Trilby Tim Posted July 9, 2009 Report Share Posted July 9, 2009 I want to tile the area of wall behind the hob to form a splashback and protect the wall from the heat. What's the best way to go about it? I've heard of masterboard as a fire-proof insulation, can I stick that to the lining and then tile? What's the best way to hold it, screws, adhesive, both? What's the best tile adhesive to bond the tiles to it? How thick board do I need, and does anyone know of somewhere in Sheffield I can get it, I've looked at Wickes and B&Q and can't find it. Cheers Link to comment Share on other sites More sharing options...
Ally Posted July 9, 2009 Report Share Posted July 9, 2009 If you have a Travis Perkins there, they should have some. 6 mm should be fine, and we usually screw it on. Use a flexible adhesive for the tiles, and you can buy flexible grout too! Ally Link to comment Share on other sites More sharing options...
WotEver Posted July 9, 2009 Report Share Posted July 9, 2009 If you have a Travis Perkins there, they should have some. 6 mm should be fine, and we usually screw it on. Use a flexible adhesive for the tiles, and you can buy flexible grout too! Ally I've seen it in B&Q. T Link to comment Share on other sites More sharing options...
Mac49 Posted July 9, 2009 Report Share Posted July 9, 2009 I want to tile the area of wall behind the hob to form a splashback and protect the wall from the heat. What's the best way to go about it? I've heard of masterboard as a fire-proof insulation, can I stick that to the lining and then tile? What's the best way to hold it, screws, adhesive, both? What's the best tile adhesive to bond the tiles to it? How thick board do I need, and does anyone know of somewhere in Sheffield I can get it, I've looked at Wickes and B&Q and can't find it.Cheers Have you tried Sheffield Insulation? I used to get stuff off them until they closed my local branch. I've used flexible tile adhesive or a grab adhesive when there was just a few tiles but it was easy and seems to have worked really well so might be tempted to just use that in future. Rick Link to comment Share on other sites More sharing options...
paulcatchpole Posted July 9, 2009 Report Share Posted July 9, 2009 (edited) I want to tile the area of wall behind the hob to form a splashback and protect the wall from the heat. What's the best way to go about it? I've heard of masterboard as a fire-proof insulation, can I stick that to the lining and then tile? What's the best way to hold it, screws, adhesive, both? What's the best tile adhesive to bond the tiles to it? How thick board do I need, and does anyone know of somewhere in Sheffield I can get it, I've looked at Wickes and B&Q and can't find it.Cheers B+Q Warehouses do Masterboard, but not the smaller ones, or at least that's what they told me. Not cheap stuff either, and unsurprisingly heavy given it's a cement particle board. It's sold as a waterproof tile-backer board, so ideal for tiling to. We used it for a hearth for our Aga[-alike], and for surrounding it behind tiles. I screwed it in place, then tiled as usual, with a decent flexilbe adhesive and grout. I like Mapei stuff, but any really good quality products should be fine. The Mapei ultracolor grout is really nice to use - fine and smooth! PC Edited to add: Here's a pic of some pieces of masterboard going in, from last year: Edited July 9, 2009 by paulcatchpole Link to comment Share on other sites More sharing options...
Chertsey Posted July 10, 2009 Report Share Posted July 10, 2009 Is heat such an issue behind the hob that you need board as well as tiles? Link to comment Share on other sites More sharing options...
WotEver Posted July 10, 2009 Report Share Posted July 10, 2009 Is heat such an issue behind the hob that you need board as well as tiles? Depends on the distance from the hob to the cabin side I'd guess. But it doesn't hurt to be safe. T Link to comment Share on other sites More sharing options...
blackrose Posted July 10, 2009 Report Share Posted July 10, 2009 (edited) I want to tile the area of wall behind the hob to form a splashback and protect the wall from the heat. What's the best way to go about it? I've heard of masterboard as a fire-proof insulation, can I stick that to the lining and then tile? What's the best way to hold it, screws, adhesive, both? What's the best tile adhesive to bond the tiles to it? How thick board do I need, and does anyone know of somewhere in Sheffield I can get it, I've looked at Wickes and B&Q and can't find it.Cheers I'd stick the masterboard on with marineflex (PU adhesive/sealant similar to sikaflex), or you could just screw it to the wall. Then I'd stick the tiles to the masterbord with the red heat reistant silicone. You only need a blob on each corner and perhaps one in the middle of each tile. Then grout witha flexible grout. If you must use tile adhesive you'll have to prime the masterboard first with PVA or a porus surface primer because the porosity of the board draws the water out of the adhesive and reduces its efficiency. Edited July 10, 2009 by blackrose Link to comment Share on other sites More sharing options...
Trilby Tim Posted July 10, 2009 Author Report Share Posted July 10, 2009 Thanks for the replies, useful as ever. I'm not sure if the board is necessary, but better safe than sorry. The hob instructions specify 55mm minimum from the wall, which I can just about comply with, but that's for a vertical wall, not a sloping inwards one, so I think it's worth giving it a bit of protection from the heat. Link to comment Share on other sites More sharing options...
Canal Shop Man Posted July 10, 2009 Report Share Posted July 10, 2009 We can supply Masterboard cut to size for you for £2.20 per square foot plus cost of postage, if you can't find it locally or don't want an 8' x 4' sheet Link to comment Share on other sites More sharing options...
Richard T Posted July 19, 2009 Report Share Posted July 19, 2009 We used a piece of brushed stainless steel plate cut to size by a local steel fabricator. Then didn't have to worry about tiles and its easy to keep clean and good looking. Link to comment Share on other sites More sharing options...
sueb Posted July 19, 2009 Report Share Posted July 19, 2009 We used a piece of brushed stainless steel plate cut to size by a local steel fabricator. Then didn't have to worry about tiles and its easy to keep clean and good looking. We did the same at home. I can't think why we haven't done the same on the boat. Sue Link to comment Share on other sites More sharing options...
