they are not revolving.
a rapidly revolving hole is called a black hole, because of their momentum they tend to be round.
an unlit hole is called a dark hole, but if it is dark you probably can't see its shape, so in the interests of extreme caution you should always treat one as a potentially black hole and avoid at all costs (unless it is less than half a crown).
the only other difference is the rate of revolution.
at night, after a few pints, dark holes revolve quite slowly but are still best avoided.
PS: if you find a truly rectangular hole it is called a doorway.
Share this post
I'll check the drawing i have at home that defines the sizes for British standard holes, and if it isn't to standard they should fill it in and start again.
(starts whistling Bernard Cribbins 'Hole in the Ground')
Share this post
Not on the hole, no.
Share this post
