Androo Posted May 24, 2014 Report Share Posted May 24, 2014 Is this normal ? When I have the throttle lever in neutral and engage forward or reverse there is an annoying clonking noise. I always allow a few seconds before going from Forward/Rev or Rev/Forward and I move the lever gently to it's position Does something need adjusting to stop this like a cable etc...? The engine mounts are new and tight but, even with the old engine mounts it still did this. BMC 1500 PRM Gearbox Is this a common BMC/PRM problem? Link to comment Share on other sites More sharing options...
saltysplash Posted May 24, 2014 Report Share Posted May 24, 2014 Have you checked the gearbox oil? and can you pull the prop shaft back and forward by hand? Link to comment Share on other sites More sharing options...
David Mack Posted May 24, 2014 Report Share Posted May 24, 2014 Or could be the drive plate (between engine and gearbox) on the way out. I should have asked is this a new thing or has it always done it? Link to comment Share on other sites More sharing options...
Androo Posted May 24, 2014 Author Report Share Posted May 24, 2014 Have you checked the gearbox oil? and can you pull the prop shaft back and forward by hand? Gearbox oil was changed last Sept 20hrs done since then. Regards prop shaft, not done that. What does that mean anyway? Or could be the drive plate (between engine and gearbox) on the way out. I should have asked is this a new thing or has it always done it? Since I bought the boat 5 years ago it's always done this. Link to comment Share on other sites More sharing options...
RLWP Posted May 24, 2014 Report Share Posted May 24, 2014 PRM gearboxes do do that Richard Link to comment Share on other sites More sharing options...
saltysplash Posted May 24, 2014 Report Share Posted May 24, 2014 Gearbox oil was changed last Sept 20hrs done since then. Regards prop shaft, not done that. What does that mean anyway? Since I bought the boat 5 years ago it's always done this. If the shaft is loose it can shift forwards and backwards when engaging gears. I had one try to exit the boat once when emergency reverse was engaged Link to comment Share on other sites More sharing options...
Geoff Taylor Posted May 24, 2014 Report Share Posted May 24, 2014 Hi, Just a thought, if your engine idle RPM is a little too high it can amplify the engagement noise of the gearbox, PRM gearboxes are designed to permit changes from forward to reverse at full revs without damage so I would be looking towards a drive plate check. (BMC 1500 idle approx 600 RPM). Our boat has a PRM 150 connected to a Perkins 4108 and is literally silent when forward or reverse is engaged regardless of revs. Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 25, 2014 Report Share Posted May 25, 2014 PRM mechanical or hydraulic gearbox? I think a PRM mechanical one may well do that, especially if the revs were a bit high but it definitely worth checking the drive plate. Link to comment Share on other sites More sharing options...
Pykebird Posted May 25, 2014 Report Share Posted May 25, 2014 Does it have an aquadrive/python fitted? Mine was rattling like a good one and turned out to be a loose bolt. Link to comment Share on other sites More sharing options...
Androo Posted May 25, 2014 Author Report Share Posted May 25, 2014 PRM mechanical or hydraulic gearbox? I think a PRM mechanical one may well do that, especially if the revs were a bit high but it definitely worth checking the drive plate. Mechanical. I always let the revs die down before changing. Idle is set at approx 650rpm Does it have an aquadrive/python fitted? Mine was rattling like a good one and turned out to be a loose bolt. I have a flexible coupling and all the bolts are tight. Mechanical. I always let the revs die down before changing. Idle is set at approx 650rpm I have a flexible coupling and all the bolts are tight. Does checking the drive plate mean, splitting the gearbox/engine? or is there an inspection hole? Link to comment Share on other sites More sharing options...
pete.i Posted May 25, 2014 Report Share Posted May 25, 2014 Hi The drive plate is attached to the face of the fly wheel. In the same place that the clutch would be attached in a road vehicle. It does a similar job to a clutch in as much that it takes up some of the initial torque when you engage forward or reverse on your boat. because of where it is attached the only way that I know of to inspect it is to separate the gearbox from the engine. I have a BMC 1.5 and Hurth gearbox and I do not have an inspection hole. An "on the way out" drive plate can cause clunking but as Richard (RLWP) says some gearboxes clunk anyway, mine does. Pete Link to comment Share on other sites More sharing options...
Traveller Posted July 19, 2014 Report Share Posted July 19, 2014 Revising an old topic. My gearbox does the same (more apparent when the engine/gearbox is warm). It only happened at low revs (when passing moored boats on tick-over for instance) and goes away once the revs are increased. It is not noticeable in reverse.What oil is recommended for a hydraulic box? Tks Colin Link to comment Share on other sites More sharing options...
