Benno 1688 Posted February 23, 2015 Report Share Posted February 23, 2015 hi all my 1800 bmc runs fine for about an hour then it starts to over heat I ran with the engine cover open and its blowing water out of the over fow pipe on the filling cap. It appears to have loads of air in the system, any ideas. Link to comment Share on other sites More sharing options...
bigste Posted February 23, 2015 Report Share Posted February 23, 2015 Sounds more like blown head gasket. Link to comment Share on other sites More sharing options...
Benno 1688 Posted February 23, 2015 Author Report Share Posted February 23, 2015 How would I know if it was the head gasket? Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 23, 2015 Report Share Posted February 23, 2015 By using a solution that you can buy on Ebay that detects exhaust gas. Assuming its a skin tank cooled boat have you bled the skin tank and manipulated the main coolant pipes to ensure no air is trapped in them? Link to comment Share on other sites More sharing options...
Benno 1688 Posted February 23, 2015 Author Report Share Posted February 23, 2015 I have opened the bleed tap until water is spraying out but i have not done the main pipes. Link to comment Share on other sites More sharing options...
Benno 1688 Posted February 23, 2015 Author Report Share Posted February 23, 2015 Does anyone know the name of the head gasket test fluid on ebay Link to comment Share on other sites More sharing options...
Puddlejumper Posted February 23, 2015 Report Share Posted February 23, 2015 Head gasket gone!!? Link to comment Share on other sites More sharing options...
alan_fincher Posted February 23, 2015 Report Share Posted February 23, 2015 Firstly you are not over-filling it, are you? If the Bowman is the only header tank you have, (i.e. there is no external header tank), then it has to accommodate all the expansion of the water as the engine heats up, which, depending on skin tank dimensions, could be a lot. It is normal to start off cold with the level maybe about an inch below the neck of the cap, otherwise expansion will often force water out as the engine heats. Secondly how big is your skin tank, (length, height and "thickness"). this will affect both how well it is able to cool the engine, but also how much water is actually in the whole system that needs to expand. Thirdly, is this water expulsion only whilst the engine is being worked hard, or does it still happen if the engine runs only on idle or low load? Finally who built the boat, as there are some builders who are known to have produced boats with inadequate skin tanks, (but please don't ask me how I know this!). Does anyone know the name of the head gasket test fluid on ebay You would be after something like this. (I'm not recommending this one - just an example - the first one that I found). Another search term to try is "Block Tester Kit" Example here Link to comment Share on other sites More sharing options...
Benno 1688 Posted February 24, 2015 Author Report Share Posted February 24, 2015 (edited) Hi Alanits a springer and yes it is when the engine is worked hard, There is also a calorifer attached does that make anydifferance.Just a thought would the thermostate not working properly cause the same issue. Edited February 24, 2015 by Benno 1688 Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 24, 2015 Report Share Posted February 24, 2015 If it takes an hour to bring the calorifier up to temperature then yes, it could be a thermostats stuck shut, especially if it has been subject to excess temperature. It would be worth a check but I thought it less likely because of the time it takes to overheat. Link to comment Share on other sites More sharing options...
MtB Posted February 24, 2015 Report Share Posted February 24, 2015 The one hour delay makes me think it isn't a head gasket failure either. I'd expect the problem to be present all the time if cylinder compression was leaking into the cooling system. MtB hi all my 1800 bmc runs fine for about an hour then it starts to over heat I ran with the engine cover open and its blowing water out of the over fow pipe on the filling cap. It appears to have loads of air in the system, any ideas. Is this an assumption based on the cooling water being ejected, or is there a temperature gauge telling you this? What goes the gauge read when the problem begins? MtB Link to comment Share on other sites More sharing options...
Benno 1688 Posted February 24, 2015 Author Report Share Posted February 24, 2015 (edited) The tempreture gauge hits red, im thinking the best place to start is a new thermostat and a new filler cap.what do you think Edited February 24, 2015 by Benno 1688 Link to comment Share on other sites More sharing options...
Theo Posted March 1, 2015 Report Share Posted March 1, 2015 Sounds like the best idea. Let us know how you get on. Nick Link to comment Share on other sites More sharing options...
matty40s Posted March 1, 2015 Report Share Posted March 1, 2015 As Tony says above, check all pipes and skin tank, bleed and bleed again until you have got rid of any air. Air trapped will lead to your symptoms in the time scale.. Link to comment Share on other sites More sharing options...
Benno 1688 Posted March 3, 2015 Author Report Share Posted March 3, 2015 Hi thanks for all your comments ive put in a new thermostat and a new pressure cap, and bled it all I manipulated the pipes as suggested and it all seems fine now. Thanks again. Link to comment Share on other sites More sharing options...
