Maudesmaster Posted May 21, 2024 Report Posted May 21, 2024 I’ve had my 3LW Cylinder head overhauled by Gardner Marine when the cam sharp end is pointing down is the time to set the gap on the valve top if I use a dial test indicator on the rocker adjusting screw and turn engine over by hand when the pointer stops moving and just before pointer starts to move would be spot on I guess Yes I’m not back on boat for 4 weeks after hip replacement
Tracy D'arth Posted May 21, 2024 Report Posted May 21, 2024 13 minutes ago, Maudesmaster said: I’ve had my 3LW Cylinder head overhauled by Gardner Marine when the cam sharp end is pointing down is the time to set the gap on the valve top if I use a dial test indicator on the rocker adjusting screw and turn engine over by hand when the pointer stops moving and just before pointer starts to move would be spot on I guess Yes I’m not back on boat for 4 weeks after hip replacement The base circle of a cam lobe is usually wide and not critical radially. The reverse applies to the cam peak of course. One turn of the engine crank away from the fully open position of the relevant valve will always be the correct point to set the tappet gap.
jonesthenuke Posted May 21, 2024 Report Posted May 21, 2024 You seem to have a complicated way of doing this. I follow the Gardner manual:- valve clearances.pdf Or this.
Tony Brooks Posted May 21, 2024 Report Posted May 21, 2024 12 minutes ago, jonesthenuke said: You seem to have a complicated way of doing this. I follow the Gardner manual:- valve clearances.pdf 1.08 MB · 1 download Or this. And you think the manual way is simpler that valve fully open, one revolution of the engine, adjust clearance?
jonesthenuke Posted May 21, 2024 Report Posted May 21, 2024 34 minutes ago, Tony Brooks said: And you think the manual way is simpler that valve fully open, one revolution of the engine, adjust clearance? Less complicated than a DTI !
Tony Brooks Posted May 21, 2024 Report Posted May 21, 2024 8 minutes ago, jonesthenuke said: Less complicated than a DTI ! I agree, except if the rocker ends were pitted (which they won't be after an overhaul) a DTI would probably be needed and thus mounted, but otherwise no point in using one.
Tracy D'arth Posted May 22, 2024 Report Posted May 22, 2024 15 hours ago, Tony Brooks said: I agree, except if the rocker ends were pitted (which they won't be after an overhaul) a DTI would probably be needed and thus mounted, but otherwise no point in using one. To set tappets when there is wear pitting I used the rotational method. That is close the gap completely and unwind the adjuster by a known degree of rotation depending on the thread pitch to equate to the required gap. For example on a BMC engine with 5/16" UNF thread adjuster a quarter turn gives almost 16 thou inch gap, close enough to the required 15 thou inch.
Maudesmaster Posted May 22, 2024 Author Report Posted May 22, 2024 16 hours ago, Tracy D'arth said: The base circle of a cam lobe is usually wide and not critical radially. The reverse applies to the cam peak of course. One turn of the engine crank away from the fully open position of the relevant valve will always be the correct point to set the tappet gap. Great thanks
Maudesmaster Posted June 18, 2024 Author Report Posted June 18, 2024 After turning engine over and over checking and rechecking jobs a good un took a day but mind is at rest cant take video but sounds lovely Thank you every one much appreciated
agg221 Posted July 20, 2024 Report Posted July 20, 2024 2 hours ago, XLD said: How often do members check tappets? Roughly every 250 operating hours or so. Alec 1
Tonka Posted July 20, 2024 Report Posted July 20, 2024 1 hour ago, agg221 said: Roughly every 250 operating hours or so. Alec every 500 hours according to the Beta BD3 manual
