RLWP Posted June 17, 2011 Report Share Posted June 17, 2011 If you can work out the volume of the space that you have available, just use the relative density of the materials Typically: Iron/steel: 7850 kg/cu m Lead: 11340 kg/cu m Obviously if you dig in to you savings: Gold: 19320 kg/cu m Platinum: 21400 kg/cu m How about depleted uranium? Richard 1 Link to comment Share on other sites More sharing options...
twbm Posted June 17, 2011 Report Share Posted June 17, 2011 How about depleted uranium? Richard It has a half-life - the boat would slowly get lighter. 1 Link to comment Share on other sites More sharing options...
RLWP Posted June 17, 2011 Report Share Posted June 17, 2011 It has a half-life - the boat would slowly get lighter. Pretty slowly though Richard Link to comment Share on other sites More sharing options...
twbm Posted June 17, 2011 Report Share Posted June 17, 2011 True, but think of the power you could generate at the same time ..... Link to comment Share on other sites More sharing options...
Chertsey Posted June 17, 2011 Author Report Share Posted June 17, 2011 True, but think of the power you could generate at the same time ..... It's hard enough doing the risk assessment for my cargo carrying licence as it is! 1 Link to comment Share on other sites More sharing options...
Hairy-Neil Posted June 17, 2011 Report Share Posted June 17, 2011 Are those blue barrels 40 gal = 200l = 1/5 tonne? A standard steel barrel is 207 litres Link to comment Share on other sites More sharing options...
cereal tiller Posted June 17, 2011 Report Share Posted June 17, 2011 probably not suitable for you but when i built my narrowboat i used "building blocks",the ones with no lime in. i used two and a half metric tonnes,each block was around 20 kg.the price?in 1997 was around a hundred squid... Link to comment Share on other sites More sharing options...
RLWP Posted June 17, 2011 Report Share Posted June 17, 2011 True, but think of the power you could generate at the same time ..... And it could work as underfloor heating Richard Link to comment Share on other sites More sharing options...
c c Posted June 17, 2011 Report Share Posted June 17, 2011 probably not suitable for you but when i built my narrowboat i used "building blocks",the ones with no lime in. i used two and a half metric tonnes,each block was around 20 kg.the price?in 1997 was around a hundred squid... I have just taken 240 compressed concrete blocks out of Badsey and stacked them in the car park awaiting a good home for a reasonable offer. Link to comment Share on other sites More sharing options...
Chertsey Posted June 17, 2011 Author Report Share Posted June 17, 2011 I have just taken 240 compressed concrete blocks out of Badsey and stacked them in the car park awaiting a good home for a reasonable offer. How much space did they occupy and where were they sited on Badsey? What do you reckon is their total weight? Are you taking them out because they didn't work for you? What are you having instead? Link to comment Share on other sites More sharing options...
flatplane8 Posted June 17, 2011 Report Share Posted June 17, 2011 I've put about 16 tons of steel from Mann Buck in Misterton see hereand here. Not as cheap as concrete, but more dense and that's probably what you want (depending on what you're planning to do with the cargo area) Link to comment Share on other sites More sharing options...
c c Posted June 17, 2011 Report Share Posted June 17, 2011 How much space did they occupy and where were they sited on Badsey? What do you reckon is their total weight? Are you taking them out because they didn't work for you? What are you having instead? PM sent with info Link to comment Share on other sites More sharing options...
onionbargee Posted June 17, 2011 Report Share Posted June 17, 2011 (edited) At the moment Chertsey is ballasted with three of those great big tanks (what are they called? You know, about four foot cubed, white polythene/polypropylene or similar, in a wire cage) full of water. They are a bloody nuisance and I want to replace them with ballast that is, as far as possible, laid on the baseplate under the floors. Firstly, can someone tell me how much those tanks hold, and then I can work out how much weight I've got in there now (we just put the tanks in and pumped in water until the boat looked right). Then, what to replace it with? I am thinking that realistically only steel will give me anything like sufficient weight per volume at something approaching an affordable cost. Are there any tables of the weight:volume ratios of various other alternatives? (concrete slab, engineering bricks, anything else??) Does anyone know of a source of steel (billets?) suitable for use as ballast? I've been told that it should be steel and not iron because of the corrosion potential of introducing a different metal. And is there anything else I need to think of? 1000 litre IBC, intermediate bulk container. fill them with gas oil a the bulk rate straight off the tanker, and beat the rising fuel prices, 2000 L should last you 4 or 5 years, imagine what the oil price will be then ! My town class motor only needs less than a ton to get the back end down and the prop to bite, why not chuck the ballast under the backcabin floor, or if you wanted to go mad put a water ballast tank under there, maybe a rubber one, pump it in and out when you need it. Edited June 17, 2011 by onionbargee Link to comment Share on other sites More sharing options...
FadeToScarlet Posted June 18, 2011 Report Share Posted June 18, 2011 Magnums of champagne will only appreciate in value there's apparently one boat that has this ballast method. Having a store of diesel seems popular around here, a boater I know put 6 drums under the tug deck when it was 30-odd p per litre. Link to comment Share on other sites More sharing options...
blackrose Posted June 19, 2011 Report Share Posted June 19, 2011 (edited) 17-18 tonnes of stone should do nicely. In a narrow boat? Unless my calculations are wrong I think I've got about 8 tonnes of concrete ballast in my 57' x 12' widebeam (that's 2 layers of broken concrete slab over a 39' x 12' area). Edited June 19, 2011 by blackrose Link to comment Share on other sites More sharing options...
Chertsey Posted June 19, 2011 Author Report Share Posted June 19, 2011 In a narrow boat? Unless my calculations are wrong I think I've got about 8 tonnes of concrete ballast in my 57' x 12' widebeam (that's 2 layers of broken concrete slab over a 39' x 12' area). Yes, that'd be nearly a full load, hence my response Link to comment Share on other sites More sharing options...
blackrose Posted June 20, 2011 Report Share Posted June 20, 2011 (edited) Yes, that'd be nearly a full load, hence my response I see - I thought you were recommending the correct amount of ballast! Edited June 20, 2011 by blackrose Link to comment Share on other sites More sharing options...
mykaskin Posted June 20, 2011 Report Share Posted June 20, 2011 Yes, that'd be nearly a full load, hence my response That would be nearer 38 tons would it not? Mind you more than 19 tons gets a little sticky on all but the deepest bits of canals. Mike Link to comment Share on other sites More sharing options...
c c Posted June 20, 2011 Report Share Posted June 20, 2011 How much space did they occupy and where were they sited on Badsey? What do you reckon is their total weight? Are you taking them out because they didn't work for you? What are you having instead? Sorry for delay - I was trying to find something to weigh one block but here goes:- Each block measures 44x22x10 cms and weighs about 25/26 lbs each (could only weigh a spare broken half-block on my weighing machine so is close but not totaly accurate) 25lbs x 240 blocks = 6000 lbs = 2.7 metric tonnes = 2.68 UK Tons. Link to comment Share on other sites More sharing options...
