Flyboy Posted December 10, 2017 Report Share Posted December 10, 2017 12 hours ago, Chewbacka said: Something else to think about as the op did say they were thinking of not running the engine for 2 or 3 months is that the engine oil may not protect the bearing surfaces if not circulated say monthly - ie by running the engine. Just running the engine for a few moments which is enough to circulate the oil is bad, as water is produced when diesel is burnt, and this does need 'boiling off' by running the engine until it is at 'normal' temperature. Agreed, also by not running an engine for long periods will probably lead to valves & seats rusting when in the open position. In my opinion a month would be a more suitable maximum period without running or at least turning the engine over. Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 10, 2017 Report Share Posted December 10, 2017 13 hours ago, JonathonGleeson said: You should ask for it back I would if I knew who borrowed it. Link to comment Share on other sites More sharing options...
Sharibeau Posted December 10, 2017 Author Report Share Posted December 10, 2017 Thanks guys ! I've been working shift work so not had chance to reply So, on all the ( good ) advice I've decided to put a few gallons of diesel ( with a can and syphon ) and chuck the appropriate amount of Marine 16 in the tank. I will start her up every couple of months ( as i have been doing ) and in the Spring hopefully take out all the residual diesel and water and fill her up and fingers crossed no harm will be done. Link to comment Share on other sites More sharing options...
Chewbacka Posted December 10, 2017 Report Share Posted December 10, 2017 That's basically what I do from about now till it warms up enough to go cruising. Never needed to drain the diesel in the spring. Wait till spring and see if there is water present. Link to comment Share on other sites More sharing options...
Eileen Welland Posted February 4, 2018 Report Share Posted February 4, 2018 On 06/12/2017 at 09:55, Sharibeau said: This is the first time i have lived on a canal boat ( or even been on one ! ). I purchase her in the summer and now the winter is here the advice i have been given is ' you must have a full fuel tank in the winter to avoid condensation' i have dipped my tank and it is practically empty - my logic is - ' that's fine , i'll just drain out if any condensation in the spring and re- fill her with new diesel as i'm not using the engine all winter' some of the folk on my marina have said that they wouldn't advise this but couldn't explain why Can someone please clarify if i can leave the fuel tank empty - drain out any water in the spring and fill tank or do i need to fill the tank now ? Thanks Link to comment Share on other sites More sharing options...
Eileen Welland Posted February 4, 2018 Report Share Posted February 4, 2018 We bought a fuel guard filter that fits in line between the tank and normal fuel filter It separates any water from the diesel and filters out any gunk All other half Does is opens bottom tap on it to drain any water that’s in there Done us well Link to comment Share on other sites More sharing options...
Slim Posted February 4, 2018 Report Share Posted February 4, 2018 Reading this before setting off on a 260 mile round trip to go to a boat jumble where I no doubt will buy some ...........jumble. This topic has reminded me to look for some Marine 16. Two observations. 1) Never seen the point of trying to drain crud out of a fuel tank using the drain plug. The very mechanics of putting a plug in a tank (unless underneath) means that some liquid must remain. 2) A Pela pump used every spring is quick, reasonably clean and the gallon or so removed can be used for starting bonfires. Now, how many more miles of rope do I need (not) Frank Link to comment Share on other sites More sharing options...
Momac Posted February 4, 2018 Report Share Posted February 4, 2018 3 minutes ago, Slim said: Reading this before setting off on a 260 mile round trip to go to a boat jumble where I no doubt will buy some ...........jumble Presumably Newark? Is it worth such a long journey? Link to comment Share on other sites More sharing options...
ditchcrawler Posted February 4, 2018 Report Share Posted February 4, 2018 12 hours ago, Eileen Welland said: We bought a fuel guard filter that fits in line between the tank and normal fuel filter It separates any water from the diesel and filters out any gunk All other half Does is opens bottom tap on it to drain any water that’s in there Done us well And if he is drawing water out of his nice expensive filter then he has water in his tank. Link to comment Share on other sites More sharing options...
dmr Posted February 4, 2018 Report Share Posted February 4, 2018 I keep getting tempted by the FuelGuard filter but its very expensive. But, we've had the boat for ten years and only once taken just a little water out of the filter. The fuel pick up pipe in the tank should be raised a bit of the bottom so if your sucking up water then you must have a LOT of water in the tank. As said, taking a fuel sample from the very bottom of the tank once or twice a year is the best approach. I suppose the FuelGuard would/might partly protect against a sudden major ingress of water into the tank. ...................Dave Link to comment Share on other sites More sharing options...
Slim Posted February 4, 2018 Report Share Posted February 4, 2018 10 hours ago, MartynG said: Presumably Newark? Is it worth such a long journey? Six fender lines, an unbranded bilge pump, a tube of sealer and a bacon roll. Link to comment Share on other sites More sharing options...
