Boat&Bikes Posted July 16, 2012 Report Share Posted July 16, 2012 Having only been boating for a year and only properly getting to grips with locks of various types this year due to being stuck between Foxton and Watford for much of last year,ive a question about how long my centre rope should be? I thought the rule of thumb is that it shouldnt reach the prop if dropped into the water,this however makes it awkward when going through broad locks when i want to run the rope around a bollard to steady the boat.When descending locks i run the rope around a bollard and hold the end,then as the boat drops rope gets shorter until i have to release it.Most of the time i simply left the lock and managed to grab the rope as it dropped,though missed once and had an awkward moment leaning over the side to scoop the rope from the water.Any suggestions as to how i should improve my technique?Obviously a longer rope would make it simple as i would not need to lose my grasp of it,trouble is it would then reach the prop if it were to fall into the water. Ian. Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 16, 2012 Report Share Posted July 16, 2012 Having only been boating for a year and only properly getting to grips with locks of various types this year due to being stuck between Foxton and Watford for much of last year,ive a question about how long my centre rope should be? I thought the rule of thumb is that it shouldnt reach the prop if dropped into the water,this however makes it awkward when going through broad locks when i want to run the rope around a bollard to steady the boat.When descending locks i run the rope around a bollard and hold the end,then as the boat drops rope gets shorter until i have to release it.Most of the time i simply left the lock and managed to grab the rope as it dropped,though missed once and had an awkward moment leaning over the side to scoop the rope from the water.Any suggestions as to how i should improve my technique?Obviously a longer rope would make it simple as i would not need to lose my grasp of it,trouble is it would then reach the prop if it were to fall into the water. Ian. That is how I decided on the length of my rope so if it does slip in the water I don't have to worry about it and can retrieve it at leisure. I have seen boats try to leave locks and get the centre rope round the prop Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 Descending a broad lock, I tuck the bow into the corner between the gate and the lock side. Then take the stern line, put three-quarters of a turn around a bollard and drop the coil of rope on the floor. As the boat descends, it pulls the rope around the bollard, the friction in doing this holds the stern in. This works for me Richard Link to comment Share on other sites More sharing options...
Boat&Bikes Posted July 16, 2012 Author Report Share Posted July 16, 2012 That is how I decided on the length of my rope so if it does slip in the water I don't have to worry about it and can retrieve it at leisure. I have seen boats try to leave locks and get the centre rope round the prop So i persevere with the rope i have,seems sensible,thanks for that. Ian. Link to comment Share on other sites More sharing options...
Guest Posted July 16, 2012 Report Share Posted July 16, 2012 Having only been boating for a year and only properly getting to grips with locks of various types this year due to being stuck between Foxton and Watford for much of last year,ive a question about how long my centre rope should be? I thought the rule of thumb is that it shouldnt reach the prop if dropped into the water,this however makes it awkward when going through broad locks when i want to run the rope around a bollard to steady the boat.When descending locks i run the rope around a bollard and hold the end,then as the boat drops rope gets shorter until i have to release it.Most of the time i simply left the lock and managed to grab the rope as it dropped,though missed once and had an awkward moment leaning over the side to scoop the rope from the water.Any suggestions as to how i should improve my technique?Obviously a longer rope would make it simple as i would not need to lose my grasp of it,trouble is it would then reach the prop if it were to fall into the water. Ian. We have two centre lines both of which are more than long enough to wrap around the prop if fully deployed. However we also boat on deep wide waterways were a very long centre line can be useful. We therefore 'lose' some of the length by winding the line around the handrail and the centre T stud and unwind the line when we expect to need it.....see pic. I'm not sure if it's considered good 'boatmanship' - but it works for us. Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 16, 2012 Report Share Posted July 16, 2012 We have two centre lines both of which are more than long enough to wrap around the prop if fully deployed. However we also boat on deep wide waterways were a very long centre line can be useful. We therefore 'lose' some of the length by winding the line around the handrail and the centre T stud and unwind the line when we expect to need it.....see pic. I'm not sure if it's considered good 'boatmanship' - but it works for us. Best of both worlds Link to comment Share on other sites More sharing options...
onionbargee Posted July 16, 2012 Report Share Posted July 16, 2012 i'm saying rule no. 1 of boating is never have any rope attached to your boat that can reach the propeller. That's my rule and i'm sticking to it. Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 i'm saying rule no. 1 of boating is never have any rope attached to your boat that can reach the propeller. That's my rule and i'm sticking to it. You must have a mighty short stern line Richard Link to comment Share on other sites More sharing options...
