MtB Posted December 17, 2014 Report Share Posted December 17, 2014 Worcester 24CDI Looking at the documents that came with the house, the boiler was installed before the attic was converted to a bedroom. However it has since then been inspected and passed. Ok.... If you are right and it was installed in 2007 then straight away it is an illegal installation, so probably a DIY fit. (This is not a condensing boiler and installation of non-condensers was banned from April 1st 2005.) Having said that it is a very good boiler, not prone to poor combustion so very much doubt it is the source of the CO but with an amateur installation all bets are off in terms of it being installed correctly. It will have a dual concentric flue and air supply. The 4" tube is the air inlet duct and inside it is another tube about 2" in diameter carrying the flue gas. So even if the flue gas is escaping it only escapes into the inlet air duct. A very fail-safe arrangement. What is the 'flame picture' like? There is a viewing port on this boiler so you can see the gas flame when alight. It should be bright blue and steady, not yellow like a candle flame. Finally, yes it is room sealed, so fully safe in a bedroom when installed correctly. MtB P.S. Forgot to say, I don't think your CO results will turn out to be anything to do with this boiler. Link to comment Share on other sites More sharing options...
Robbo Posted December 17, 2014 Report Share Posted December 17, 2014 It does. The only test the manual says is to press the 'test' button. But I'm never actually 100% sure this will mean it will actually detect CO. To me that is just a test of the battery the LED's and the sounder. Mine suggests how to test the sensor... Page 11.. http://fireangel.co.uk/Uploads/Products/UserManuals/GN0637R6%20CO-9D%20Manual.pdf SENSOR TEST CAUTION: Sensor testing should only be performed by a responsible adult. This test should only be performed once a month. Excessive testing will shorten the life of the power pack. NOTE: Aerosol CO test kits may be used in order to avoid having to burn incense sticks or cigarettes. However we recommend that incense sticks are used as they are cheap and readily available. A readable level of carbon monoxide will not be given off by other sources of smoke, for example an extinguished candle or match. Step 1: If the alarm is wall mounted unhook it from the fixing screws. Step 2: Hold the Test/Mode button down until the spanner icon appears in the bottom left hand corner of the screen and the bar graph ‘scans’ from left to right. This indicates the alarm is in sensor test mode where the sampling rate of the sensor has increased and the alarm can be tested using a known source of CO. Step 3: Light an incense stick or cigarette using a match or lighter. Extinguish the lighter, or put out the match and place it into a dish of water. Step 4: Hold the incense stick or burning cigarette 15cm (6 inches) below the detector, so that the smoke goes into the holes at the bottom of the detector. As the smoke gets into the alarm the display will show the amount of CO being detected. When the level of CO in the sensor reaches 50ppm the alarm will sound a single alarm cycle, this confirms that the sensor is working correctly and is the end of the sensor test. The alarm will return to normal standby mode. Step 5: Put out the incense stick or cigarette by placing it into a dish of water. Ensure that all flames have been extinguished. Link to comment Share on other sites More sharing options...
BruceinSanity Posted December 17, 2014 Report Share Posted December 17, 2014 (edited) Don't think so Mike. CO is undetectable innit? By us I mean. Hence its insiduouusousness. The hit is deffo nicko. Or even better with your assumed additives! ETA: Inferred, not assumed. This getting a bit OT, but it's both. There's some old research that shows that regular smokers manage their level of alertness by varying the rate at which they drag on the fag. IIRC, slow smoking increases the stimulant effect of the nicotine, quick drags make the CO hit harder. So when doing a dull task, you have the fag sitting in an ashtray by you and take the odd drag at it. When anxiously waiting for something, you smoke quickly and the CO calms you down. ETA This is a big part of the reason why it's so hard to stop. Smokers lose the ability to use other ways of managing their arousal levels... Edited December 17, 2014 by BruceinSanity Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 17, 2014 Report Share Posted December 17, 2014 Smokers lose the ability to use other ways of managing their arousal levels... I find a cold shower works for me Link to comment Share on other sites More sharing options...
Alastair Posted December 17, 2014 Report Share Posted December 17, 2014 Ok.... If you are right and it was installed in 2007 then straight away it is an illegal installation, so probably a DIY fit. (This is not a condensing boiler and installation of non-condensers was banned from April 1st 2005.) Having said that it is a very good boiler, not prone to poor combustion so very much doubt it is the source of the CO but with an amateur installation all bets are off in terms of it being installed correctly. It will have a dual concentric flue and air supply. The 4" tube is the air inlet duct and inside it is another tube about 2" in diameter carrying the flue gas. So even if the flue gas is escaping it only escapes into the inlet air duct. A very fail-safe arrangement. What is the 'flame picture' like? There is a viewing port on this boiler so you can see the gas flame when alight. It should be bright blue and steady, not yellow like a candle flame. Finally, yes it is room sealed, so fully safe in a bedroom when installed correctly. MtB P.S. Forgot to say, I don't think your CO results will turn out to be anything to do with this boiler. Only the 35 model is room sealed. I have the model 24 - I checked the manufacturer's pdf. No concentric flue on this one. The Missus says it was installed a long time ago, going by the docs. Gas flame colour all blue. Link to comment Share on other sites More sharing options...
Loafer Posted December 17, 2014 Report Share Posted December 17, 2014 This getting a bit OT, but it's both. There's some old research that shows that regular smokers manage their level of alertness by varying the rate at which they drag on the fag. IIRC, slow smoking increases the stimulant effect of the nicotine, quick drags make the CO hit harder. So when doing a dull task, you have the fag sitting in an ashtray by you and take the odd drag at it. When anxiously waiting for something, you smoke quickly and the CO calms you down. ETA This is a big part of the reason why it's so hard to stop. Smokers lose the ability to use other ways of managing their arousal levels... That sounds reasonable. I have also noticed though, that the 'hit' achieved with the new vaporising e-smokes, still works. Hence their popularity, But there's no CO in that, 'cos there's no combustion. Interesting viewpoint though. Must add it to the list of stuff to look up! Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 17, 2014 Report Share Posted December 17, 2014 That sounds reasonable. I have also noticed though, that the 'hit' achieved with the new vaporising e-smokes, still works. Hence their popularity, But there's no CO in that, 'cos there's no combustion. Interesting viewpoint though. Must add it to the list of stuff to look up! Its not just combustion http://www.itv.com/news/anglia/update/2014-12-17/workers-treated-for-suspected-carbon-monoxide-poisoning-after-chemical-leak-at-vegetable-storage-facility/ Link to comment Share on other sites More sharing options...
Loafer Posted December 17, 2014 Report Share Posted December 17, 2014 It could be if it's a gas-powered fridge. Link to comment Share on other sites More sharing options...
