Martin CC O'Beirne Posted May 30, 2015 Report Posted May 30, 2015 Oh no – anyone got any advice? I let a friend stay on my boat for 2 days, and he somehow managed to separate the flue from the top plate, I’m not sure how the fitting should work, so not sure how to fix it, I tried fixing it with that heat clay but that failed, the flue doesn’t sit naturally over the hole, it requires pressure to keep it in place, it has a back boiler, lots of plumbing, so moving the unit is not preferable to moving the flue – Do I just need a new cuff or topplate or some other fix, can you take off the top plate really? I would have though these things become jammed with heat over the years Any advice appreciated Cheers Martin
MtB Posted May 30, 2015 Report Posted May 30, 2015 The top plate on my Squirrel distorted concave in it's dying days, leaving a 1/4" gap below the flue collar. Maybe yours has done the same. MtB
RLWP Posted May 30, 2015 Report Posted May 30, 2015 The flue should really sit nicely on top of the stove and move up and down in the roof collar. There's an installation guide on the BSS site somewhere Richard
Martin CC O'Beirne Posted May 30, 2015 Author Report Posted May 30, 2015 Mike, that would explain it - dodgy photo - it just appears to be hovering over the top, I assumed the collar must have broken 1
RLWP Posted May 30, 2015 Report Posted May 30, 2015 Check tthe flange on the back of the top, you will probably find it's broken as well. Richard
Tonka Posted May 30, 2015 Report Posted May 30, 2015 (edited) The flue should really sit nicely on top of the stove and move up and down in the roof collar. There's an installation guide on bas Not if it cast That explains why all squirrel stoves are failing. Edited May 30, 2015 by Tonka
b0atman Posted May 30, 2015 Report Posted May 30, 2015 I believe collar is held in place by screws which rot with the heat and sheer off remove collar and drill and tap bolt holes or buy new collar.
nine9feet Posted May 30, 2015 Report Posted May 30, 2015 (edited) I believe collar is held in place by screws which rot with the heat and sheer off remove collar and drill and tap bolt holes or buy new collar. Yep! The parts are Collar 44140921 Lugs 44256700 Bolts 743625 Note there are 2 sizes of collar above is larger as my installation has a step down connector to the 4" flue. Edited May 30, 2015 by nine9feet
MtB Posted May 30, 2015 Report Posted May 30, 2015 Or just buy a new stove... Once a Squirrel starts playing up like this the writing is on the wall. Cut your losses NOW.
RLWP Posted May 30, 2015 Report Posted May 30, 2015 The flue should really sit nicely on top of the stove and move up and down in the roof collar. There's an installation guide on bas Not if it cast That explains why all squirrel stoves are failing. Key word is should. The flue should move in the roof collar. Of course, most are cemented in solid, the flue expands and breaks the stove top Richard
MtB Posted May 30, 2015 Report Posted May 30, 2015 Oi Richard, Why are you posting on here instead of getting leathered at the lapworth banter???!!
RLWP Posted May 30, 2015 Report Posted May 30, 2015 Multi tasking. I'm in touch with me feminine side <HIC> Richard
MtB Posted May 30, 2015 Report Posted May 30, 2015 Too much information Richard! MtB P.S. I got in touch with my inner self the other day. That's the last time I'm buying Tesco 'Value' toilet roll...
Alan Saunders Posted May 30, 2015 Report Posted May 30, 2015 Yep! The parts are Collar 44140921 Lugs 44256700 Bolts 743625 Note there are 2 sizes of collar above is larger as my installation has a step down connector to the 4" flue. Thank you, not only have my bolts and lugs long disappeared into the ash tray but the collar is cracked.
Tonka Posted June 20, 2015 Report Posted June 20, 2015 ame="Tonka" post="1580391" timestamp="1433004182"] Key word is should. The flue should move in the roof collar. Of course, most are cemented in solid, the flue expands and breaks the stove top Richard But that means that the top of the stove is supporting a cast iron flue and a Squirrel is not designed to support this.
bizzard Posted June 20, 2015 Report Posted June 20, 2015 The top plates on Squirrels are terribly thin and I reckon just the weight of the flue pipe resting on it will eventually cause trouble even if it does move in the roof collar. A couple of hefty stand off's clamped to the pipe and secured strongly to the cabin wall behind would help take the weight. If the packing around the pipe in the roof collar is not too tightly packed and sealed with silicon, which should remain flexible, it will allow the pipe to move up and down. Ordinary cheap silicon is fine, it's all fireproof.
smileypete Posted June 21, 2015 Report Posted June 21, 2015 (edited) The top plates on Squirrels are terribly thin and I reckon just the weight of the flue pipe resting on it will eventually cause trouble even if it does move in the roof collar. A couple of hefty stand off's clamped to the pipe and secured strongly to the cabin wall behind would help take the weight. How about something clamped or welded on the lower end of the flue, that looks like a buttress but transfers the flue weight onto the edges of the stove sides/back. Short answer seems to be that Squirrels may not be that boater proof... cheers, Pete. ~smpt~ Edited June 21, 2015 by smileypete
Alan Saunders Posted June 21, 2015 Report Posted June 21, 2015 The top plate of my Morso Squirrel is intact despite a very heavy flue pipe. However, the flue collar has cracked (it was sealed with solid fire-clay) and has detached from the top-plate. I believe it was originally bolted to the top-plate with two screws through its flanges. All sealed up with expensive high temperature black silicone sealant but yet another dirty, difficult job that will require a proper repair before next winter. It always worthwhile checking the contents of the ash-pan or on top of the 'smoke deflector' and trying to determine where the various pieces of cast iron came from. Alan
MtB Posted June 21, 2015 Report Posted June 21, 2015 How about something clamped or welded on the lower end of the flue, that looks like a buttress but transfers the flue weight onto the edges of the stove sides/back. That's a very good idea...
dor Posted June 22, 2015 Report Posted June 22, 2015 The top plates on Squirrels are terribly thin and I reckon just the weight of the flue pipe resting on it will eventually cause trouble even if it does move in the roof collar. A couple of hefty stand off's clamped to the pipe and secured strongly to the cabin wall behind would help take the weight. If the packing around the pipe in the roof collar is not too tightly packed and sealed with silicon, which should remain flexible, it will allow the pipe to move up and down. Ordinary cheap silicon is fine, it's all fireproof. When I have fitted a SF stove, either Squirrel or Stovax, I fix the flue in the roof collar with silicone and leave the bottom of the flue floating with a small gap. A thin piece of wood, 3 or 4mm can be used to support it initially (the wood will burn away). Then a piece of rope tapped down not too tight, then fill the rest with high temp (300 deg.C) silicone such as Delta. Never had a failure of the type described. All fire cements I have come across inevitably crack due to expansion and movement of the metal, which can lead to leaks.
