system 4-50 Posted December 13, 2019 Report Share Posted December 13, 2019 Pushfit Tips: Mark the pipe off at the inserted length so that you know for certain when you have got it fully home, before you fit the pipe into to joint. Saves lots of "is it in??" afterwards. Count out the inserts before you start so that when you've finished you can be certain the right number have been used! 1 Link to comment Share on other sites More sharing options...
David Mack Posted December 13, 2019 Report Share Posted December 13, 2019 1 minute ago, system 4-50 said: Count out the inserts before you start so that when you've finished you can be certain the right number have been used! But if there's an insert left over, you might have to undo several joints to find out where it should have been! Link to comment Share on other sites More sharing options...
system 4-50 Posted December 13, 2019 Report Share Posted December 13, 2019 Just now, David Mack said: But if there's an insert left over, you might have to undo several joints to find out where it should have been! There is no "But" about it. If there's an insert left over, you might have to undo several joints to find out where it should have been! Link to comment Share on other sites More sharing options...
robtheplod Posted December 13, 2019 Author Report Share Posted December 13, 2019 I'm going to see if I can identify the pipes further, maybe they have something on which I can identify the version.... Link to comment Share on other sites More sharing options...
blackrose Posted December 13, 2019 Report Share Posted December 13, 2019 1 hour ago, Jen-in-Wellies said: IT is why I said chances are you won't need them. Not 100%. I didn't recommend not using them. I just said your chances of a leak without are low. In the OP's case, where he was mixing a pipe from one manufacturer with a fitting from another in a cold water feed, where of the two joints, one side is unpressurised, this is not a risky thing to do. I had never tried using speedfit ferrules on Hep2o pipe, so couldn't say if it would work or not. You have, so could. Jen Ok, but I'd always use ferrules in plastic push-fit pipes, no exceptions. These things cost pennies so there's really no point not using them. 1 hour ago, Bod said: Pipe manufactures, make inserts for a reason. Plastic pipe, now has such a weak wall, compared to copper, especially when warm, that extra support is needed, where the pipe could be under stress, due a combination of internal pressure pushing a joint apart, and external pressure of the joint trying to grip the pipe. If the pipe manufacture, recommends inserts, then it's foolish not to fit them! Bod Agreed Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 13, 2019 Report Share Posted December 13, 2019 39 minutes ago, robtheplod said: I'm going to see if I can identify the pipes further, maybe they have something on which I can identify the version.... The make of pump is irrelevant they are all made to 15mm external diameter just like copper pipe Link to comment Share on other sites More sharing options...
Chewbacka Posted December 13, 2019 Report Share Posted December 13, 2019 7 hours ago, system 4-50 said: There is no "But" about it. If there's an insert left over, you might have to undo several joints to find out where it should have been! “Where it should have been“, or in my case “To learn your counting skills need improvement”...... 2 Link to comment Share on other sites More sharing options...
