Brain has filed and cannot retrieve information
what the formula steps to convert AC wattage to DC amperage .. I know I have to build a loss factor in for inverter etc.
I can do the i = v/r etc but how to transpose 230v ac to 12 v dc
brain dead fool
I need wine
1 minute ago, Loddon said:
Will it help or confuse you more ?
Thanks j
People say if you work it out as 10 volts DC it allows for the inefficiencies so 1000 Watts is 100 Amps
Thank you I couldn’t remember the average ....
back to calcs
brain dead fool
I need wine
If you think in Watts, then simply decide the voltage you interested in and calculate the current to suit using W=IV.  If going through an inverter or transformer than add on say 10% for losses.
Absolutely. That might err on being slightly pessimistic but that’s a good thing.
I'd be a bit careful about generalising about alternating current.
it is very unpredictable and jumps all over the place, one moment this way, next moment that way.  in fact if you are a mathematician looking at the sine wave curve you could persuade yourself that it isn't really there at all.
I was brought up on 4.5v batteries that I put in my bicycle headlight - much easier to understand.       :rolleyes:
All my youthful electrical experimentation was powered by those Ever Ready 4.5V batteries with screw terminals on the top.
