No, there are guys down in Bristol docks who have the relevant LPG and boat qualifications.
But I'm guessing that Rich2019's boat isn't in Warmley even if he is.
Steve
The swan neck is usually welded onto the rudder shaft on Liverpool boats. Hence the need to get the rudder off and pull the shaft up out of tne bearing.
Stefe
We replaced the bearing on our Liverpool boat a couple of years ago. The new bearing isn't expensive, but you do have to get the boat out of the water as it entails getting the rudder off. We did ours on the slipway above Broadmoor lock on the Oxford. It should only take a couple of hours.
As matty says make sure you regularly tighten the grub screws.
Steve
Having been caught out once at Gloucester when the lock wasn't ready even though I'd called ahead, I now have one of these on a short rope attached at the stern ready to drop over one of the ladders in the wall if I have to.
Though having done it many times, the lockies are excellent, and 99% of the time the gates are open and waiting if you call ahead.
Steve
Our Isuzu 38 is self priming. I ran out of fuel soon after buying the boat. All I did was put a jerry can full in the tank, turn ignition on, listen to the pump - the note changes when it's full. Turned the key and it started straight away.
Steve
Increase the vent as others have said, but you'll never completely get rid of the smell with a dump through. It may be expensive, but you're best bet is to fit a macerator.
Steve
Mark
Our Liverpool boat, built in 2004 has had Epimastic MT ( Spencer Coatings) from new. Unfortunately this is no longer available.
Of course yours may not be the same, as I believe the original owner of our boat specified the two pack.
Steve
David James are agricultural valuers and agents in Gloucestershire. They deal with all sorts of strange properties.
Their website : http://www.djandp.co.uk
Steve
An old farmer friend used to sweep the farmhouse chimney thus :
climb up onto the roof
drop a rope down the chimney
get someone to tie a large branch off of a holly tree on the bottom of the rope
Pull the rope back up the chimney
The holly branch cleans out all the soot etc.
So perhaps you could use a smaller holly branch in tne squirrel
Steve
Can anyone recommend a BSS examiner covering the Cheshire area?
We currently moor in Cropredy but will be moving to Oakwood marina near Northwich in early October. Our BSC expires mid November so I'll need to get it done soon after we arrive.
Thanks
Steve
Surprisingly ours went at the top. It was fairly thin in several places, but the only actual hole was along one edge on the top.
It's difficult to know how thick it was originally but I'd guess about 4mm. It was 14 years old.
Steve
