Days Won
34
Everything posted by Jen-in-Wellies
Isolator for Bow Thruster Battery
Jen-in-Wellies replied to cuthound's topic in Boat Building & Maintenance
The lever on these switches can be removed when in the OFF position, but not the ON. A safety thing. When working on the electrics it can be turned off and the key taken away with the person working on the system to prevent it being accidentally turned on. When ON you want to be able to turn it off in an emergency and having to hunt round for the key is not what you need! Since a bow thruster is only used when cruising then the key could be out and the cap to keep the internals a little drier. On @cuthound's boat it might be possible to use longer bolts and washers under the mounting plate to space the lever down enough to remove the key while still having enough room to get it to engage and turn. Alternatively, fitting a new mounting plate in a better spot. Need to be a bit careful, as the gas locker may be behind the bulkhead, so making holes for bolts leads in to "does it pass BSS or not" territory. A welded plate would be better from that point of view. Jen -
Here you go. This is what you have. https://www.midlandchandlers.co.uk/products/battery-switch-250a-single-pole-durite-vs-054 I have these on my boat. As fitted by Pipers when it was built. Jen -
Fitting a galvanic isolator
Jen-in-Wellies replied to Galilee's topic in Boat Building & Maintenance
If we see it in next years OED we'll know there is one of their compilers on the forum. -
Me too. It definitely meets their criteria of protecting bystanders around the boat. -
My experience too with several friends boats. Mains installed, with GI, or without, but no hull earth bond. With boat electrics never assume anything! Jen -
Based on my experience: A lot more expensive than a GI. Fit and forget. Less likely to fail unsafe from a hull corrosion point of view, so no monitoring needed. Monitoring of a GI often gets done less often than it should. CO and fire alarms should be tested once a week according to the makers. Most don't get this, mine included. If you connect generators with weird earth arrangements the earth will be redefined properly on the boat. They can be a bit buzzy sometimes when drawing a large load. The soft start thing on my Victron includes a loud relay, so, if on board, I can hear if the shore power goes down. Takes up more space than a GI. My take. If you can afford one and your boat spends most of its time on a marina shore lead, then they are the gold plated solution. Otherwise, a GI and regular testing. For most people the extra cost isn't worth the marginal differences above. Jen
We have land line boxes on each of our residential moorings here. A few people use them. We have a really good 4G signal here. Much faster than the land line broad band. I've never bothered looking in to getting the land line connected. Since I once accidentally destroyed an electric bollard by setting off with the shore line still connected I don't think I could be trusted with another wire... If the mobile signal is poor where you are then it might be worth it. Jen
Wot @WotEver said. You might get away with it, or the routers life might be a bit short. Depends on how well the input electronics on the router are designed if it can cope with being powered direct from the boat, or not. Since these things are designed down to a price my guess is not very. As well as the higher than 12V voltage from the alternator, or charger, you also have various high voltage spikes coming down the wires from things like water pumps. A voltage stabiliser, like that linked to above is what you need. Jen
I've had a Victron isolation transformer installed for the last twelve years. It has the anti-surge gubbins that @Onewheeler ,mentions. Not cheap, but basically fit and forget. It is fitted in a similar position to where you are proposing, so some protection from the rain, but not total. Wind driven rain and the hatch open would get it wet. I keep the hatch closed and doors shut when cruising if it is raining for that reason. You've got a cruiser stern, so can do the same. Or build a vented cupboard around it to keep it dry. Jen
Just had a look again and it now says: I wonder which part the seller decided was in error?
There was another recent thread where this was pointed out and we came to roughly the same figures. Oak lock gates seem to last 25 years so.... Until the balance beam rots through and falls off when someone tries to open the gate. Damage by a boater according to CaRT. Accountants. Experts in everything, not just bean counting. ?
I agree that you can find shed boats everywhere. What is special here is the discrepancy between the extreme shedness of the boat and the apparent pride with which the seller describes it. I don't know if he is just talking it up in the hope that a mug buyer on ebay will actually pay £8k for it, of if he is genuinely proud of it and blind to its shedness and his complete lack of any skill in fitting it out. Jen
Yes, that looks like it. If the alternator in questions centre terminal says D+, then this goes to the warning lamp. The other side of the warning lamp goes to battery +ve (via fuses, switches etc.)
The B terminal goes to Battery Positive. A thick wire. What is the lettering under the centre red connector? It is probably the connection for the ignition warning light, but this needs confirming. W is probably the connection to the tacho. If so, then not needed just to get it running.
