Pie Eater Posted November 17, 2008 Report Share Posted November 17, 2008 I have some very stubborn philips head screws that I want to to remove to get into my water tank to clean it. I seem to recollect reading somewhere about a gadget that you can place over the offending screw and then whack it on the top with a hammer and this automatically taps the screw anti clockwise and starts to release it. Does anyone know what the gadget is called and where I can get one. Or was I having a vivid dream. Steve Link to comment Share on other sites More sharing options...
twocvbloke Posted November 17, 2008 Report Share Posted November 17, 2008 (edited) Impact Screwdriver? I know a guy in the US who sells them for Kirbys with stuck screws, but the shipping price is a bit much as it weighs a fair bit... This is it if you need a reference picture: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=180227927685 Edited November 17, 2008 by twocvbloke Link to comment Share on other sites More sharing options...
mayalld Posted November 17, 2008 Report Share Posted November 17, 2008 I have some very stubborn philips head screws that I want to to remove to get into my water tank to clean it. I seem to recollect reading somewhere about a gadget that you can place over the offending screw and then whack it on the top with a hammer and this automatically taps the screw anti clockwise and starts to release it. Does anyone know what the gadget is called and where I can get one. Or was I having a vivid dream. Steve Impact driver. Any car accessory shop should sell them, as they are commonly used to remove screws from brake disks and drums. Link to comment Share on other sites More sharing options...
bottle Posted November 17, 2008 Report Share Posted November 17, 2008 Pie Eater A little tip, tighten the screws first. Screwfix have them on a clear out sale. They work both ways Link to comment Share on other sites More sharing options...
zenataomm Posted November 17, 2008 Report Share Posted November 17, 2008 Another good tip is to touch the head of the screw with something very hot like a soldering iron. The rapid expansion can break the seal. If you have electrickery to your boat, or a cordless drill, then get yourself one of these.............. http://www.jmldirect.com/Screw-Extractor-PS5616/ Works a treat, so long as the screw is a quality one and not a cheapy alloy one. Cheapy ones just get the head ripped off them. Good luck. Link to comment Share on other sites More sharing options...
Pie Eater Posted November 17, 2008 Author Report Share Posted November 17, 2008 Thanks everyone, I have just purchased an 15 piece Impact Driver kit from a local motor factors. Now I just have to find time to try it out. Steve Link to comment Share on other sites More sharing options...
John Orentas Posted November 17, 2008 Report Share Posted November 17, 2008 Thanks everyone, I have just purchased an 15 piece Impact Driver kit from a local motor factors. Now I just have to find time to try it out. Steve Steve; As you are into 'spending mode' buy some A2 stainless steel screws to replace the ones you are removing. Link to comment Share on other sites More sharing options...
johnjo Posted November 17, 2008 Report Share Posted November 17, 2008 (edited) Probably a bit late now, but putting some heat on as previously posted is a good idea, but before trying to untighten it, [not with your gizzmo thingy] try to tighten it very slightly with screwdriver, this will also help to break the seal, but less likely to snap the head off, remember just a tweak,and don't forget good old WD40. Then use your gizzmo thingy. If you have an old driver especially one thats lost it's handle use that with a pair of mole grips, and give the driver a sharp tap with a hammer, this can also work. The reason it's better with the handle missing is you hit the other end of the shaft and not a soft shock absorbing handle. Hopefully you've already got them all out in one piece. Regards John Edited November 17, 2008 by johnjo Link to comment Share on other sites More sharing options...
Hairy-Neil Posted November 17, 2008 Report Share Posted November 17, 2008 .... buy some A2 stainless steel screws to replace the ones you are removing. Stainless steel bolts will seize into mild steel nuts or tapped holes in short order. It's the old dissimilar metals/ galvanic corrosion thing again..... Link to comment Share on other sites More sharing options...
Amicus Posted November 17, 2008 Report Share Posted November 17, 2008 Impact drivers, don't pussy-foot about with wussy hammers, use a lump hammer and give it a good one. Link to comment Share on other sites More sharing options...
TeeELL Posted November 18, 2008 Report Share Posted November 18, 2008 A tip I was given by a gunsmith, well used to locked solid screws, machine screws etc is to take a flat punch of the same diameter as the offending screw head and then give it a whack. The idea is the 'release the thread', then do the tightening slightly bit before unscrewing. Link to comment Share on other sites More sharing options...
ditchcrawler Posted November 18, 2008 Report Share Posted November 18, 2008 Steve; As you are into 'spending mode' buy some A2 stainless steel screws to replace the ones you are removing. and a tube of "Copaslip" Link to comment Share on other sites More sharing options...
Pie Eater Posted July 27, 2009 Author Report Share Posted July 27, 2009 At long last I finally got around to trying out the new impact driver at the weekend - I followed the advice given by Amicus and used a lump hammer and it works brilliantly. Managed to release all the screws holding the water tank cover on and drained the remaining water in the tank and left the cover off to help the tank to dry out. Next job is to scrape & wire brush the tank before treating with bitumen. Thanks to eveyone who offered advice. Steve Link to comment Share on other sites More sharing options...
WotEver Posted July 28, 2009 Report Share Posted July 28, 2009 At long last I finally got around to trying out the new impact driver at the weekend ... 8 months from asking the question to getting around to doing the job. I like your laid back style, sir Link to comment Share on other sites More sharing options...
