pete.i
pete.i last won the day on June 4 2018
pete.i had the most liked content!
    Moved now to where we want to be.
  • Interests
    Water Safety
  • Occupation
    Retired
  • Boat Name
    No boat now.
5,942 profile views
pete.i's Achievements
Rising Star
Rising Star (8/12)
395
  1. I reckon that if this bunch of cowboys that are running this country cannot fund things like the NHS etc I hardly think they are going to lash out funds for the waterways. I also do not think that whoever takes over from them will do any better. I believe that the canals, at least, would have been sold off to developers a long time ago it it wasn't for the thousands who are living on the canals who cannot just be chucked off because there is nowhere for them to go although having said that this bunch of cowboys don't seem to have any trouble housing umpteen thousand illegal immigrants.
  3. I was shot at when cruising down the Selby Canal by this yobbo. I saw him walkin up the towpath with an uncovered rifle over his shoulder. It was one of the rare sunny and warm days in Yorkshire so there were lots of parents and children on the towpath. I took a picture of him and he promptly fired his rifle at me. Luckily it missed and pinged off the side of the boat. It was back in BW days and there were actual waterways police back then so I reported the incident with the picture but as far as I am aware nothing was done. I also had rocks thrown at the boat from one of the bridges on the Selby Canal one of which narrowly missed my grandaughter. They ran when they saw my camera so I didn't manage to get any pictures of those scroats.
  4. It wouldn't use inserts if it was copper pipe and assuming that pipe is plastic then as suggested it would be better changing it to copper. But if it stays as plastic then how do you think the olive would crush down to provide a seal if there is nothing to for it to crush too? That is why it would need an insert. Anyway I wont be looking at this thread again because these threads nearly always end as arguments.
  5. I would think you would need inserts if that pipe is plastic otherwise the olive will not crush and the pipe will collapse. Something like this:- https://hgvdirect.co.uk/pack-tube-inserts-8mm-dia-pipe-6mm-id-p-40063.html
  6. I've had both. A 30 foot narrowboat and a grp cruiser. My cruiser was a Shetland and getting into the cockpit was a bit of a trial as the side was high so it meant lifting a leg or two which even at 65 was a tad hard. The narrowboats that I have had was just a step onto the back which 99% of the times was at the mooring or pontoon level. The other problem I found with the shetland was keeping it in straight line especially if there was a bit of wind. It wasn't too bad but I found the narrowboat much easier. A friend of mine had a 56 foot narrowboat (Zuny I think) that had a covered cockpit and wheel steering. I did helm that a few times and it was okay. I have given up boating now as I moved to an area without any near canals.....Ah no it was Zuni, this one....... ooppss that's copyrighted so it's gone.
  7. What does an ethanol fireplace bring to a living space? Any living space can include an open fireplace design now that ethanol fireplaces are widely available and accepted as an effective source of heat. Whether you are building, renovating or renting, you can introduce an open flame appliance at any time. I thought about one of these in the house we have just moved to. We have no chimney and there was a very old gas fire with an external flue which looked ugly. So I had all that ripped out with the idea that one of these flickering ethanol fire things which didn't need a chimney would be a good idea. problem was they gave out very little heat. Okay a lack of heat wasn't particularly a problem as we have central heating but they didn't look good in my opinion so we settled for an electric jobby with a flickering flame effect that was oodles cheaper, didn't need to be installed by some bod with a bit of paper and gave a decent amount of heat when switched on.
  8. When I had this problem on my BMC 1.5 and a friend's BMC it was the O rings. They are fairly easy to change and this is the thread that helped me.
  9. I used closed cell adhesive foam tape on my windows. My frames were screwed in and I had to reseal two windows. They weren't leaking when I got rid of that boat 5 yrears later.
  10. The last boat that I had a couple of years ago had one in that was leaking. I replaced it with the same type of bladder and cover and it was fairly easy. Of course everything was in place so I didn't have to run pipes or connect up pumps or anything. I no longer have that boat but it was all okay when I sold it.
  11. Unfortunately not. It depends on how well they have been looked after. With the best will in the world steel and water do not play well together. Also the effects of electricity on steel hulls has to be factored in. You need to do a lot of research and also realise that most of the things that you need to know about buying a narrowboat will be down to you. You will have to get a survey but that is absolutely no guarantee that the boat you choose is good. Also you must realise that sellers will not point out the bad bits no matter who they are. Good luck, I have bought 3 boats before I stopped using the canals and they were all good. My first one was well over 30 years old. Buyer beware and um caveat empress or what it's called which basically means the same thing.
  12. Those wires are quite tight on that sharpish edge of the engine. My guess is that that blue and black wire chaffed against that edge wearing the insulation until it shorted with the engine. Witout knowing where that black and blue wire goes it's imposible to say for sure that that is what caused the isolator burn out but it could have. I would rejoin the black and blue wire and replace the isolator and then keep an eye on things whilst running the engine or whatever it was you did when it burnt out. If all is well then some protection is required between that loom and the edge of the engine.
  13. They are brilliant pieces of kit. The only idiots are the ones behind, who seem to think a pram hood makes you slow, and can't be bothered to try to pass and then come on a tin pot forum to complain. How stupid is that?
  14. Most, if not all, presenters are total twits.
  15. I bought my first boat when I was 60. I gave it up when I got to 70. I'd had 3 boats in that time. I enjoyed the time I had but a move to South Wales, where I was a long way away from a canal and the roads to the nearest navigable canal were basically cart tracks, made the decision to give up permanently for me. I will admit that my age, 72, did play a significant part in that decision.
