RLWP Posted January 5, 2015 Report Share Posted January 5, 2015 (edited) Fittie's plate: Richard Edited January 5, 2015 by RLWP Link to comment Share on other sites More sharing options...
Laurence Hogg Posted January 5, 2015 Report Share Posted January 5, 2015 That's spot on, exactly like the one we had as a pattern. Link to comment Share on other sites More sharing options...
pete harrison Posted January 5, 2015 Report Share Posted January 5, 2015 Lancing's has the yard number and the year The actual completion / handover date was 22 July 1936 according to both W.J. Yarwood & Sons Ltd. and Grand Union Canal Carrying Company Ltd. records Link to comment Share on other sites More sharing options...
Timleech Posted January 5, 2015 Report Share Posted January 5, 2015 Period photographs suggest the Yarwood builders plates on the two pairs of 'Admirals' were about 5'' by 3'', and as you say were fitted to the rear cabin bulkhead. I am sure the Yarwood builders plates fitted to G.U.C.C.Co. Ltd. boats were a little smaller. The Pimblott built 'Admirals' had a builders plate in a similar location, but these were a little larger and oval in shape - and again featured the relevant 'Yard Number' under which the boat was built. I am mystified by the oval Harland & Wolff Ltd. plates (as you found in THEMIS) as I have never seen one in a period photograph, and they are very rarely seen now The THEMIS was, allegedly, the very first composite Small Woolwich motor, maybe it or the first few boats had them fitted to 'show off', & they didn't bother after a while? I have no reason to suppose that the plate on the VENUS was not original. Tim Link to comment Share on other sites More sharing options...
pete harrison Posted January 5, 2015 Report Share Posted January 5, 2015 The THEMIS was, allegedly, the very first composite Small Woolwich motor, maybe it or the first few boats had them fitted to 'show off', & they didn't bother after a while? I have no reason to suppose that the plate on the VENUS was not original. Tim HYPERION and HYADES were the first to be delivered on 15 May 1935, with THEMIS and TITANIA delivered 3 days later. THEMIS and TITANIA usually appear first in period documents of both Harland & Wolff Ltd. and the Grand Union Canal Carrying Company Ltd., and this pair also have the lowest Harland & Wolff Ltd. 'Yard Numbers' of the iron composite small Woolwich's - followed directly by HYPERION and HYADES . Link to comment Share on other sites More sharing options...
Laurence Hogg Posted January 5, 2015 Report Share Posted January 5, 2015 Here we have two photographs taken at the same time showing "Hyperion" being launched and "Themis" being craned onto the launch trolley. Neither shows any sign of a builders plate. Link to comment Share on other sites More sharing options...
Timleech Posted January 5, 2015 Report Share Posted January 5, 2015 (edited) Here we have two photographs taken at the same time showing "Hyperion" being launched and "Themis" being craned onto the launch trolley. Neither shows any sign of a builders plate. Indeed, but it's only a question of two bolts to fit them, could easily have been done after launching. This one of the THEMIS' launch shows it as more complete, with chimney, funnel, cratch more complete etc., as though they were trying to show that it was ready to go off immediately to fetch a load. Tim Edited January 5, 2015 by Timleech Link to comment Share on other sites More sharing options...
Paul H Posted January 5, 2015 Report Share Posted January 5, 2015 Thats because (as I said previously) because the plates were probably originally fixed on the bulkhead at the front of the hold and would be hidden under the cratch. Paul Link to comment Share on other sites More sharing options...
madcat Posted January 5, 2015 Report Share Posted January 5, 2015 Possibly x 2 but not if they are too expensive . GU style cast brackets for the bevel gears on the gear control maybe? Link to comment Share on other sites More sharing options...
