whoops I didn't realise it was set to that- have now changed!
I don't have an inverter as when not plugged in the 240V plugs don't work - which never was a problem for me as I stay put in the marina and only go out for the occasional weekend.
The 'inverter charger' is this different to an inverter?
Think I was more aware of my battery setup when first buying the boat and had forgotten it all as I haven't been cruising and hadn't thought about it! So will try and learn a bit more about the setup...
They are open cells, and I have two batteries. will have a closer inspection of them when back, at work right now and can also take some pictures.
12v things were working when the mains was on. Last time I was off the mains electricity was August and the 12v lights definitely worked then. The lights went out and at the time the only electric I was using were the 12v lights so hard to tell if the 240 went out at the same time as the 12v. However I was using 240 plugs earlier in the evening, so if the 12v stayed on it would have been probably minutes rather than hours.
As for the battery isolator being off, is this something I would have to physically turn off or can it turn it self off?
thanks all for the help, making me realise I need to take more care of my battery set up!
