rivergate Posted August 21, 2016 Report Share Posted August 21, 2016 Does anyone have a source - ideally off the shelf, for this please..? Thanks in advance Jon Link to comment Share on other sites More sharing options...
MtB Posted August 21, 2016 Report Share Posted August 21, 2016 Steel packing you mean, presumably? Given 1/8" or 3mm (different sizes to an engineer) therefore accuracy isn't necessary, I'd suggest a mooch around Wickes or B&Q. They both have racks of metal bar for sale in sizes like 3mm x 20mm. Both steel and aluminium. Link to comment Share on other sites More sharing options...
rivergate Posted August 21, 2016 Author Report Share Posted August 21, 2016 Its for a jabsco and hand diesel pump...like gland packing... Link to comment Share on other sites More sharing options...
rivergate Posted August 21, 2016 Author Report Share Posted August 21, 2016 Mike? - I added this question to both in case someone who isn't interested in old boats didn't look here... ...take it easy with the exclamation marks please Link to comment Share on other sites More sharing options...
bizzard Posted August 21, 2016 Report Share Posted August 21, 2016 Try Cleghorn Waring Jabsco. Icknield way Letchworth, Herts. Or a steam model engineers supplier. Link to comment Share on other sites More sharing options...
Laurence Hogg Posted August 21, 2016 Report Share Posted August 21, 2016 You can buy it on ebay. Link to comment Share on other sites More sharing options...
MtB Posted August 21, 2016 Report Share Posted August 21, 2016 Its for a jabsco and hand diesel pump...like gland packing... Try these people. They have a trade counter you can buy anything in their catalogue over the counter... http://www.heritagesteamsupplies.co.uk/ Link to comment Share on other sites More sharing options...
rivergate Posted August 21, 2016 Author Report Share Posted August 21, 2016 Thank all .....anywhere near to Stockton which might stock it..? lol Link to comment Share on other sites More sharing options...
X Alan W Posted August 21, 2016 Report Share Posted August 21, 2016 (edited) If you cannot obtain the size you require a larger size can be flattened to a smaller size in one plain with hammer a wood strip/ block Edited August 21, 2016 by X Alan W Link to comment Share on other sites More sharing options...
rivergate Posted August 21, 2016 Author Report Share Posted August 21, 2016 Thanks Alan - that's my Plan B Cheers Link to comment Share on other sites More sharing options...
bizzard Posted August 21, 2016 Report Share Posted August 21, 2016 I wouldn't do that, get the correct size. Oversize packing flattened can seize and wear out the shaft. 1 Link to comment Share on other sites More sharing options...
adrianh Posted August 23, 2016 Report Share Posted August 23, 2016 Please clarify, are you using this for diesel? If so you will need the PTFE type gland packing - I will look for some in my stock. This type is common on isolating valve stems, graphite filled types, ie stern gland packing is not suitable for diesel. Link to comment Share on other sites More sharing options...
RLWP Posted August 24, 2016 Report Share Posted August 24, 2016 Please clarify, are you using this for diesel? If so you will need the PTFE type gland packing - I will look for some in my stock. This type is common on isolating valve stems, graphite filled types, ie stern gland packing is not suitable for diesel. What did wing pumps use in the days before PTFE existed? Richard Link to comment Share on other sites More sharing options...
X Alan W Posted August 24, 2016 Report Share Posted August 24, 2016 What did wing pumps use in the days before PTFE existed? Richard Some of the old semi rotary pumps had what appeared to be graphite coated Cork unless the graphite was crud & it was just plain cork Link to comment Share on other sites More sharing options...
MtB Posted August 25, 2016 Report Share Posted August 25, 2016 What did wing pumps use in the days before PTFE existed? Richard Well whatever they use now, it still leaks! Link to comment Share on other sites More sharing options...
WotEver Posted August 25, 2016 Report Share Posted August 25, 2016 Well whatever they use now, it still leaks! Hey Mike, clear out your PM box will ya! Link to comment Share on other sites More sharing options...
