billh
Everything posted by billh
How to orientate the split pin at the end of prop shaft.
billh replied to Gybe Ho's topic in Boat Building & Maintenance
I suggest that a split pin is not the best way of securing the nut. I have experienced the ends of the pin being broken off by constant battering by rubbish on the prop and the pin then falling out. Since then I have used a Stainless roll pin (sometimes called a spring pin), pressed into the castellations of the nut and ground off flush with the sides of the nut. , never a problem since but a bit more difficult to remove at prop servicing time. -
A37 has been at Castlefield for many years. Perhaps of more concern is the boat near the viaduct in the second picture? It's the L & L short boat "Irwell" sat on the bottom despite having been re-floated more than once. I don't know if the engine is still in it , a 3(or was it 4?)cylinder RN . Happy memory of a camping boat holiday on Irwell in 1972- Leeds to Manchester at a time when she was sometimes still involved in commercial carrying. Sad to see now.
Never mind a 4LK, this is the ultimate Land Rover power unit: Frank Rothwell also owns Oldham Athletic F. C. and rowed the Atlantic solo at the age of 70+.
Was Uncle Irvine on that trip also? I think he would have been Deputy Head at that time. If appropriate, move to history and heritage😃
Vertical lifting bridges - why or why not?
billh replied to magpie patrick's topic in History & Heritage
Rochdale Canal ,Grimshaw Lane, Chadderton. A modern hydraulic lift system. I can't remember what the old bridge was like, it's about 50 years since I crossed it. The modern system does not seem to be very reliable- fancy electrical control system and miles of hydraulic pipes and fittings ready to leak at a moments notice. -
That strapping post at the lock looks suspiciously like a steam loco funnel , made of cast iron too. Some of these are still in place with a slight deviation from vertical to suit the application.
Yes. As far as I know, it is a purely decorative feature. Reference to C&RT archive shows the same on the original Joel of 1927. (broken up ,1948). I would say it was a product of the artist in residence blacksmith at the Gorton Canal Depot . If we look around the photo shown above, we can see other features of Joel which might be considered not traditional: The Kelvin engine's gearchange wheel tucked in to the left of the hatch , so your head wasn't damaged going into the very low cabin, necessary because of low bridges on the local canals. Who else was fitting a Kelvin in a NB in 1927 or 1948? The round top dollies possibly unique design. The bits of old tyre instead of dead cat rope fenders- in my experience the tyres were far more practical and long lasting than expensive hand made rope things The rudder blade did not extend behind the counter- there's a story! The original Joel's steerer , maybe in 1930's cilled the boat and did some serious damage and so it was rebuilt with the small blade and a solid post from skeg to counter as we can just see here. Trouble was, it was awful at going round bends( I remember it well) and that feature was dispensed with in the 1980s. A more conventional blade fitted and any handling difficulties are now completely down to operator error, not the boat.😀 The cabin side writing "British Waterways" in a straight line instead of a curved arch shape. I think the gang at Gorton Depot were somewhat renegade with their interpretation of the rules sent down from London by the new nationalised canal authority. These staff were all members of a RAILWAY union having , up to nationalisation been employed by the Great Central Railway and LNER from 1923 and there was still much interaction between the canal depot and the vast railway workshops across Cornwall Street right up to closure in 1962. Bits and pieces of locomotives and carriages got re-purposed into boats, including Joel. This practice persisted into more recent times with the fitted air horn recycled from a scrapped BR class EM1(later class76) electric loco. The picture was taken about 75 years ago near Lumb Lane Bridge, Audenshaw on the Ashton Canal, Joel was posed again in 2011 in exactly the same spot. The concrete drain pipes and shed in the background have been replaced by pleasant bungalows on Slate Lane. That's enough for now, wake up at the back there!
Rivets? RIVETS!!! Tis a wooden boat with nails,spikes and cup square head bolts. Though you're right about the decorative aspect . The photo is about 75 years old
Do you want a brief comment or a boring essay?
Lock 5 "Nan Fox's" . The lock keeper's house was off the towpath where the two small trees can be seen. The house was cleared away in the 1890s when there was a big expansion of the Bradford Road gas works on the left. The concrete wall defines the gasworks boundary. The building to the right was a bakery. To the right of the pound above lock 5 was the Richard Johnson wire works, steel wire was produced from billets. Canal water was used in the process and huge amounts of millscale found its way into the canal. About 1972 the Canal Society working party were engaged in excavating by hand much of this millscale from under Forge Lane bridge where mechanical excavators could not reach. A short 2ft gauge railway was laid on the towpath and tipping skips loaded and winched out of the canal bed. This whole area of Manchester was affected by mining subsidence caused by the nearby Bradford Colliery, lock 5 had to have its walls raised in timber by about 6 inches. Lock 4 which today appears to have a drop of around 4ft is in fact the same depth as lock 5 but has buttresses at the invert. The colliery closed in 1968 because the cost of subsidence remedial work made it uneconomic. There were an estimated 300million tons of coal reserves left underground. Anyone still awake?😃
Well, me and others spent a while digging out that lock a couple of years before that picture was taken . You should have seen the state of it 10 years before. It is a very familiar scene to me,I'll leave it for others less local to identify.