Mick Poyser Posted January 5, 2015 Report Share Posted January 5, 2015 As this topic is supposed to be about Yarwood plates I'm going to go off topic by talking about H & W plates on my very first post. Cassiopeia has her original back end bulkhead and just below the rail is an oval area of very deep corrosion which is the exact size of the Fuller replacement plate. The corrosion is not central (of set by about 2") so the original plate was very crudely fitted. In fact I could not fit the Fuller Plate in the same place (it just looked wrong) so some corrosion is still visible. Both Jim and Eddy Hambridge tell me they cannot remember a plate, so it had probable fell of before the early 1950s. In fact looking at the depth of pits in the bulkhead it probable went with a large bang. Link to comment Share on other sites More sharing options...
Derek R. Posted January 6, 2015 Report Share Posted January 6, 2015 (edited) . . at Stretton Aquaduct (Nr. Brewood) I like that. I think I might know where that is now. Welcome Mick. I wouldn't consider your comment as off topic - I think we are talking plates in general, though perhaps more specifically GU boat plates, but it's a broad subject. PS I do wonder if such plates were fitted if time and circumstances allowed. They were a trade mark, but when pressed to build fast such plates might well have been the last - and possibly forgotten additions. Edited January 6, 2015 by Derek R. Link to comment Share on other sites More sharing options...
Timleech Posted January 6, 2015 Report Share Posted January 6, 2015 Another factor which might explain the scarcity of these H&W plates is the fact that the front bulkheads were altered after building. The original design allowed for engines to be removed for major overhaul through the bulkhead, the bolted panels can clearly be seen in the launch photos of THEMIS and HYPERION. It was found in service that lifting through the roof was more practical (Imagine removing a blown engine through the bulkhead of a fully loaded boat), and I believe that the bulkheads were rivetted closed. I don't know any detail of how this was done, or whether all the Small Woolwich motor boats left the builders with bolted bulkhead panels, but it is quite conceivable that builders plates got lost somewhere during the changes. Tim Link to comment Share on other sites More sharing options...
Derek R. Posted January 6, 2015 Report Share Posted January 6, 2015 Certainly TYCHO had bolted lower sections to the forward bulkhead, and I'm also reliably told it was for engine replacements - Russel Newbury 2DM would come out that way, though the Petter replacement certainly wouldn't! Off with it's top. Still bolts in the bulkhead though. Link to comment Share on other sites More sharing options...
fittie Posted January 6, 2015 Author Report Share Posted January 6, 2015 (edited) There is a good image which, I believe, shows the makers plate on the engine room bulkhead. http://www.associatedcanalcarriers.co.uk/wordpress/ ps Thanks for posting the image of my plate Edited January 6, 2015 by fittie Link to comment Share on other sites More sharing options...
RLWP Posted January 6, 2015 Report Share Posted January 6, 2015 No problem. Richard Link to comment Share on other sites More sharing options...
fittie Posted January 6, 2015 Author Report Share Posted January 6, 2015 Thanks Richard, that's the one! Link to comment Share on other sites More sharing options...
RLWP Posted January 6, 2015 Report Share Posted January 6, 2015 That cabin looks really short! Richard Link to comment Share on other sites More sharing options...
fittie Posted January 6, 2015 Author Report Share Posted January 6, 2015 The engine room looks huge, well long. Link to comment Share on other sites More sharing options...
RLWP Posted January 6, 2015 Report Share Posted January 6, 2015 It was the height of the sides that looks odd to me I don't think I have seen that hinged tiller before either All this does is tell you how little I know about these boats Richard Link to comment Share on other sites More sharing options...
IanM Posted January 6, 2015 Report Share Posted January 6, 2015 It was the height of the sides that looks odd to me I don't think I have seen that hinged tiller before either All this does is tell you how little I know about these boats Richard Because the hull sides are so deep the cabin doesn't need to be as high. Link to comment Share on other sites More sharing options...
