M molly
    Female
M molly's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. Sorry wasn't clear I know it's off a FORD Sierra 2.0 the pulley has been changed to a v belt the wire still on the starter motor ready to be wired up but wanted to find out the right way and I have a insulator switch to with a warning light and a igniton switch to wire up thank u Sorry wasn't clear I know it's off a FORD Sierra 2.0 the pulley has been changed to a v belt the wire still on the starter motor ready to be wired up but wanted to find out the right way and I have a insulator switch to with a warning light and a igniton switch to wire up thank u
  2. It's a FORD Sierra 2.0 am putting on just needed a diagram of wiring to a battery I'll add battery pack on later on for power inside the boat thank u plus got the igniton switch and the warning light thank you
  3. The person I got the boat of took the wiring out so got to do it from scratch the engine is a sabb single cindinder 10hp and I'll get a pic of the alternator in a min thank u FORD Sierra 2.0i
  4. Can any one give me a diagram of alternator wiring to battery pack thank u
  5. How much u think I would get my this engine thank u
  6. Just wondering if any one knows how rare this is as people want my engine and don't know weather to change it and sell the engine or keep it in any one can help or share with me about it thank you
  7. Over the last month a mop bucket off water I've pull some Polystyrene off and it's like rain drops water underneath thank u
  8. What do u think it could be as the only place that doesn't look wet inside is around the fire thank you
  9. Hi all I hope you may beable to help I have a little nb 26ft had only month in which time I have been staying aboard it's a Cosgrove which I have researched with no joy it is unusual construction hull of which I have never seen before it is neither v or flat bottom it has a central trough running down the middle at the bow there is a triangular section which seems to be collecting water at first I thought condensation but am also worried the hull could be damaged anodes and blacking have not been done for I don't know how long which was my next plan after rip out and new insolation as currently has ok polystyrene and a new refit any help would be gratefully received thanks in advance and happy cruising to all m,Molly Sorry also sides of hull are glistening wet thanks
