Need advice on a kabola drip feed boiler. Diesel is dripping out of the soot scraper. Can these be repaired or is a new one in order..
Share this post
Ask Kuranda in Whalley Bridge.
Share this post
Does it not have a nut shaped tightener that you can give a slight turn which should seal it?
Share this post
Mine did that. I cured it by tightening the nut on the end. If it still leaks aftwr that the butyl rubber "O" ring needs replacing
Kuranda will not sell a new "O" ring, only a complete scraper assembly. They advise wrapping the scraper in PTFE tape. According to the Refleks forum, (worth joining if you have any oil drip stove) replacement "O" rings can be obtained from agricultural merchants.
Edited by cuthound
Share this post
As long as you have FAME free fuel, nitrile or butyl will be fine. However, if you have any bio fuel content, Viton is the only reliable option.
Share this post
When I worked for BT we tested Nitrile rubber with biodiesel and found it unaffected up to a 10% bio content. Currently biodiesel commercially available has a 7% concentration.
Share this post
