Everything posted by Onewheeler
What to paint the roof with?
Onewheeler replied to cairanvanrooyen's topic in Boat Building & Maintenance
No idea, but they're helpful, cheap and the paint is top quality. In comparison, Toplac is like a gold-plated pot of pi**. -
I've just done our roof with Black Country Paints paint. Much cheaper than Toplac, much more pigment and available in all RAL colours matt, semi gloss and gloss. They're also nice people to deal with. -
There aren't many places that you can't turn a 18 m boat, and even fewer where you can't turn within five minutes of cruising. You can tie up pretty much anywhere on the towpath side other than near bridges and where the bank makes it difficult. There may be some local restrictions due to water voles. It is a lovely and unique waterway. Hope you get to Sharpness, a walk around the old dock and around the riverbank is always interesting.
Water Leak !! Bugger.......
Onewheeler replied to NewCanalBoy's topic in Boat Building & Maintenance
No one seems to have asked yet if the front deck drains into the bilge. Not unknown and it might explain the presence of a bilge pump. It might be regarded as slightly unusual to have one in the main cabin bilge. -
If (and only if) the hull and engine are not too bad it looks good value. The seller quotes three different BSS dates, all soon, could be worth an offer subject to survey and new BSS. The cosmetics can be done as and when you please. The external paint job looks passable. I'd get rid of the toilet and keep the porta-potti. OVMD!
Stern gland? Is it water cooled? -
Looks an easy job as it's all accessible. Wouldn't like to suggest a price as it depends on the scope, eg. install pump, wiring etc.
Ulverston canal
The tank that I took out last year on our shared boat was corroded in patches all over. One edge had gone from top to bottom.
It does look as if it's integral to the hull. It should be easy to hack out the parts inside the boat with a reciprocating saw and/or jigsaw if the access is adequate, but there'll be some rough edges left which it might be possible to bend out of the way with a lump hammer. It looks as if the tank was made of thin steel so one hopes that the hull won't be too corroded.
It might well be less than generally thought. The battery on the wife's car is so knackered that the central locking won't unlock if it's been standing for a few days, yet it starts with only a little wheezing from the motor.
What have you fettled for the boat today?
Onewheeler replied to Captain Fizz's topic in Boat Building & Maintenance
Complete Newbie: What type of mooring should I look for?
Onewheeler replied to DanielBiggin's topic in Living Afloat
Bristol is difficult. Saul Junction marina was welcoming when I moored there, a few people spending a lot of time on their boats and not too expensive as marinas go. ~6 km from two main line stations (on different lines) and rural.- 51 replies
- new member
- mooring
(and 1 more)
Tagged with:
I've had two marina moorings. Both say in the small print "no residential use" but in practice don't care if people spend "a long time" on their boats. Indeed, many like to have a few people spending most of their time there as it increases the security. The only issue is that they do usually say not to use the marina office as an address for post (although neither have issues in accepting parts for a boat if you ask nicely first). Tell us roughly where you might be interested and I'm sure that someone will have suggestions. (But don't mention that London!)- 51 replies
- new member
- mooring
(and 1 more)
Tagged with:
Leisure batteries - advice on what to buy
Onewheeler replied to cairanvanrooyen's topic in Build Blogs
My last set of cheap leisure batteries (Numax) lasted 10 years with minimal care so give it a try. -
Naked except for knee pads and the second-smallest pair of shorts. I paint the boat like that too.
It took me 20 years to discover, and has never been noticed by an examiner, that the low level ventilation louvres on the front bulkhead are screwed straight onto solid steel. -
I've got a 12V- Adverc in the garage that was taken off my BMC1.8 when I replaced it a few years ago. Open to offers!
Worth noting that if you were buying in France, you'll pay a lot more than if buying in the Netherlands. For some reason France is very expensive for boats (and cars).
I've just put the undercoat and first top coat on the roof with Black Country Paints. It's good stuff, very heavy pigment and coverage. It's also about 1/4 the price of Toplac.
Ecluse Chatelier, Rance - strange gates!
Onewheeler replied to magpie patrick's topic in General Boating
Very large tidal range there (it's close to the usine maremotrice de la Rance). I imagine it's so to that at high tide there's always a gate being held closed. That's if I understand you or unless it's something else. -
Last winter it was closed from late October until April or so due to floods, and then more or less shut due to that virus. At least there are navigable stretches under the proposed closures.
I think it would take a bit more than the recent deluges to affect the Severn by much, and it tends to rise slowly. It takes at least a couple of days for water to get to the navigable stretch from the upper reaches. The Avon is different, it goes up and down like a fiddler's elbow.
My dodgy panel was producing almost full voltage output but not much current. Check the s/c current.
Slightly random thoughts: Has the controller been disconnected from the batteries with the panels connected? The controller should be connected to the batteries first (most controllers anyway). Disconnect the panels and connect an ammeter straight across the terminals to see what open circuit current they're producing. It sounds a bit like a high impedance connection in the panel circuit (possibly in the panel, I had a vaguely similar problem with a damaged panel once). err... out of ideas for the moment.
