Hi all, Finaly got our first boat, have been reading and watching the forum, thanks for all the brill topics and advice, now we feel very in the deep end, as we got the boat at the start of all this cold, but usual winter weather.
Would love to start our solid fuel stove, but should we clean the chimney first?
If so, how?
It's a chili penguin stove, and was fairly clean, just had to clear some ash and a little bit of burn on the glass, is there an easy way to check if the chimney is clear, or should we get a sweeper pro to do it?
Thanks for any advice, temptation to light is there, but also very aware of risks
all you need is a chimney sweeping brush to fit a max 4" flue.
Take the chimney off and look down the flue, you will be able to see if there is a large amount of build up in it, if you havn't a brush, a length of chain can be dropped down and rattled around to the same effect.
If you have a damper fitted at the base of the flue, make sure this is cleared (hand up top inside of stove) before you light the stove, then your chili penguin will be a toasty one.
https://www.amazon.co.uk/Hills-Brush-Flu5-Flue-Long/dp/B000TAW3VA/ref=pd_lpo_201_tr_t_3?ie=UTF8&psc=1&refRID=N7DPB5GAC02ZBX7JF721
Edited by matty40s
Agree with what matty 40s says - just remove the chimney, shine a torch down the flue and if it needs it brush it out.
Put the dustpan or a carrier bag in the fire to catch the soot.
Ask your neighbouring boaters if they have a brush to lend you.
Steve
Thats great, thanks, will try and get a brush, if not, have torch, chain or something similar, need to check damper, thanks for info, feel more confident now, will be getting on boat Friday after work, hope to be toasty before dark.
Thanks again
Marie
If the flue is straight to the top of the stove, a wire brush cable tied to a broom handle is a good tool for flue cleaning.
Doesn't work if there's bends, though
If you light the stove and the boat fills with smoke, you may need to sweep your chimney.
...or fit a taller one.
ha ha, yep, we do have all the alarms, and watched cruising the cut youtube a few times, so should be ok on the door closingunsure.png flue has two small kinks, so will need bendy rod for brush, on the shopping list. Thanks all