Guest Posted July 16, 2012 Report Share Posted July 16, 2012 (edited) i'm saying rule no. 1 of boating is never have any rope attached to your boat that can reach the propeller. That's my rule and i'm sticking to it. Fairy nuff.... where do I put my stern line then?? ed. cross post with Richard. Edited July 16, 2012 by The Dog House Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 16, 2012 Report Share Posted July 16, 2012 Fairy nuff.... where do I put my stern line then?? ed. cross post with Richard. I only put my stern rope on the bollard when it about to be used and take it off straight afterwards. The rest of the time its coiled up. Link to comment Share on other sites More sharing options...
magpie patrick Posted July 16, 2012 Report Share Posted July 16, 2012 i'm saying rule no. 1 of boating is never have any rope attached to your boat that can reach the propeller. That's my rule and i'm sticking to it. A very sensible idea, although it can get a bit more complicated, when we owned Ripple I always took the stern rope off the dolly and laid it on the bench in the semi-trad stern ready for when needed. Overall, Ianali, I'd suggest a centre rope as long as you need it, and at least as long as the boat, but stow it so it is to hand but not in particular danger of ending up in the water. Link to comment Share on other sites More sharing options...
Guest Posted July 16, 2012 Report Share Posted July 16, 2012 I only put my stern rope on the bollard when it about to be used and take it off straight afterwards. The rest of the time its coiled up. So do I - but that is not what OB said - Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 So do I - but that is not what OB said - Zackly Richard Link to comment Share on other sites More sharing options...
onionbargee Posted July 16, 2012 Report Share Posted July 16, 2012 You must have a mighty short stern line Richard It's not permanently attatched is it ! Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 i'm saying rule no. 1 of boating is never have any rope attached to your boat that can reach the propeller. That's my rule and i'm sticking to it. It's not permanently attatched is it ! Where did you say permanently? Richard Link to comment Share on other sites More sharing options...
onionbargee Posted July 16, 2012 Report Share Posted July 16, 2012 Give us a break ! Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 Give us a break ! Richard Link to comment Share on other sites More sharing options...
David Mack Posted July 16, 2012 Report Share Posted July 16, 2012 Give us a break ! Give him a KitKat! Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 16, 2012 Report Share Posted July 16, 2012 They are in a funny mode tonight, must be something in the water Link to comment Share on other sites More sharing options...
RLWP Posted July 16, 2012 Report Share Posted July 16, 2012 They are in a funny mode tonight, must be something in the water Highland Park Richard Link to comment Share on other sites More sharing options...
Grace and Favour Posted July 16, 2012 Report Share Posted July 16, 2012 Och - - are ye tryin' to toss ye caber laddie? Link to comment Share on other sites More sharing options...
luctor et emergo Posted July 16, 2012 Report Share Posted July 16, 2012 The stern line should be coiled up, and hung over the convinient tiller pin. Link to comment Share on other sites More sharing options...
bottle Posted July 16, 2012 Report Share Posted July 16, 2012 He is trying to be controversial Link to comment Share on other sites More sharing options...
LoneWolf Posted July 16, 2012 Report Share Posted July 16, 2012 So i persevere with the rope i have,seems sensible,thanks for that. Ian. Well i dunno, it depends what you're comfortable with. My centre line is over 12 metres on a 45' boat which is well long enough to go round the prop but i prefer it that length for singlehanding. It hasn't come anywhere near the moving prop yet, probably because i always keep in mind that it could. I've gotten into the habit of always coiling it up as i walk to the stern and placing it on the slider before i get on even if i'm going to pick it up again a minute later eg as i exit the lock Link to comment Share on other sites More sharing options...
MtB Posted July 16, 2012 Report Share Posted July 16, 2012 That is how I decided on the length of my rope so if it does slip in the water I don't have to worry about it and can retrieve it at leisure. I have seen boats try to leave locks and get the centre rope round the prop I prefer 10 metre centre lines. I avoid them fouling the prop by not dropping them in the water. Mike Link to comment Share on other sites More sharing options...