Mick Poyser Posted January 6, 2015 Report Share Posted January 6, 2015 Can somebody tell me how you do the cutting and pasting bit when you want to highlight what somebody else has said so you can comment on it? I don't think the photos of Hyperion and Themis are showing engine removal panels, I think what you see is the two rows of rivets fixing the bulkhead to the internal framing. The engine removal panel only extends a few inches above the gunnel. Cassiopeia's panel is riveted in not bolted, therefore, I think it's a GU fitter's thing not original design. Stage one how the f--- do we get the engine out. Stage two why are we riveting these panel back when we could bolt them. The roof off job came later when BTW had their engine replacement program. Going back to the builders plates they may have beed suppled loose with other bits such as engine spares & spanners etc (in them days new engines came with spares & spanners) and it may have been up to the GU fitter doing final adjustments etc, of where and how or if they where fitted on to the craft. I can also see the H&W stores-man when requesting a re-order of the plates being told they're to expensive, no more. I do believe they were only fitted to Iron craft. Link to comment Share on other sites More sharing options...
RLWP Posted January 6, 2015 Report Share Posted January 6, 2015 First off, use the Quote button to put their text into your post. Now you have some options. You could highlight the bit of text you want to highlight and change the text colour, or you could delete the bits you don't want. Be careful not to delete the header and fitter though as everything goes weird Simplest option is to copy and paste the bit you want and put quote marks at each end Does that help? Richard Link to comment Share on other sites More sharing options...
Timleech Posted January 6, 2015 Report Share Posted January 6, 2015 Can somebody tell me how you do the cutting and pasting bit when you want to highlight what somebody else has said so you can comment on it? I don't think the photos of Hyperion and Themis are showing engine removal panels, I think what you see is the two rows of rivets fixing the bulkhead to the internal framing. The engine removal panel only extends a few inches above the gunnel. Cassiopeia's panel is riveted in not bolted, therefore, I think it's a GU fitter's thing not original design. Stage one how the f--- do we get the engine out. Stage two why are we riveting these panel back when we could bolt them. The roof off job came later when BTW had their engine replacement program. Going back to the builders plates they may have beed suppled loose with other bits such as engine spares & spanners etc (in them days new engines came with spares & spanners) and it may have been up to the GU fitter doing final adjustments etc, of where and how or if they where fitted on to the craft. I can also see the H&W stores-man when requesting a re-order of the plates being told they're to expensive, no more. I do believe they were only fitted to Iron craft. I have read/been told more than once that a removable panel was part of the original design, it would be logical if it were, but that doesn't mean it's true and I don't know the details. Impossible to be sure from the pic I scanned, but those 'rivets' look too prominent to me. Looking at a Small Woolwich which is here at present, the front bulkhead has been chopped around too many times to establish anything except that the National would not come out through just the lower part of the bulkhead, without stripping parts from the top of the engine first. Tim Link to comment Share on other sites More sharing options...
Derek R. Posted January 6, 2015 Report Share Posted January 6, 2015 I know there are subtle differences between Woolwich and Northwich builds, but TYCHO's forward engine room bulkhead is pretty original. The Bolts do go all the way from bottom to top, but in the main are holding the internal angle in place. The removable section stops short half way between gunnel and cabin top. Link to comment Share on other sites More sharing options...
fittie Posted January 6, 2015 Author Report Share Posted January 6, 2015 Can somebody tell me how you do the cutting and pasting bit when you want to highlight what somebody else has said so you can comment on it? I don't think the photos of Hyperion and Themis are showing engine removal panels, I think what you see is the two rows of rivets fixing the bulkhead to the internal framing. The engine removal panel only extends a few inches above the gunnel. Cassiopeia's panel is riveted in not bolted, therefore, I think it's a GU fitter's thing not original design. Stage one how the f--- do we get the engine out. Stage two why are we riveting these panel back when we could bolt them. The roof off job came later when BTW had their engine replacement program. Going back to the builders plates they may have beed suppled loose with other bits such as engine spares & spanners etc (in them days new engines came with spares & spanners) and it may have been up to the GU fitter doing final adjustments etc, of where and how or if they where fitted on to the craft. I can also see the H&W stores-man when requesting a re-order of the plates being told they're to expensive, no more. I do believe they were only fitted to Iron craft. Venus was wooden and she did have a makers plate. Link to comment Share on other sites More sharing options...
