curzons246 Posted October 9, 2009 Report Share Posted October 9, 2009 The switch for my immersion heater was located in the airing cupboard. I have moved it into the bathroom. it's location is such that it shouldnt be splashed - is this likely to be a problem when i renew my safety certificate. In anticipation thank you Link to comment Share on other sites More sharing options...
tomsk Posted October 9, 2009 Report Share Posted October 9, 2009 The switch for my immersion heater was located in the airing cupboard. I have moved it into the bathroom. it's location is such that it shouldnt be splashed - is this likely to be a problem when i renew my safety certificate. In anticipation thank you Ideally it should be outside the bathroom, but depending in which 'zone' it is in within the bathroom, it may comply. Link to comment Share on other sites More sharing options...
steelaway Posted October 9, 2009 Report Share Posted October 9, 2009 The switch for my immersion heater was located in the airing cupboard. I have moved it into the bathroom. it's location is such that it shouldnt be splashed - is this likely to be a problem when i renew my safety certificate. In anticipation thank you It should be visible to any one working on the immersion heater - to ensure it cannot be switched on by others. Alex Link to comment Share on other sites More sharing options...
alan_fincher Posted October 9, 2009 Report Share Posted October 9, 2009 The switch for my immersion heater was located in the airing cupboard. I have moved it into the bathroom. it's location is such that it shouldnt be splashed - is this likely to be a problem when i renew my safety certificate. In anticipation thank you Ideally it should be outside the bathroom, but depending in which 'zone' it is in within the bathroom, it may comply. Does the BSS actually care about such things? I've not looked recently, but my memory was of almost s*d all on 240 volt electrics, and certainly nothing as specific as switch placement. All the documents are available online. so you can always check latest situation for yourself. Link to comment Share on other sites More sharing options...
tomsk Posted October 9, 2009 Report Share Posted October 9, 2009 Does the BSS actually care about such things? I've not looked recently, but my memory was of almost s*d all on 240 volt electrics, and certainly nothing as specific as switch placement. All the documents are available online. so you can always check latest situation for yourself. Alan, I wasn't refering to BSS regs. as such. More landlubbery. Common sense dictates that you shouldnt have anything not LV or IP rated anywhere near water, however the 17th Edition allows for outlets in bathrooms in new installations DEPENDING ON THEIR POSITION as everything should be RCD protected... Beggered if I would though.. Link to comment Share on other sites More sharing options...
Gary Peacock Posted October 9, 2009 Report Share Posted October 9, 2009 There aren't any specific rules but good practise is to make an attempt to base its location on the domestic rules so really it's not ideal but it's your choice to relocate it or not. Link to comment Share on other sites More sharing options...
ditchcrawler Posted October 9, 2009 Report Share Posted October 9, 2009 Alan, I wasn't refering to BSS regs. as such. More landlubbery. Common sense dictates that you shouldnt have anything not LV or IP rated anywhere near water, however the 17th Edition allows for outlets in bathrooms in new installations DEPENDING ON THEIR POSITION as everything should be RCD protected... Beggered if I would though.. I would join your club any day, 13 socket in bathroom, hair dryer, straighteners, geto blaster, I better buy an extension lead with multiple outlets. It looks like it will balance on the bath OK, Whoops Link to comment Share on other sites More sharing options...
tomsk Posted October 9, 2009 Report Share Posted October 9, 2009 I would join your club any day, 13 socket in bathroom, hair dryer, straighteners, geto blaster, I better buy an extension lead with multiple outlets. It looks like it will balance on the bath OK, Whoops Thanks for your valued input Link to comment Share on other sites More sharing options...
nb Innisfree Posted October 9, 2009 Report Share Posted October 9, 2009 It needs positioning so that it is difficult to use with wet hands, i.e. away from basin, shower etc. Link to comment Share on other sites More sharing options...
curzons246 Posted October 10, 2009 Author Report Share Posted October 10, 2009 I think there's enough caution shown on here to pursued me to move it the other side and into the kitchen - thanks for your help - Bill Link to comment Share on other sites More sharing options...
Robbo Posted October 10, 2009 Report Share Posted October 10, 2009 I think there's enough caution shown on here to pursued me to move it the other side and into the kitchen - thanks for your help - Bill If you really want it in the bathroom you could put it on a pull cord switch. Link to comment Share on other sites More sharing options...
ChrisPy Posted October 10, 2009 Report Share Posted October 10, 2009 If you really want it in the bathroom you could put it on a pull cord switch. read out of context that encourages the imagination to run wild ............ Link to comment Share on other sites More sharing options...
RobinJ Posted October 12, 2009 Report Share Posted October 12, 2009 The switch for my immersion heater was located in the airing cupboard. I have moved it into the bathroom. it's location is such that it shouldnt be splashed - is this likely to be a problem when i renew my safety certificate. In anticipation thank you Talking about boats, the issue with BSC relates to the position, security and insulation of 240V installation. The building regs. ditate where the switch must be fitted, which might be an issue if it is residential. Needless to say it is a good idea to make sure it complies with both! Link to comment Share on other sites More sharing options...