Grace and Favour Posted July 19, 2014 Report Share Posted July 19, 2014 Revising an old topic. My gearbox does the same (more apparent when the engine/gearbox is warm). It only happened at low revs (when passing moored boats on tick-over for instance) and goes away once the revs are increased. It is not noticeable in reverse. What oil is recommended for a hydraulic box? Tks Colin You'll need to tell folks which gearbox you have - - different boxes use quite different lubricants Link to comment Share on other sites More sharing options...
Traveller Posted July 19, 2014 Report Share Posted July 19, 2014 Yes, thought that might be the case. Was hoping there would be some kind of generic answer :-( The boat is a 1978 Peter Nicholls with BMC 1.5 but I cannot find a makers label on the gearbox. Any pointers please? Link to comment Share on other sites More sharing options...
Tony Brooks Posted July 20, 2014 Report Share Posted July 20, 2014 If it is oval in cross section with a vertical longitudinal split and fins cast on the outside its is probably a Hurth (Automatic transmission fluid). If it is sort of oval or heart shaped and looks as if it has been fitted by a drunk (because it looks skewed on the engine and it has a couple of hydraulic hoses comping out of it then it is probably a PRM hydraulic (engine oil). Once you eliminate those two we need a photo. At that age it could be a TMP hydraulic or a number of other makes. Unless it has been changed in the last few years it is unlikely to be a PRM mechanical box. These are rectangular with rounded corners in cross section with no vertical split. They have fins cast onto the case. They now use Automatic transmission fluid. Do not extrapolate from this post to an unknown box. post a photo. Link to comment Share on other sites More sharing options...
Traveller Posted July 20, 2014 Report Share Posted July 20, 2014 Thanks for this Tony, I am away from the boat for a few days now but will have a look-see again when I get back. The PRM looks likely but I can't remember it looking as though a drunk had fitted it :-). What I do remember is the filler cap is a large hexagonal job with the dip stick going through the middle of it.A picture will follow idc. Link to comment Share on other sites More sharing options...
RLWP Posted July 20, 2014 Report Share Posted July 20, 2014 What I do remember is the filler cap is a large hexagonal job with the dip stick going through the middle of it. It's definitely a PRM of some kind then Richard Link to comment Share on other sites More sharing options...
Traveller Posted July 20, 2014 Report Share Posted July 20, 2014 My gearbox does the same (more apparent when the engine/gearbox is warm). It only happened at low revs (when passing moored boats on tick-over for instance) and goes away once the revs are increased. It is not noticeable in reverse. Thanks Richard, so engine oil it is? Any thoughts on the noise? Link to comment Share on other sites More sharing options...
RLWP Posted July 20, 2014 Report Share Posted July 20, 2014 Thanks Richard, so engine oil it is? Any thoughts on the noise? Engine oil it is The clonk - ours does it too and has for years. I suspect if I took it apart I would find the splines on the forward clutch to be worn. As long as it still works, I'm leaving it alone Richard Link to comment Share on other sites More sharing options...
Traveller Posted July 20, 2014 Report Share Posted July 20, 2014 Many thanks. It certainly works and works well seemingly. Link to comment Share on other sites More sharing options...
Traveller Posted July 21, 2014 Report Share Posted July 21, 2014 It's definitely a PRM of some kind then Richard Just been trawling pics on Google and it could well be a TMP gearbox I think. A TMP certainly has the same oil filter arrangement and also sports a hexagonal filler nut through which the dip stick passes. Link to comment Share on other sites More sharing options...
RLWP Posted July 21, 2014 Report Share Posted July 21, 2014 (edited) We need a picture Richard MORE: Bet it is a PRM 100 or similar early PRM with the oil filter Edited July 21, 2014 by RLWP Link to comment Share on other sites More sharing options...
Traveller Posted July 21, 2014 Report Share Posted July 21, 2014 Shall take a pic when down at the boat tomorrow. I do know that Peter Nicholls fitted TMPs. That said he also fitted PRMs! Link to comment Share on other sites More sharing options...
StarUKKiwi Posted July 22, 2014 Report Share Posted July 22, 2014 Ours has just started clunking, I wondered if it could be the oil filter Link to comment Share on other sites More sharing options...
Traveller Posted July 23, 2014 Report Share Posted July 23, 2014 I now have a photo of the gearbox but how do I attach it here? Link to comment Share on other sites More sharing options...
