GUMPY Posted Thursday at 17:06 Report Share Posted Thursday at 17:06 How can one change their user name The boat is going and I might not want the association with the new owner whoever they may be. Link to comment Share on other sites More sharing options...
Solution M_JG Posted Thursday at 17:08 Solution Report Share Posted Thursday at 17:08 Just now, Loddon said: How can one change their user name The boat is going and I might not want the association with the new owner whoever they may be. Account settings / display name / change Link to comment Share on other sites More sharing options...
rusty69 Posted Thursday at 17:09 Report Share Posted Thursday at 17:09 Just now, Loddon said: How can one change their user name The boat is going and I might not want the association with the new owner whoever they may be. I think you an change the display name within account settings, but to change it permanently, you probably have to ask a moderator to intervene. Link to comment Share on other sites More sharing options...
GUMPY Posted Thursday at 17:13 Author Report Share Posted Thursday at 17:13 4 minutes ago, M_JG said: Account settings / display name / change I will have to look at that when I'm not on my phone Link to comment Share on other sites More sharing options...
M_JG Posted Thursday at 17:14 Report Share Posted Thursday at 17:14 3 minutes ago, rusty69 said: I think you an change the display name within account settings, but to change it permanently, you probably have to ask a moderator to intervene. Not sure what you mean. If you change it you then log in with the new name but same password. You can only change it once every 180 days though. Caveat - unless something has changed following a forum software update. Link to comment Share on other sites More sharing options...
rusty69 Posted Thursday at 17:19 Report Share Posted Thursday at 17:19 2 minutes ago, M_JG said: Not sure what you mean. If you change it you then log in with the new name but same password. You can only change it once every 180 days though. Caveat - unless something has changed following a forum software update. Fair enough. It used to be that it could only be changed by a moderator. It looks like the software now allows the display name as a log in. I assumed that may be different than user name. Apparently not. I hope Loddon wanted to be gumpy and not grumpy 😂 Is GUMPY an acronym? Link to comment Share on other sites More sharing options...
GUMPY Posted Thursday at 17:21 Author Report Share Posted Thursday at 17:21 Just now, rusty69 said: Fair enough. It used to be that it could only be changed by a moderator. It looks like the software now allows the display name as a log in. I assumed that may be different than user name. Apparently not. I hope Loddon wanted to be gumpy and not grumpy 😂 Yes GUMPY is correct comes from the fact that a two year old can't say grumpy 1 1 Link to comment Share on other sites More sharing options...
M_JG Posted Thursday at 17:22 Report Share Posted Thursday at 17:22 Just now, rusty69 said: Fair enough. It used to be that it could only be changed by a moderator. It looks like the software now allows the display name as a log in. I assumed that may be different than user name. Apparently not. I hope Loddon wanted to be gumpy and not grumpy 😂 On Thunderboat the user log in and display name can be two different things. Other forums are like that too. I dont think here is. Link to comment Share on other sites More sharing options...
stablemabel Posted Thursday at 17:35 Report Share Posted Thursday at 17:35 My name isnt actually STABLE MABLE..its MICHEAL RECYCLE..or is it STEVEN UNEVEN..no its FORUM DECORUM 1 Link to comment Share on other sites More sharing options...
buccaneer66 Posted Thursday at 18:10 Report Share Posted Thursday at 18:10 55 minutes ago, M_JG said: Caveat - unless something has changed following a forum software update. That is quite possible as I can't change my username due to there being no change button. Link to comment Share on other sites More sharing options...
M_JG Posted Thursday at 18:17 Report Share Posted Thursday at 18:17 7 minutes ago, buccaneer66 said: That is quite possible as I can't change my username due to there being no change button. Possibly because you are a moderator?? Loddon has successfully changed his. Link to comment Share on other sites More sharing options...
MtB Posted Thursday at 21:46 Report Share Posted Thursday at 21:46 4 hours ago, stablemabel said: My name isnt actually STABLE MABLE Correct. It's "stablemabel". Other good usernames in a similar vein could be: Ollie Gark Purple Wayne Chubby chick Walter Pump Harry Stottle Link to comment Share on other sites More sharing options...
Mike Hurley Posted Friday at 06:08 Report Share Posted Friday at 06:08 8 hours ago, MtB said: Correct. It's "stablemabel". Other good usernames in a similar vein could be: Ollie Gark Purple Wayne Chubby chick Walter Pump Harry Stottle Betty Swallocks. Mary Hinge.😁 Link to comment Share on other sites More sharing options...
IanD Posted Friday at 09:54 Report Share Posted Friday at 09:54 (edited) So if you've blocked somebody irritating/hateful and they change their name, do they reappear in your feed? That would be annoying... 😞 Mind you, that works both ways... 😉 Edited Friday at 09:54 by IanD Link to comment Share on other sites More sharing options...
PCSB Posted Friday at 16:18 Report Share Posted Friday at 16:18 6 hours ago, IanD said: So if you've blocked somebody irritating/hateful and they change their name, do they reappear in your feed? That would be annoying... 😞 Mind you, that works both ways... 😉 Not sure with this forum software, but with the variety of other softwares I've worked with each user has a unique ID (always numeric) and all actions and preferences are keyed on the ID. Numbers are faster than text in SQL DB's (or they used to be ...). As this is a well established forum software I'd expect it to be the same. Link to comment Share on other sites More sharing options...
GUMPY Posted Friday at 17:49 Author Report Share Posted Friday at 17:49 7 hours ago, IanD said: So if you've blocked somebody irritating/hateful and they change their name, do they reappear in your feed? That would be annoying... 😞 Mind you, that works both ways... 😉 I don't know, am i still blocked @IanD 1 1 Link to comment Share on other sites More sharing options...
IanD Posted 23 hours ago Report Share Posted 23 hours ago On 26/05/2023 at 18:49, GUMPY said: I don't know, am i still blocked @IanD Nope, because you make sensible posts 🙂 Link to comment Share on other sites More sharing options...
