Content Count
120 -
Community Reputation
1 NeutralProfile Information
Gender
Location
Bucks/Oxfordshire
Previous Fields
Occupation
Electrician
Boat Name
Tamora
Boat Location
Buckinghamshire
Contact Methods
Website URL
http://
3281 profile views
Plenty of water this morning on braunston flight. Ian
Can’t see how that much water (inches!) could get past the diesel filler, but wouldn’t that end up in engine room area anyway. I would be more inclined to suspect a leak from the calorifier or plumbing. Ian
Bigcol I came past you twice as i had to turn, nice and slow I hope and I acknowledged your good lady. Will be past again on Friday as well. Obviously we are not used to that depth of water. Ian
Doesn't look like we are going anywhere soon Ian
Its hidden under a litle blanking plug next to the USB port. Ian
From Mastervolt Combi manual Ground relay The ground relay function allows you to connect the Neutral conductor (N) of the inverter output circuit to the Safety Ground (PE / GND) automatically when the Mass Combi is working as an inverter. With most electrical installations in the USA this ground relay must be set to ON. Refer to local regulations on this issue. If you want… DIP switch A SW8 no internal connection between the Neutral (N) and the Safety Ground (PE / GND) when the Mass Combi is working as an inverter OFF the Neutral wire (N) of the inverter output circuit connected to the Safety Ground (PE / GND) when the Mass Combi is working as an inverter and disconnected when incoming AC-power is applied (charger / transfer mode). ON So dip switch A number 8 should be on. Ian
I got a Huawei mobile wifi unit and it seems to work very well. You need to make sure you get the right model with the aerial port (ie the 5332). These seem to be locked on the Orange network but are easy to get unlocked via Ebay. I use a “3” sim card and have found them quite good for coverage. I just buy a top up and convert it to a £10.00 for 1Gig of data which lasts a month or until you use it up. Regards aerial I have just ordered one from http://www.connextech.co.uk/ they appear to be very helpful. Ian
Honeywell L641B 1012 Pipe Thermostat will be fine. Ian
Yes, he was talking about the canal (The sight of all the empty pounds was a very sad thing to see) not the reservoirs. Ian
Fram PH 20 is correct, there are plenty of other makes out there, I think I know most by now. Here we go then... Run engine for 5mins or so until warm. Turn off engine and remove the oil filler cap. Remove the little plug from the oil pump and turn on the valve. Pump out oil into suitable container (about 6 litres) I now like to now wait for about 5 more mins or so to let as much oil run from the filter as possible, then undo the filter with suitable wrench, try and stuff some rag below to catch the oil which will spill out when you undo it, keep the filter upright after you have removed it. Clean up the filter mounting and seal with some clean rag. Take the new filter and smear some clean oil on the rubber seal and screw on, tighten firmly by hand. Close valve on oil pump and refit plug. Refill with oil to dip stick top mark, use API CG-4 or CF-4 (you don’t need an expensive oil, I use Halfords basic diesel oil) Run engine, check for leaks, leave 5 mins then recheck oil level. Ian, fellow JD3 owner
Never used this particular make, but I fairly sure that you will find you need 230V for the receiver, will that be a problem to you? Ian
Thanks for all the replies, Tony, I forgot that I had a old switch mode 25amp bench power supply in my workshop, do you think it may do the job. It does just about get to 15.5V Yes, I am using flooded cells, 6 x 6 Volt 225Ah I installed them about nine months ago (to replace 3 new 220 Elecsols which just did not work for me) and so far they seem to be very good.
Thanks Robin Sorry but I don’t quite understand that, my 3-stage charge is Bulk, Absorption, Float at 14.25 and 13.5 Volts respectively, (Mastervolt 12/2500/100 Combi with CSCP) I cannot alter the bulk/absorption voltage but I can vary the float slightly. When I charge via the alternator (Mastervolt 120 amp 3-stage) I have more control over the voltage and bulk/absorption is set to 14.5V at 20 degrees. I can even push the voltage to just above 15V but it is a bit of a fiddle to keep adjusting it. And by the way, nothing wrong with my cables. Regarding an equalization charge, I was under the impression it could help remove sulfate crystals that might have built up on the plates. And as you point out with 6V batteries it is probably a good idea. So the general consensus seems to be that yes it is a good idea. Next question is, can I get a charger just for equalization and if so what current is required? Ian
Whilst we are talking chargers what is the consensus regarding equalizing? I only have 3 stage charging systems and can’t get to the required voltage of 15.5V (recommended by battery manufacturer). Is there anything out there I can use just for equalizing and what current would I need. Battery bank is 675Ah using 6 x 6 Volt. Thanks Ian
Go and turn it off on the bollard, then reset the trip in the boat, then reset the bollard trip and see what happens. Ian
