Leaderboard
Popular Content
Showing content with the highest reputation on 06/06/21 in all areas
  9. An old photo from when it was busy and the railway and Arches can be seen in use. Most people in Sheffield don’t know this place is there or know any historical facts about the canal basin. So good to see someone taking interest in the local history.
    4 points
  11. Hi all, thought some of you may be interested in this vid . . .
    3 points
  25. 2 points
  28. It seems to me that while CaRT may think they are trying to protect you from verbal and maybe actual abuse and violence they are in fact taking the easy way out. Whilst it is clear that it is not our place t argue with the moorers you must have a local paid supervisory CaRT employee and it if the vegetation needs cutting back then his job is to ensure its done, including taking on those moorers in whatever way is appropriate. Maybe notice of refusal to renew their licence would be one way. there is too much of taking the easy option nowadays (not you - CaRT in this case).
    2 points
  31. If English is not your first language, can I suggest that you post a full description of your problem in your own language and then we can get a Google translation of your posts?
    2 points
  41. That’s not giving cyclists a bad name at all is it. Maybe that’s why they behave like they do thanks to irresponsibility from the likes of you.
    2 points
  42. And they must be screwed either fully in or fully out. Anywhere in between and you will lose compression. No it's not. Yours is a marine engine, with the flywheel at the same end as the injector pump. That generator is powered by an industrial JP3 which has the flywheel at the other end. (You do see industrial JP3s in boats, with varying degrees of marinisation and a variety of different gearboxes).
    1 point
  43. Must have been a tea break. ?
    1 point
