NBMike Posted August 18, 2009 Report Share Posted August 18, 2009 Can anyone point me in the direction of a supplier for a 170 or 180mm, 6 groove pulley for PK type belt. Taperlock type or otherwise and hopefully I can machine it to suit. Mike Link to comment Share on other sites More sharing options...
soldthehouse Posted August 18, 2009 Report Share Posted August 18, 2009 Can anyone point me in the direction of a supplier for a 170 or 180mm, 6 groove pulley for PK type belt. Taperlock type or otherwise and hopefully I can machine it to suit.Mike Medwaypt.co.uk Link to comment Share on other sites More sharing options...
dove Posted August 19, 2009 Report Share Posted August 19, 2009 I get all mine from here http://www.fptgroup.com/fenner.asp?title=P...amp;pageid=2655 They're nation wide. Andrew Link to comment Share on other sites More sharing options...
Timleech Posted August 19, 2009 Report Share Posted August 19, 2009 I get all mine from here http://www.fptgroup.com/fenner.asp?title=P...amp;pageid=2655 They're nation wide. Andrew You'll find their trade counters are called ERIKS now, though. Tim Link to comment Share on other sites More sharing options...
NBMike Posted August 19, 2009 Author Report Share Posted August 19, 2009 Medwaypt.co.uk Yes they do the belts but not the pulleys. Thanks anyway I get all mine from here http://www.fptgroup.com/fenner.asp?title=P...amp;pageid=2655 They're nation wide. Andrew Same with them - Loads of belts but not the right pulleys. You'll find their trade counters are called ERIKS now, though. Tim I'll do a search for ERIKS then thanks Tim Link to comment Share on other sites More sharing options...
soldthehouse Posted August 19, 2009 Report Share Posted August 19, 2009 Yes they do the belts but not the pulleys. Thanks anyway Same with them - Loads of belts but not the right pulleys. I'll do a search for ERIKS then thanks Tim Its a long shot but stationaryengineparts.co.uk were advertising such a thing but a quick look didnt currently show anything like it anymore, maybe worth a phone call though ,old stock etc etc Link to comment Share on other sites More sharing options...
dove Posted August 20, 2009 Report Share Posted August 20, 2009 Yes they do the belts but not the pulleys. Thanks anyway Same with them - Loads of belts but not the right pulleys. I'll do a search for ERIKS then thanks Tim If you go to Eriks you get Fenner, same place. PJ, PL, PM are listed in the cataloque but PK only gets a mention on page 84. I should ring up and ask Andrew Link to comment Share on other sites More sharing options...
Timleech Posted August 20, 2009 Report Share Posted August 20, 2009 If you go to Eriks you get Fenner, same place. PJ, PL, PM are listed in the cataloque but PK only gets a mention on page 84. I should ring up and ask Andrew My point was that you won't find Fenner trade counters in the phone book these days. The Fenner name seems to be used by a variety of companies these days as different parts of the business have been hived off. Eriks seem to get a lot of their polyvee stuff from Gates or other makers now, the fact that it's in the catalogue doesn't mean that it's readily available. Maybe K is a vehicle size, sometimes they're not readily available through transmission houses. Tim Link to comment Share on other sites More sharing options...
Chris Pink Posted August 20, 2009 Report Share Posted August 20, 2009 Can anyone point me in the direction of a supplier for a 170 or 180mm, 6 groove pulley for PK type belt. Taperlock type or otherwise and hopefully I can machine it to suit.Mike have you tried bearingboys.co.uk? Link to comment Share on other sites More sharing options...
NBMike Posted August 20, 2009 Author Report Share Posted August 20, 2009 (edited) Yes K is a vehicle size. Mike have you tried bearingboys.co.uk? No good Chris I think I'll have a look at the breakers yard Edited August 20, 2009 by NBMike Link to comment Share on other sites More sharing options...
dove Posted August 20, 2009 Report Share Posted August 20, 2009 Yes K is a vehicle size. That explains that, then. Andrew Link to comment Share on other sites More sharing options...
NBMike Posted August 20, 2009 Author Report Share Posted August 20, 2009 That explains that, then. Andrew Yes but -still- someone must make them or have a load of 'em in a warehouse somewhere, shirley! Link to comment Share on other sites More sharing options...
Timleech Posted August 20, 2009 Report Share Posted August 20, 2009 Can anyone point me in the direction of a supplier for a 170 or 180mm, 6 groove pulley for PK type belt. Taperlock type or otherwise and hopefully I can machine it to suit.Mike Have you considered making one from scratch? they're not hard to do if you don't need the taperlock feature. If you don't fancy it, there must be thousands of places which could do it for you. If you're stuck I could do it, but carriage would bump the cost up a bit. You should be able to find the specs on the web, if not let me know & I'll scan & email them to you. Tim Link to comment Share on other sites More sharing options...
Proper Job Posted August 20, 2009 Report Share Posted August 20, 2009 If you go to Eriks you get Fenner, same place. PJ, PL, PM are listed in the cataloque but PK only gets a mention on page 84. I should ring up and ask Andrew I'm listed in a catalogue! Link to comment Share on other sites More sharing options...
RLWP Posted August 20, 2009 Report Share Posted August 20, 2009 I'm listed in a catalogue! Yes, under Nuts. Richard Link to comment Share on other sites More sharing options...
nb Innisfree Posted August 20, 2009 Report Share Posted August 20, 2009 Yes K is a vehicle size. Mike No good Chris I think I'll have a look at the breakers yard Sound better and more fun Link to comment Share on other sites More sharing options...
paulcatchpole Posted August 20, 2009 Report Share Posted August 20, 2009 I'm listed in a catalogue! Yerrss, so am I, in too many places... ...but those new Microsoft TV adverts are the worst. I think they'll find *I'm* the PC. PC Link to comment Share on other sites More sharing options...
NBMike Posted August 20, 2009 Author Report Share Posted August 20, 2009 Have you considered making one from scratch? they're not hard to do if you don't need the taperlock feature. If you don't fancy it, there must be thousands of places which could do it for you. If you're stuck I could do it, but carriage would bump the cost up a bit. You should be able to find the specs on the web, if not let me know & I'll scan & email them to you. Tim Hmmm - I wonder if my machining skills are up to it. I've only done 2 terms of evening class. I might have a go though if I can't find one in the breakers at the weekend. I have a small 53mm pulley for the alternator so can take some measurements from that. Thanks Tim Yerrss, so am I, in too many places... ...but those new Microsoft TV adverts are the worst. I think they'll find *I'm* the PC. PC Ha - that advert was just on in the middle of X Files Link to comment Share on other sites More sharing options...
Boatgypsy Posted August 22, 2009 Report Share Posted August 22, 2009 I've just been through the same process as yourself. I found a flywheel off an old Petter stationary engine which just needed some trimming to the hole and the V's cutting. I was in luck in that my dad has a lathe and used to be a tool maker, so did the work. But you should be able to get it sorted at your local precision engineers for not too much cash. Link to comment Share on other sites More sharing options...
NBMike Posted August 23, 2009 Author Report Share Posted August 23, 2009 I've just been through the same process as yourself. I found a flywheel off an old Petter stationary engine which just needed some trimming to the hole and the V's cutting. I was in luck in that my dad has a lathe and used to be a tool maker, so did the work. But you should be able to get it sorted at your local precision engineers for not too much cash. Thats exactly what I started with - an old Petter stationary engine. But I need the flywheel at t'other end. Link to comment Share on other sites More sharing options...
