FidoDido Posted July 17, 2013 Author Report Share Posted July 17, 2013 Some Americans on a hire boat have just moored opposite the tree.... Despite me telling the the branch could fall at any time, and the fact that its a private mooring. Now waiting for the Darwin effect to come into play.... Link to comment Share on other sites More sharing options...
Paul C Posted July 17, 2013 Report Share Posted July 17, 2013 Can you get access to the offside (non towpath side) (I'm assuming you're moored on towpath side). Link to comment Share on other sites More sharing options...
FidoDido Posted July 17, 2013 Author Report Share Posted July 17, 2013 Farmers field. Looks like it will be tricky to clear. Suspect navigation will be closed for at least a day. Link to comment Share on other sites More sharing options...
billS Posted July 17, 2013 Report Share Posted July 17, 2013 How many tethered chinese laterns would it take - I wonder? Bizzard? Link to comment Share on other sites More sharing options...
Paul C Posted July 17, 2013 Report Share Posted July 17, 2013 Farmers field. Looks like it will be tricky to clear. Suspect navigation will be closed for at least a day. No worries, without reasonable access and a tree (or possibly a friendly farmer with a tractor) my idea isn't possible, so I shan't suggest it. Did CRT say they'll be able to increase the water level, and a timescale? Otherwise, you're into extra equipment, access to that offside, etc etc Link to comment Share on other sites More sharing options...
FidoDido Posted July 17, 2013 Author Report Share Posted July 17, 2013 Guess they are assuming the Trent will eventually fill it. Still good 6 inches down. The level by the tree is about 2 inches currently. Winds picking up, so I suspect it will come down by itself overnight and pin the hire boaters to the bank Link to comment Share on other sites More sharing options...
FidoDido Posted July 17, 2013 Author Report Share Posted July 17, 2013 Canadian hire boaters have seen sense and moved, thank goodness.. Canal rising slowly. Ale going down at a slightly faster rate Link to comment Share on other sites More sharing options...
Mrs Trackman Posted July 17, 2013 Report Share Posted July 17, 2013 Vandals apparently.. Had opened Weston, Aston and Shardlow locks. Did first two Monday, then Shardlow last night. Took 6 hours to refill. Now there is a tree branch waiting to fall and close the cut.. Err...Vandals? Must have taken a lot of dedication to travel from Weston to Aston unless by boat. http://twitter.com/robstockman/status/357513084878848002/photo/1 C&RT refused to close navigation, so spent the afternoon putting some signs up to warn people. Would kill if it fell on you. Contractors coming tomorrow to cut it down. Happened 10 mins after I got back from Dobsons. Heard a huge crack, go outside, and am amazed it didn't go all the way. It's resting on a thin branch at the mo. next gust of wind and it will come down. Link to comment Share on other sites More sharing options...
FidoDido Posted July 17, 2013 Author Report Share Posted July 17, 2013 May have been careless boaters.. True. C&RT suggested vandals. Whomever, I hope they don't do it again! Link to comment Share on other sites More sharing options...
Doorman Posted July 18, 2013 Report Share Posted July 18, 2013 Canadian hire boaters have seen sense and moved Thought you said that they were from Americky? Link to comment Share on other sites More sharing options...
Mrs Trackman Posted July 18, 2013 Report Share Posted July 18, 2013 Not quite sure where you are but think you are on pound between Aston and Shardlow locks in which case vandalism at Aston or Weston locks would have tended to mean there was an excess of water where you are not a lowering of levels. However, hope all getting sorted and you are afloat again. It is most disconcerting being stuck. Link to comment Share on other sites More sharing options...
FidoDido Posted July 18, 2013 Author Report Share Posted July 18, 2013 Thought you said that they were from Americky? Turned out they were Canadian.. some other folks corrected me later in the day. Mrs Trackman - pound above Aston was empty from what CaRT bloke said. Had to pull water down from Swarkestone. Your suggestion of careless boaters would fit with all the above. Lots of Canaltime / Hire-a-canal-boat traffic, so might be inexperienced folk inadvertantly doing it. Only takes one to forget to close paddles each lock, and there you go. Shardlow lock is so leaky, without a feed from the pound above, it might drop the cut by a foot over a 24 hour period I suppose. Thats alot of water though.. The it does leak badly - both sets of gates. And Trent is VERY low, so probably not much feed from further up. Link to comment Share on other sites More sharing options...
KJT Posted July 18, 2013 Report Share Posted July 18, 2013 Fido, Are you still aground? We are at the bottom of the Erewash at Trent Lock, planning to head up your way tomorrow through Shardlow. Is traffic still passing through or are levels too low? Do you need a hand to pull you off the putty? Ken Link to comment Share on other sites More sharing options...
bizzard Posted July 18, 2013 Report Share Posted July 18, 2013 How many tethered chinese laterns would it take - I wonder? Bizzard? Eco-fan plonked on the hot roof aimed upwards will lift it off the mud like a big Helicopter. Link to comment Share on other sites More sharing options...
FidoDido Posted July 18, 2013 Author Report Share Posted July 18, 2013 Fido, Are you still aground? We are at the bottom of the Erewash at Trent Lock, planning to head up your way tomorrow through Shardlow. Is traffic still passing through or are levels too low? Do you need a hand to pull you off the putty? Ken It was filled yesterday. Fine this morning. However, dangerous tree branch hanging over canal may stop play if and when contractors come to remove it. I'll let you know update later. No sign of any contractors this morning at 8.30 when I went to work. Link to comment Share on other sites More sharing options...
alan_fincher Posted July 18, 2013 Report Share Posted July 18, 2013 (edited) Fido, Are you still aground? We are at the bottom of the Erewash at Trent Lock, planning to head up your way tomorrow through Shardlow. Is traffic still passing through or are levels too low? Do you need a hand to pull you off the putty? Ken Funny you mentioned Shardlow. Yet another stoppage notice just turned up! Shardlow Lock 2 and Aston Lock 3 Thursday 18 July 2013 until further notice Due to a dangerous tree which has a bees nest inside, navigation will be closed from 5.00pm today the 18th July to remove the bees nest first then attend to the tree. It is anticipated that this work will be finished by lunchtime tomorrow the 19th July. Canal & River Trust apologise for any inconvenience this may cause. Enquiries: 0303 040 4040 during normal office hours. Edited July 18, 2013 by alan_fincher Link to comment Share on other sites More sharing options...
deckhand Posted July 18, 2013 Report Share Posted July 18, 2013 It was filled yesterday. Fine this morning. However, dangerous tree branch hanging over canal may stop play if and when contractors come to remove it. I'll let you know update later. No sign of any contractors this morning at 8.30 when I went to work. CRT Customer Service @CRTContactUs 2h Trent & Mersey, Shardlow Lock 2 and Aston Lock 3, Navigation closed from 5pm until lunch tomorrow to remove a beehive and dangerous tree. Is this your favourite tree? This was on twitter 2 hours ago Link to comment Share on other sites More sharing options...
KJT Posted July 18, 2013 Report Share Posted July 18, 2013 Funny you mentioned Shardlow. Yet another stoppage notice just turned up! Thanks Alan. We will have a very leisurely start tomorrow and by the time we get up there it should be open again. Bees permitting! Ken Link to comment Share on other sites More sharing options...
FidoDido Posted July 18, 2013 Author Report Share Posted July 18, 2013 Yup.. Sign up on locks now. Pic of tree on one of my earlier posts. Looks like more than a couple of hours job to me, but then with a lot of contractors could be. Link to comment Share on other sites More sharing options...
