Bee Posted June 20, 2016 Report Share Posted June 20, 2016 http://www.marktplaats.nl/a/watersport-en-boten/bootonderdelen/m1061960815-lister-petter-keerkoppeling.html Might help someone, postage could be dear though. Link to comment Share on other sites More sharing options...
RLWP Posted June 20, 2016 Report Share Posted June 20, 2016 I doubt it - that's a clutch, not a gearbox Richard Link to comment Share on other sites More sharing options...
Flyboy Posted June 20, 2016 Report Share Posted June 20, 2016 I doubt it - that's a clutch, not a gearbox Richard It looks like a gearbox to me. It's even described as a gearbox. Link to comment Share on other sites More sharing options...
RLWP Posted June 20, 2016 Report Share Posted June 20, 2016 It looks like a gearbox to me. It's even described as a gearbox. You are welcome to buy it and find out. It's a clutch no matter what it looks like It isn't the first time I have come across this misunderstanding Richard Link to comment Share on other sites More sharing options...
FadeToScarlet Posted June 20, 2016 Report Share Posted June 20, 2016 So is the clutch in the bellhousey bit on the right, and some form of reduction gearing on the left? Link to comment Share on other sites More sharing options...
RLWP Posted June 20, 2016 Report Share Posted June 20, 2016 So is the clutch in the bellhousey bit on the right, and some form of reduction gearing on the left? It is exactly that. If you compare it to an LM100, you'll find the 'gearbox' is completely different Richard Link to comment Share on other sites More sharing options...
bizzard Posted June 20, 2016 Report Share Posted June 20, 2016 And here it is. Link to comment Share on other sites More sharing options...
Bee Posted June 20, 2016 Author Report Share Posted June 20, 2016 Well I didn't know that. it looks like lots of old mechanical boxes, looks like it should just bolt on the engine and off you go. Link to comment Share on other sites More sharing options...
mayalld Posted June 20, 2016 Report Share Posted June 20, 2016 It is exactly that. If you compare it to an LM100, you'll find the 'gearbox' is completely different Richard So, STRICTLY SPEAKING; It does contain a gearbox (the 2:1 or 3:1 reduction box on the left of the picture) so it isn't falsely described, but the bit that would be useful if it were an LM100 reversing box is just a clutch without the reversing functionality of an LM100. Can Bizzard not create a contraption to make use of a non-reversing gearbox in a boat. Link to comment Share on other sites More sharing options...
bizzard Posted June 20, 2016 Report Share Posted June 20, 2016 So, STRICTLY SPEAKING; It does contain a gearbox (the 2:1 or 3:1 reduction box on the left of the picture) so it isn't falsely described, but the bit that would be useful if it were an LM100 reversing box is just a clutch without the reversing functionality of an LM100. Can Bizzard not create a contraption to make use of a non-reversing gearbox in a boat. They are fairly commonly used with sailing yacht auxiliary engines, in conjunction with variable pitch propellers, which blades can be reversed for going astern, also the prop blades can be feathered to reduce prop drag when sailing. They are also used in industrial applications for clutching in and out of things like generators and water pumps without stopping the engine. Link to comment Share on other sites More sharing options...
David Mack Posted June 20, 2016 Report Share Posted June 20, 2016 Well I didn't know that. it looks like lots of old mechanical boxes, looks like it should just bolt on the engine and off you go. Indeed you can go. You just can't stop. Link to comment Share on other sites More sharing options...
FadeToScarlet Posted June 20, 2016 Report Share Posted June 20, 2016 Indeed you can go. You just can't stop. Keep Calm and Strap In.... Link to comment Share on other sites More sharing options...
Taslim Posted June 20, 2016 Report Share Posted June 20, 2016 For use with a Kitchen rudder? Link to comment Share on other sites More sharing options...
Bee Posted June 21, 2016 Author Report Share Posted June 21, 2016 I think the idea of Bizzard being let loose on a big box of cogs and sprockets needs thinking through, I'm sure he would invent something but it might not be a gearbox, could be something to cut your toe nails and I, for one would not be the first to try it. Link to comment Share on other sites More sharing options...
bargemast Posted June 21, 2016 Report Share Posted June 21, 2016 Gearboxes like that were a common thing for anchorwinch motors, until the days that anchorwinches (and lots of other auxillary Equipment) became more and more electricly driven. Peter. Link to comment Share on other sites More sharing options...
