Patrick Vale Posted July 7, 2013 Report Posted July 7, 2013 Hi everyone, I'm in the process of re-fitting and have moved some things around like the kitchen, which previously had skin-fittings, but now have them somewhere else. My question is -what to do about the existing fittings/holes? A chap at midland chandlers suggested making a cork plug, which I guess would work (swell up if it got wet) but I wondered if there wasn't another way to do it. I googled for 'skin fitting blank', but no-one popped up with the 'perfect product'. Help?! Thanks! Patrick
Higgs Posted July 7, 2013 Report Posted July 7, 2013 Hi everyone, I'm in the process of re-fitting and have moved some things around like the kitchen, which previously had skin-fittings, but now have them somewhere else. My question is -what to do about the existing fittings/holes? A chap at midland chandlers suggested making a cork plug, which I guess would work (swell up if it got wet) but I wondered if there wasn't another way to do it. I googled for 'skin fitting blank', but no-one popped up with the 'perfect product'. Help?! Thanks! Patrick Don't think I'd go with the cork job. Another method would be to have a disk welded into place.
Ray T Posted July 7, 2013 Report Posted July 7, 2013 Tap the hole, and screw in a suitable bolt with lashings of Boss White and or PTFE tape. File down bolt head so it is not too obtrusive.
Guest Posted July 7, 2013 Report Posted July 7, 2013 Get something like a fake rivet made with a hole through it. Countersink hole and put a counresunk bolt through to another drilled plate on the inside. Nut on and job done. I agree welding is better if you can power up a welding set.
larkshall Posted July 7, 2013 Report Posted July 7, 2013 I have made up a disk the same size as te aperture and welded it in place, then coated it in black. Had to do this one many occassions. Think yourself lucky its not a plastic boat !
bizzard Posted July 7, 2013 Report Posted July 7, 2013 Easier to do on a plastic boat. No electricity or welding skills required either.
larkshall Posted July 7, 2013 Report Posted July 7, 2013 Easier to do on a plastic boat. No electricity or welding skills required either. LOL, I was thinking of invisible repairs to the Gel coat.
GUMPY Posted July 7, 2013 Report Posted July 7, 2013 if the fittings are still in place, cut off the hose tail, if fitted, then screw on a bsp end cap of the same thread as the fitting.
blackrose Posted July 7, 2013 Report Posted July 7, 2013 (edited) A chap at midland chandlers suggested making a cork plug, which I guess would work (swell up if it got wet) That's what I did - but I used a plastic wine cork, pushed in with plenty of Marineflex. I wouldn't use natural cork in case it disintegrated over time. Edited July 7, 2013 by blackrose
DHutch Posted July 7, 2013 Report Posted July 7, 2013 You could probably do a lot worse the just capping it off, filling it with cork, etc. Its not going to be a huge hole, its been there yonks, and if its suitable above the water line would not cause me much upset. That said, as a long term job or if you can get someone to do it now, I would be aiming weld it up and grid it off flush on the outside, which is what I did with the deck drains i removed from our boat. Daniel
blackrose Posted July 7, 2013 Report Posted July 7, 2013 Yes, depends on how close it is to the waterline. If it was close I'd want a plate welded over the hole.
smileypete Posted July 7, 2013 Report Posted July 7, 2013 (edited) Threaded cap on the inside ideally then fill with cement maybe, smooth off and paint with favourite blacking goo once set. cheers, Pete. ~smpt~ Edited July 7, 2013 by smileypete