Finding out the which connection is which may be tricky. A possibility could be to find a place locally that repairs alternators and starter motors. Most towns of any size will have one. They may be able to tell you. Are there any numbers, or letters moulded in to the plastic by the terminals. If so, what are they as they may give a clue? You're going to need to do some research. Jen
A Ford Sierra 2.0 was a model of car, not a type of alternator. The picture may have been of an alternator that was fitted in that car. The picture also shows a ribbed belt pulley, not a V belt, which I would have thought more likely on a Sabb 10hp single cylinder engine, so you may have to change the pulley at one end, or the other and possible in between too. In order to be able to wire it up you need to know which is the output, which will be the largest and which is the alternator light wire. There may be others like sense wires and tacho outputs too. I have no idea what this is on an old Sierra car alternator. The alternator warning light needs connecting up as otherwise the alternator won't work. It is not just the wiring diagram, but an idea on wire sizes. Connections to the engine block from the battery negative and from the battery positive to the starter motor need to be a minimum of 25mm2. The alternator output to battery positive, or starter positive can be smaller, perhaps 10, or 6mm2, depending on the alternator output current and distance. Connections to any glow plugs may need to be substantial. 4mm2, or more, depending. Other wires can be lighter. Boat safety scheme says there needs to be an isolator switch to disconnect the battery, but see the comments on the risk of wrecking the alternator. I have put in a basic wiring set up in a friends boat to get the engine running so it could be moved and it can be very simple, but you need to understand what you are doing. Jen
Battery drills - capacity, cost & weight.
Jen-in-Wellies replied to rusty69's topic in Boat Equipment
Greatn (where n is a very large number) Grandfather Bizzard said "But half the time, folk don't need bronze tools to do simple jobs when peaceful flint tools can do it. Most folk these days have lost the art of knapping flint. Around here for example, we have folk getting out their wretched bronze axes to cut up twigs when they can be cut much more quickly with a flint blade glued with pine resin in to a wooden handle. Mucking about with smelting and casting and the smoke and smell just to get a few ounces of bronze. Having to trade with foreigners in Wales and Cornwall for copper and tin. It 'taint natural. This new fangled metal ought to be banned. Kids today." -
Well it is the correct type of glass for a stove door. The kitchen does have a fire extinguisher and blanket. Escape should be easy as a light kick would get you through any cabin side. The gaps in the roof are a charming and novel way to meet the high level ventilation recommendations and acts as a flue for the gas heater. The cooker sloping in to the wall means it can't topple over. The "builder" has definitely read at least some of the BSS requirements. No bids yet, despite the seller having 100% positive feedback. The next and bigger project will be something to see!
Is that the alternator that has been on the engine, or the one you plan to put on it? Just the thing at the top says Ford Sierra 2..0i, which was a petrol car. I used to have one! If so, then it may not have a connection for a tacho. Jen
I got that one wrong. A puddle of dish water collects at the far end of the draining board. Not a big thing, but annoying. ? The floor is used as an assumed flat level datum to work from. Only actually horizontal when the boat is sometimes out the water. Depending on how level the ground is. Jen
You missed out connecting the earth on the "boat" side of the GI to the boat hull. What, if any inverter do you have? Does it do auto switch over between shore power and inverter supplied mains? You may have to connect that to boat earth too to ensure there is a functioning earth under all circumstances that ensures the hull doesn't go live. Depends. Jen -
Can you change engine mounts with a jack?
Jen-in-Wellies replied to Pirateringo's topic in Boat Equipment
Can you change engine mounts with a jack? Their name doesn't need to be Jack. -
A cheap supplier of methylated spirits?
Jen-in-Wellies replied to Mad Harold's topic in General Boating
IT doesn't have the pyridine and purple dye in it to make it undrinkable that you get in the UK. On trips to France I try and bring back enough to keep my Trangia stove going till the next time. Much cheaper and smells nicer than anything you can easily buy in the UK. Jen -
If a stove has survived the best part of a century, then it is likely at lower risk of cracking as all the dodgy ones failed long ago. However, a boat installation might put new stresses on it that it never experienced before. Particularly expansion loads from the flue, if the seal through the roof collar is rigid. Just did an image search on Godin Radiolette's. A very striking and pretty stove. Jen
Is it always the day after curried sprout night? ?