I think I can answer my own question! The L&YR electrified the line beween Manchester & Bury, but for some reason,built the power station for it at Clifton Junction on the Manchester Bolton LIne. So they needed a feeder cable from Clifton to Radcliffe on the Bury line and used the old ELR route for that cable. There might have been a plan to electrify Clifton to Radcliffe but that never happened .
"An interesting perspective of Fletchers Canal This view shows a boat going onto it but what was the cargo?" Flintstone/fluorspar or similar for Pilkington's tile works? Another question: On the viaduct I can see a signal post for control of Molyneux Junction and what look like overhead catenary gantries for electric trains. I am aware that various electric traction systems were tried locally, Bury, Holcombe Brook and others in the early C20th . Not aware of it here though. Any more information? ETA, Limestone for the Aniline works?
Key words: Clifton,Molyneux, Fletchers, ELR,L&YR , and Robin Hood(!)
The starter information label should be on the outside front of the plate between the two large terminals .It may have 12v or 24v embossed on a lilttle insulated panel at the terminals in rather small characters. Also, check the connection between the copper bus bar and the back of the main terminals, round brass thing with bar slotted into it . Had one go faulty with loose connection, cured by soldering with a big iron.
TVO allows a bit higher compression ratio than straight paraffin, so more power and more economical. It was developed in the 1930s for the likes of Ferguson and Fordson (E27?) TRACTORS,. Production of TVO in bulk ceased around 1978*. There are numerous variations on the supposed mix for TVO. The Kelvin and probably Glennifer paraffin engines predate TVO , being designed from the outset to run on paraffin. The Kelvin instruction book recommends trying different brands to get best performance-Esso Blue anybody? * I have a letter somewhere from Shell oils confirming ceasing TVO production!
There are a lot of features on that engine that are very similar to the Kelvin-Ricardo petrol/paraffin engines of that era. I don't know the model of the Glennifer but I expect it was designed to run on paraffin rather than TVO. Features common to the Kelvin, that I can see: The advance/retard ignition lever rotates the magneto. The decompressor / priming valves are similar. The cylinder heads are same shape, so maybe uses the patent Ricardo combustion chamber. Have you any idea of bore size? I would guess the HP to be about 50 at sub 1000rpm. With six cylinders I would think very smooth running if you can keep all 6 firing reliably. The compression ratio will be low, less than 4.5:1 and fuel consumption poor compared with a similar sized diesel. Certainly a rare and interesting engine, I hope someone comes up with more detailed information.
In my experience, that sometimes makes it worse. A2 stainless seems most vulnerable.
That's the term I was looking for on this thread, thank you.
Stainless has a horrible habit of binding up the thread on an ordinary steel stud, i'm not sure why. Brass is way to go on exhaust stuff, the nut may destroy its own thread on removal but won't damage the steel stud. I bought a set of "Irwin" rusty nut extractors and can confirm they work well. They can be used with a 3/8"drive or ordinary spanner on the external hex.
The Bridgewater licence holders are Peel's paying customers, any other boaters , with a very few exceptions, are not. It's got nothing to do with anyone else. For the sake of clarity the breech has blocked much of my boating plans for the forseeable but I'm not a Peel customer. I look forward to being able to use the Bridgewater again.
I think Dave's Mr Jinks is more likely related to the 60s cartoon character! John Jinks was from a boating family and may well have been connected with the Jinks' boatbuilders yard at Top Lock , Marple. The yard was established in Victorian times and continued through the first half of the 20th century. Much of their business was the building and repairing of wooden boats engaged in the limestone traffic from Bugsworth and later , under contract, repairs to the Great Central Railway canal maintenance fleet.
To me it dont look that much worse/better than a standard issue brass rail over the Epping😃 Am I missing something?
The Titanic had a coal bunker fire when she left Southampton, check your fuel storage arrangements! Is it damp coal that does the spontaneous combustion thing?
The same, with some NOS replacement parts from Tom (thanks!) and elsewhere. Non original ~(no electrics in 1948) are the CAV starter and AC5 alternator. Original prop yet to be re-fitted. Great to see Norway coming back to life, considering you started with just a pile of scrap wrought iron😄.
