Everything posted by davidg
shot/quill blasting - is DIY possible?
davidg replied to magnetman's topic in Boat Building & Maintenance
That was the Quill system which is what Rex has just used on his barge as I said. Uses ground glass and is very effective by all accounts -
Short answer: Yes. Talk to Rex Wain at Brinklow Boat Services. He's just done his barge with kit hired from a company at Melbourne (?) near Derby. -
I retrieved my windlass off the boat today & measured it. The thin end of the taper is 13/16" and the fat end a slightly over 1". Like Anthony's I think it is a T&M size and would only go less than half way on the offending spindles; I bought it off the BCN society stall at what I think was their first Windmill End rally in 1984, it has been used on a great many paddles since then. If the paddles at Buckby conformed to the drawing it should go all the way on with a bit of spindle protruding. Talking to Christine at Rose this morning the ones at Buckby aren't the worst, the bottom lock at Braunston has some too but they were about the only paddles my windlass didn't touch between Cassio Bridge & Braunston. And Alan is correct about the plates and the bolts welded to the pawls on the gate paddles.
Interesting find Alan, they don't quote tolerances on the measurements but if my eyes can see the difference on two spindles three feet apart the tolerance must either be huge or they are not both in spec. Your memory of the Ham Baker paddle gear is correct, they are now the only remaining examples of what was the GU standard paddle spindle size, a large taper. The decision to alter the GU paddles south of Braunston was lamentable.
I've just sent an email to C&RT southeast so we'll see what response I get. I didn't have a tape or a Vernier caliper with me (nor the time to use one) but a visual comparison between the ground paddle spindle and the adjacent gate paddle spindles shows up a quite noticeable difference. You certainly don't need high tech measuring equipment to see it, the mk.1 eyeball is quite enough. Does anyone know what the spec on the standard paddle spindle is?
I've just brought a boat up the Grand Union from Watford. At Buckby there was a stoppage before Christmas involving new gates and it appears new ground paddle spindles. My windlass which fits happily on every other spindle I tried it on is at best a very sketchy fit on the new spindles fitted to the ground paddles at locks 10/11/12. The spindles on the ground paddles are too large. Before I fire off an email has anyone else been through since the work and found this?
The area the dock sinks in was dredged just before Christmas which should put an end to the search for human ballast and other shenanigans to get boats on & off. Wasn't there today to see how it went, out boating which is the subject for another thread.
Photos of Narrow Boat Owners Club Gathering 1984
davidg replied to John Brightley's topic in History & Heritage
That's better. Where the ivy covered tree is and the depression tracking off to the right is the site of the former arm to a lime quarry about half a mile away. It used to go under the road which is the hedge line you can see upper right, below the school, and continue across the fields. There were the remains of a accommodation bridge up there but it's a while since I've been that way. All likely to disappear under a new housing development. -
It took me a while to work it out but the one in the middle, left hand column is the wrong way round I think. That was the Christmas some of the residents of Stockton went to Stoke, three pairs went. After a Christmas Eve in the Boat we turned Barrow & Cheam round in the middle of the night, to the great surprise of everyone else the following morning. I've got some photos but I think they're on the boat, I'll see if I can dig them out. -
Also difficult may be sourcing marine feet if you are mounting it on normal engine beds. They could be fabricated but they would never be as pretty as the cast ones. Parsons Mathway were acquired by a firm in Coventry, still giving support for the gearboxes.
I ran some tests on a Squirrel last year. Highest temperature measured on the flue was 132deg near the bottom; top of flue got to 94deg. Tiles by back corners got to 115deg but they were on insulating board plus air gap.
I've never had a problem with a GU motor boat at Bordesley; at Aston and the 13 (and other single bottom gate BCN locks - bottom lock at Smethwick is the worst) the problem isn't while descending the lock, it's opening the bottom gate past the stem post while simultaneously holding the stern end against the cill with 2 out of three fenders up and the rudder over while single handed. Hillmorton, however, isn't a problem.
Quite so. When I go through a narrow lock the tiller is on the cabin roof from about when the boat is halfway into the lock until it is halfway out again. To repeat, there is no need to hold the rudder over while passing through Hillmorton in a GU motor boat. Curses, someone snuck in, I should point out the "Quite so" there refers to the last line of Daniel's post.
No it doesn't, before that one is allowed to run any further
When I tried to buy a Flojet from Aquafax that too was unavailable which may tell a story. I can give you some background on the Jabsco availability if you pm me.
I'm pretty certain this is a genuine GUCCCo company issue dipstick, big Woolwich diesel tanks for the use of. As you can see in the second photo it is graduated in 5 & 10 gallon increments up to 80 by which time the diesel will have hit the triangles. There is also a notch in the sides at the top which is about the top of the tanks. I found it a long time ago lying in the engine 'ole bilge between the diesel tank and hull side; the need to dip the tanks prompted me to fish it out and give it a birthday by way of a wire brushing to clean it up. The mystery is in the third photo which shows it is stamped JJC S11 on the reverse. The combined might of the Brinklow Boat Services (woodwork dept.) tea room couldn't come up with a plausible explanation yesterday so the question is does anyone else have an explanation? Or does anyone else have one and is it also stamped on the reverse of the scale? Of course if there is a demand for these I'm sure the Brinklow Boat Services (steelwork dept.) could find a few old ones round the back of the stores....
Errrrr.....hang on a minute Alan. The deckboard, engine 'ole & cabin sides should be taller on a little boat which roughly compensates for that 7". If you want me to name a boat which got this point seriously wrong I'll tell you tomorrow.
Oooh. I can hear the spluttering from Dadford's wharf from here.
Or Llanfarian Kemp? (You'll struggle to find it, I did.)
Sounds a bit like the Adverc cycling, which is what it should do, but the on/off times should be more like 10minutes on/5minutes off (without looking it up). The voltage looks high too, again from memory I think the Adverc should cycle between 14V and 14.4V. The high voltage seen could depend on where it is being measured. The Adverc will try and produce 14.4V at the battery but if the measurement you see is taken near the alternator that voltage will be higher. The Adverc measures both and if the difference gets too high it should flash a warning. It means bad connection/wiring too thin somewhere down the line.
Atherstone - what is notable about this picture?!
davidg replied to archie57's topic in History & Heritage
The Super D just out of shot on the right? Nah, it's the gate paddles. -
Try Thorntons in Shrewsbury for bearings
I have some copper head gaskets if you are still looking
Pair stuck under a bridge nr Stockton, Grand Union
davidg replied to AMModels's topic in General Boating
Depends which bridge you mean Pete. The Fosse bridge isn't the same bridge as the WFCo bridge and I regularly took pairs through the Fosse road bridge in the eighties though the bushes growing out of the old bridge could get a bit interesting for the cabin on the offside. The bridge below WFCo however...we told the Friends of President, did they listen? Forget how long it took to get them out. -
Kharma, for the speed he came past the boat I was working on at Tomlow. I thought eny fule kno you couldn't get a pair breasted through that bridge.
