gbmud
Contact Methods
  • Website URL
    http://
    Sussex
  • Occupation
    Waster
  • Boat Name
    emreggub
  • Boat Location
    In my dreams. :)
2,163 profile views
gbmud's Achievements
Contributor
Contributor (4/12)
2
  1. ...or bright green jollop which you squeeze into the tyre through the valve as a prophylactic measure, and which will seal any small puncture as soon as it happens. It works very well. Chris
  2. How about a good quality stainless Thermos flask? The ones I have seen have a plastic screw cap but it may be possible to buy one with a stainless cap... Chris
  3. With just a little logic a genny could be configured to start and charge a battery when the battery voltage was below a certain level (say, 50%) as long as the time was between 0800 and 2000. Another voltage level could be set so that if the battery voltage was lower than a certain level (60%?, depends what you might use before bed) by 1800 then the genny could cut in to recharge before the 2000 cutoff time. I am sure a small computer could easily do it. Whether something is available off the shelf, I do not know. Chris
  4. The bastard lovechild of a boat and an Apé! Chris
  5. Have you ever heard the TGV passing close by in France? It sounds like the end of the world coming, though it does only last for a few seconds, it is EXTREMELY NOISY! Chris
  6. The programme can be downloaded here. The boat/spider/allegedly stolen diesel story starts at about minute 39 in the last quarter of the programme. When the cops were stuck behind the gate, they could just have opened the gate from the inside. When there is a power cut these type of gates can be opened from the inside by just releasing a catch on the actuator and swinging the gate. Dur. Chris
  7. On iPlayer. Chris
  8. I thought I recalled something about the Romans driving on the left so I Googled it; but it seems I was mistaken or mis-informed. This article in Wikipedia has a paragraph on waterborne traffic right at the bottom. Chris
  9. gbmud
    SMD LED's
    Apparently one's eyes are not designed to see blue light as well as other colours, particularly yellow. So a lamp with a very white light might appear, on paper, to be brighter than a much yellower light, which the eye perceives as brighter due to being set up to see the yellow light more vividly. Apparently this is true of blue boy-racer car headlamps where the light output is much greater when measured by a light meter but in reality, actual visibility is no better - or even worse! There are some LED lamps which give a really nice light akin to halogen bulbs, a friend has some in his camper as direct replacements for halogen capsule bulbs but sadly they were a chance purchase off ebay and he does not remember where from. LED technology will get there, indeed, if one spends enough money it already is. ...almost. Chris
  10. As well as heating coil area and volume of water, it will depend on how much spare heat there is - on how hard the engine is working (how much diesel you are burning!). Meandering slowly past miles of moored boats will take rather longer than struggling against a current! As an example, many modern diesel car engines go cold when sitting in traffic with the heater on in winter as there is so little waste heat being produced. Some even have separate diesel heaters fitted to compensate. Chris
  11. Actually pretty reliable post 2002 when several fuelling, oil pump and head gasket issued were addressed. The fuel pressure regulator can be a pain but is easy to replace at least and by then the oil/ECU issue is supposedly addressed. In the Td5 the timing belt was done away with in favour of a duplex chain. In unmodified form 135BHP but still lots of torque low down. This is fast becoming a Landrover anorak-fest! Chris
  12. Landrover 2.5 naturally aspirated diesels have a timing belt and are a reliable, long lived engine - if rather underpowered in a Landrover. IIRC they manage something about 50BHP. The first turbocharged units were just the same 2.5 with a bolt on turbocharger which had the effect of making them very unreliable and not all that much more powerful. Then came the 2.5Tdi engines which, while very reliable are probably rather too powerful for NB use at 100+BHP - though maximum torque is at 1800RPM. Much older 2.25 Landrover diesels had chain drive and were reliable but not very long lived. Chris
  13. Does it not work like motor insurance? You tell your insurer who then gets the repairs done and claims the costs back from the third party? Unless there an accepted alternative protocol that is where I would start. After all, you pay your premium every year, get them to do something for it! As far as painting goes, I expect that, like a damaged car, they will spray the repair (on a car up to a door shut line, wing join etc) in the original paint and then cut and polish the rest of the car to match. I can see no reason why this would not work on a boat too, though how long the result looked good might be a different matter. Chris
  14. Close one eye before entering the tunnel, then, once in the tunnel, swap eyes. Chris
  15. Something suspended for comfort? My brother made this for his local pub some years ago, I am sure he would be open to a commission. Chris
