PaulG Posted December 7, 2016 Report Posted December 7, 2016 I still think the easiest way is a small 24v battery bank - a couple of cheap, small car batteries for example - next to the toilet and charged by a small charger circuit. Charger does not need to be very big as the amp hours used will be quite low. I agree - as I suggested in post #7. Simple, reliable and cheap.
Chewbacka Posted December 7, 2016 Report Posted December 7, 2016 I agree - as I suggested in post #7. Simple, reliable and cheap. If we are playing 'who said it first' how about post #2
PaulG Posted December 7, 2016 Report Posted December 7, 2016 If we are playing 'who said it first' how about post #2 Well, I'm certainly not going to play "let's start an argument over something we agree about"...
fudd Posted December 7, 2016 Author Report Posted December 7, 2016 I've just taken delivery of the bog. Reading the manual it states 24v needs 25 amps. I can easily get a 20 amp converter. Would it be suitable? I know there could be a certain amount of redundancy built in. Thanks.
Keith M Posted December 7, 2016 Report Posted December 7, 2016 If the manual states 25 amps is that the peak power or the current required after the start up current Some the manual will state running current and not the starting current Starting current can easily be 3 or 4 times the running current Always select a device which will have around 30% in reserve Keith
fudd Posted December 7, 2016 Author Report Posted December 7, 2016 It just says 25amps. I assume it's the starting current.
WotEver Posted December 7, 2016 Report Posted December 7, 2016 Is it this one? http://coastalrides.co.uk/index.php?route=product/product&product_id=14544 If so, that states "Maximum current 25A" for the outlet pump. Plus another 4A for the inlet pump. Tony
OldGoat Posted December 7, 2016 Report Posted December 7, 2016 Very much IMO, but unlike AC induction motors, the starting current is less of an issue. However, the run current is likely to the reasonably near the published figure. Remember that the macerator is expected to be powerful enough to shred all sorts of solid matter (loo paper and some non ingested matter as well) as part of their design. It may appear to be a bit od a faff, but I'd go for a couple of inexpensive c-tec type chargers wired in series (Aldi have them from time to time) together with a couple of low maintenance Yuasa type batteries - they will provide enough grunt for the grinding bit. Don't assume 25A is the starting current DC stuff is not rated that way. In similar vein don't assume that the 12/24V converter can handle a peak load of any length.
Arthur Brown Posted December 7, 2016 Report Posted December 7, 2016 A battery on short fat wires has to be a good choice of power supply. The charger could be anything from a Mains driven one, to solar, to a 12v derived one. A good charge regime should help the batteries to last as long as a starter battery.
NMEA Posted December 7, 2016 Report Posted December 7, 2016 I wonder at how much current this thing draws. Folk have been saying 40A @ 24V, so I'm guessing that a motor rewound for 12V is going to draw about double that? It'll need seriously fat cables if that's the case. Or is the 40A purely to cover start-up surge? The recommended fuse is 35a for a 24v DC unit so I suspect the draw will be quite a bit lower than 35a certainly nowhere near 40a which is the recommended fuse for a 12v DC unit.
WotEver Posted December 7, 2016 Report Posted December 7, 2016 The recommended fuse is 35a for a 24v DC unit so I suspect the draw will be quite a bit lower than 35a certainly nowhere near 40a which is the recommended fuse for a 12v DC unit. Yeah, I have no idea where that 40A came from. I found some specs above showing max at 24V of 25A
Geo Posted December 7, 2016 Report Posted December 7, 2016 (edited) Yeah, I have no idea where that 40A came from. I found some specs above showing max at 24V of 25A It came I think you will find from the OP post #3. I would have thought you would have seen it. It needs a dedicated 40 amp supply, and I'm finding it difficult to find a converter that will supply that. Edited December 7, 2016 by Geo
fudd Posted December 7, 2016 Author Report Posted December 7, 2016 Yeah, I have no idea where that 40A came from. I found some specs above showing max at 24V of 25A That would be from me I'm afraid. Getting my 12 and 24 volts mixed up.
WotEver Posted December 7, 2016 Report Posted December 7, 2016 That would be from me I'm afraid. Getting my 12 and 24 volts mixed up. Ahh, ok. Makes sense
Geo Posted December 7, 2016 Report Posted December 7, 2016 The recommended fuse is 35a for a 24v DC unit so I suspect the draw will be quite a bit lower than 35a certainly nowhere near 40a which is the recommended fuse for a 12v DC unit. I would have thought a 30A supply should cope happily.
WotEver Posted December 7, 2016 Report Posted December 7, 2016 That would be from me I'm afraid. Getting my 12 and 24 volts mixed up.This converter should do: http://m.ebay.com/itm/12V-TO-24V-30A-STEP-UP-DC-DC-CONVERTER-30-AMP-720-Watt-H30-12-24-daygreen-/221701383136 $87 US delivered. He only has one. How far is the toilet from the batteries? Tony
fudd Posted December 7, 2016 Author Report Posted December 7, 2016 This converter should do: http://m.ebay.com/itm/12V-TO-24V-30A-STEP-UP-DC-DC-CONVERTER-30-AMP-720-Watt-H30-12-24-daygreen-/221701383136 $87 US delivered. He only has one. How far is the toilet from the batteries? Tony A run of about 3m'
Geo Posted December 7, 2016 Report Posted December 7, 2016 (edited) A run of about 3m' You will get away with 10mm2 for that run Edited December 7, 2016 by Geo
jddevel Posted December 10, 2016 Report Posted December 10, 2016 Having made a similar- I like to call it slight human error but others would call it a big stupid mistake -I have been following this topic with interest trying to avoid being beaten but at the same time not wishing to throw to much good money after bad!! My question is assuming a dedicated battery bank as local to the loo as possible what precautions are necessary to be both RCD compliant and more importantly safe for personal reasons, would standard battery boxes be O.K?
Keith M Posted December 10, 2016 Report Posted December 10, 2016 The batteries to be in a battery box The battery box may require external ventilation talk to the BSS office Fuse for the changing supply DC protection between the batteries and the toilet Keith
ditchcrawler Posted December 10, 2016 Report Posted December 10, 2016 The batteries to be in a battery box The battery box may require external ventilation talk to the BSS office Fuse for the changing supply DC protection between the batteries and the toilet Keith Do you think it would also require an Isolation switch? Having made a similar- I like to call it slight human error but others would call it a big stupid mistake -I have been following this topic with interest trying to avoid being beaten but at the same time not wishing to throw to much good money after bad!! My question is assuming a dedicated battery bank as local to the loo as possible what precautions are necessary to be both RCD compliant and more importantly safe for personal reasons, would standard battery boxes be O.K? Is this a new boat? I thought that was the only time the RCD came into play.
WotEver Posted December 10, 2016 Report Posted December 10, 2016 Do you think it would also require an Isolation switch Yep.
jddevel Posted December 10, 2016 Report Posted December 10, 2016 New boat. My sailaway. The only way I can both afford my dream and hopefully get what I want with all its idiosyncrasies. I love a challenge. Stupid me!!!
jddevel Posted December 10, 2016 Report Posted December 10, 2016 On the other hand it may be that a 12/24volt step up converter may be a easier way to go as a 12 volt tail already in place in the toilets location and according to the information available the maximum amps needed is 7.5amps with the what I`m led to believe is the quote "flushed motor locked rotor current (amps)" as displayed in the specification. I would add it is a vacuum toilet not a macerating one so I assume the motor loading is no where so great.
