davidg
Patron
Everything posted by davidg
  1. Mea Culpa. When Ron Hough was signwriting that he asked me whether the second L should be capitalised. Reasoning that double L is treated as one letter I said yes. A native Welsh speaker pointed out the error later but by then it was too late. My knowledge of Welsh has improved since then😀
  2. If it hasn't been out since we built the boat (at WFBCo) thirty(?) years ago it will not give up without a fight. Expect to have to hammer all manner of long thin things - chisels, screwdrivers(!) - between the collar and the middle pipe to free it, or if you're lucky unbolt the collar and the collar lifts off with the middle pipe attached. Worst case is having to take an angle grinder with a cutting disk to cut the middle pipe in half. Messy and unpleasant. I think high temperature silicone wasn't invented back then, or we hadn't come across it.
  3. You should have used cock grease David. Alright, it's really called gas cock grease (Molykote 1102 Gas Cock Grease 50g Tube 10395) but where's the schoolboy snigger in that.🙂
  4. Having walked between 15E and Slaithwaite on Friday & yesterday the pound below 15E is 2ft off with not much feeding down, I think it was the short pound between 18 & 19 that was 4ft off, one of the longer pounds is a foot off and there's not a lot of water coming down the bywashes. I don't think there's any feed from Hill Top or Sparth reservoirs, it's a while since I walked over the Hill Top embankment and Tunnel End is silted up/dewatered.
  5. 'Tis on the book of face: (10) Facebook and I've seen Chris & Phil on Thursday so definitely for sale.
  6. Sure you've got the right Trevor there? Morley?
  7. Depends on how the stern tube is arranged but I’ve done this on a Grand Union boat. Remove rudder Make a piece of plywood drilled to take the stuffing box studs. Undo tail shaft coupling, remove any keys, pins etc. from shaft Tie a rope round the shaft inboard of the blade Grease one face of the plywood Push the shaft back with someone holding the rope but not all the way out When the inboard end of the tail shaft is clear of the inboard end of the stern tube remove the stuffing box packer Put the plywood on the studs greased face towards the stern tube and hold it on with the stuffing box nuts Pull the shaft the rest of the way out Very little water comes in To reassemble reverse the removal procedure. 😀 With a weed hatch getting the end of the shaft back in is easy, without a weed hatch less so.
  8. You're forgetting that back in the day coal was king. At peak steam coal (1913) Cardiff shipped 13 million tons. In 10t capacity wagons (the 16t mineral was a long way off) and a six day week (the Welsh would all be in chapel on a Sunday🙂) that's about 180 wagons an hour going through the Marquess of Bute's docks and making them rather a lot of money in the process. Likewise the Taff Vale Railway which moved a lot of it. Other ports and railways wanted a slice of this action and the coal owners wanted to break Cardiff's monopoly, the Vale of Neath line from Pontypool to Neath gave the GWR access to pits in the Taff & Cynon valleys and the docks at Newport at one end and in the Swansea area at the other end. For another example look at the Barry Railway and it's ruinously expensive line to link the port of Barry to the Rhymney valley on which stood Llanbradach viaduct, opened 1905, dead in the water twenty years later.
  9. Not trying to be picky but.... The agents/suppliers are Kuranda, not Karunda and the stove will be a Kabola.
  10. Didn't I look young, and haven't changed a bit (in my dreams). I'm surprised Nick's bike recovered from that trip, I seem to remember a lot of cleaning was involved before handing it back. Yes I think I know where they were taken but we'll leave it open for people to speculate.
  11. No probably about it Ray, that is Gort. Having worked on it I can testify to what a PITA* the gearwheel is. It does come off fairly easily as the nut securing it is usually only finger tight but that leaves the end of the shaft sticking out to catch yourself on; rock & a hard place... Getting through the door between the engine room and front cabin is a challenge too. Fortunately I haven't eaten too many pies but it would be amusing to watch someone who had try it.😃 Gort now has a new owner so hopefully the boat's future is secure. *Actually head, back & shoulders but you get the idea.
  12. That's what I did and similarly ran out of ideas🙂
  13. And there's something which reminds me of Graham Wigley in the steerer's profile.
  14. Well I know what they are* but I bet there's not many on here who do. *I do have the advantage of having grown up in Wellhouse.
  15. After a shrewd guess which turned out to be on the money I know where it is. Go north and keep going north until you run out of likely places.
  16. If it’s brass and t section, which it appears to be, then it looks like an original. I have a big Woolwich boat which would go with it rather nicely. My current one is flat steel which I found down the side of the diesel tanks many years ago (is it really 40?); at the time I believed was original but have since been told not. Send me a message if you would like to pass it on and it can stay with the boat should I pass it on to someone else.
  17. Any true devotee of the Premier Line knows that Joy is the only way to go. If only for the name.😁
  18. Was with Pete two hours ago but won't see him again until Monday. I could ask then.
  19. That's Ian steering! From behind it could be Chris Stubbings but I'm sure there are many other people who fit the bill.
  20. Well if you're feeling lucky on all three counts I'll see you in The Bell in Adderbury on August 16 2054. Unfortunately the ship has almost oops, already (just checked my bank statement) sailed on the 5 covering a pint of Hooky. Anyone prepared to speculate on whether the 10 would cover it in 2054?🙂
  21. But, but, but….. It’s all oak and will go black. It might take thirty years but five gets you ten it’s gone black by then. To add to the name confusion, how about “Admiralty skylight” which was on a plan we have used in the past. Size was more appropriate to a man of war so a certain amount of scaling was necessary. ps. Doubt I’ll be around to collect or pay out if anyone cares to take up the bet😀
  22. According to the date on this photo it was taken on July 10th 2001. The young chap sat on the slide is taller than me nowadays.
  23. Just the steelwork. Add to that fitting out and painting the cabin, an engine plus installation, shutts & running gear and all the rest of the titivation.
