Squirrel scraper
rusty69
Anyone with a squirrel stove with backboiler fitted will know the routine.
Getting the debris off the top of the boiler, is always a skin scraping experience. I
always use my trusty hand.
Is there a better way, tool, hoover attachment, blanking plate or just a simple glove?
Take it out (the back boiler that is) and get a Morco!
(To go with your Morso.)
2 minutes ago, cuthound said:
And there was me thinking this post would be about a device to remove road kill from the front of a car ?
I've nearly hit 2 of the buggers this week whilst driving (me,  not the squirrel).
Phew, that was nearly a dangling participle.
1 minute ago, tree monkey said:
Obtain a small hamster, place small bits of it's favourite food over the area and place hamster in stove.
Whilst it's sniffling for snacks it will dislodge the debris
How do I get the hamster out? up the flue pipe?
One flue out of the hamsters nest!
I hold that said hamster would die of CO poisoning before dislodging all of the debris.
Although I suppose it might work if the stove is allowed to go out first...
1 minute ago, philjw said:
Love the humour but it would be great if there was such a bit of kit. It would save the skin on the back of the hand from punishment.  I have considered a crook shape attachment for a vacuum cleaner but have yet to attempt to build one.
Ah finally another poster bitten by their squirrel. Pity they don't leave just a bit more room between boiler and stove.
An old farmer friend used to sweep the farmhouse chimney thus :
climb up onto the roof
drop a rope down the chimney
get someone to tie a large branch off of a holly tree on the bottom of the rope
Pull the rope back up the chimney
The holly branch cleans out all the soot etc.
So perhaps you could use a smaller holly branch in tne squirrel
Steve
Edited by Just Heaven
Cant spell holly!
A great idea for flue cleaning. I would still be left with the problem of removing the rubbish off the boiler though.
It's not getting the flue clean that is the issue - quite the reverse. All of the muck disloged from the flue ends up on top of the boiler where it is hard to remove.
Apparrently they used a method similar to your branch to clean Blisworth tunnel. The museum has photos of a boat loaded up with branches which was towed through to clean of the soot from the steam tugs.
In an attempt to be serious :offtopic::offtopic:
This is a problem I will encounter in a couple of hours when I go up to the boat to prepare it for the winter (minor op in a couple of weeks so won't be able to get to it for a couple of months). In the past I've tried an ash vac, various hand and paint brushes, shaped metal scrapers and assorted bits and pieces. Without doubt the best tool is the Mk 1 hand in a rubber glove. The glove soon gets destroyed but the job gets done..
If anyone can come up with a sensible suggestion in the time it takes to drive 75 miles I would be grateful.
Frank
