Kismet
Shower Mixer, with a uneven wall
Hi,
Need some help, Currently fitting a new shower mixer into my shower on my boat. The walls are un even ( not surprised) but this means that with the shower mixer central piece pushed flat, the washers of the in/ out pipes do not lie flat on the wall, See picture attached. Is there a smart way to get around this? I was currently thinking packing it out with washers then siliconing round this, but wanted to see if anyone has any knowledge to do it any better way.
Thanks
Share this post
20 minutes ago, OldGoldy said:
Surely tha chrome nut(s) screws down til the trim touches the wall?
I think they are compression fittings or tap connectors that connect to the plastic pipe so I doubt they will go any further.
Share this post
47 minutes ago, OldGoldy said:
and as the OP has stated its the tiling/wall that is not level I doubt there is much he can do apart from try to cut a large circle out of the tiles the mixer body goes against so the body is recessed into the tile. I suppose the proper way would be to take the tiles off, level the wall and re-tile.
Share this post
Or a block of fancy wood with a counterbored hole.
ETA, or a posh chrome packing piece (a washer by any other name)
Edited by rusty69
Share this post
that would work a slog as the OP can lengthen the pipes a bit. Not sure how durable the finish on the wood would be in a shower though.
Share this post
Yup. That’s why I hadn’t replied earlier, it was the only solution I thought of.
Share this post
Fit a different shower mixer with 2 rather than 3 wall contact points. There's plenty of tube shaped ones on the market with controls for flow one end and temperature at the other. Clearly this involves another expense, but it has the potential to give you the most elegant solution.
Share this post
It looks to me that the pipes are too long for the fittings.  The amount that the trim is clear of the tile looks a lot more than the unevenness of the tiles.
On my showers, the threaded part of the pipe the shower fittings screw onto are pretty much level with the tile.
Share this post
