Bat & Frog Posted August 8, 2009 Report Share Posted August 8, 2009 Hi All, Our fuel tank does not have a fuel gauge, how does one tell how much fuel is in the tank, and is it easy / how does one retrofit a sender unit or gauge. At present the only option is a cane to dip tank. Thanks Link to comment Share on other sites More sharing options...
saltysplash Posted August 8, 2009 Report Share Posted August 8, 2009 At present the only option is a cane to dip tank.Thanks That tends to be the industry standard method. Link to comment Share on other sites More sharing options...
ChrisPy Posted August 8, 2009 Report Share Posted August 8, 2009 (edited) There are previous threads about tank level sensing, but Salty's 'standard industry method' is fit-for-purpose and simple. Gadget men always want some thin wires and flashing instruments, however. Edited August 8, 2009 by ChrisPy Link to comment Share on other sites More sharing options...
steelaway Posted August 8, 2009 Report Share Posted August 8, 2009 That tends to be the industry standard method. Yep ! Me too. Although mines a nice piece of hardwood graduated at 20ltr stages. Alex Link to comment Share on other sites More sharing options...
RLWP Posted August 8, 2009 Report Share Posted August 8, 2009 Yep ! Me too. Although mines a nice piece of hardwood graduated at 20ltr stages. Alex Mine is painted with matt black blackboard paint and has a nice rope handle worked on it. Richard Link to comment Share on other sites More sharing options...
David Schweizer Posted August 8, 2009 Report Share Posted August 8, 2009 On our boat any dip stick would have to be about a metre long and capable of bending through two 110 degree bends, so the "industry standard" is not always applicable. Retro fitting a sender unit would also involve major disruption, so we resort to the time honoured method of keeping a record of how many hours the engine has run since the last refill, and re-fueling when the calculatiions suggest that the tank is 2/3rds empty. It is quite easy to calculate an average fuel consumption figure by re-fuelling several times after comparatively short cruising periods and dividing the number of Litres consumed by the number of hours cruised to obtain average litres per hour figure. Subsequent calcuklations will help to confirm the average figure. On our boat this varies between 1.05 lph to 1.3 lph , depending on how hard we have been running the engine, and how deep the canal has been. Link to comment Share on other sites More sharing options...
Yoda Posted August 8, 2009 Report Share Posted August 8, 2009 On our boat any dip stick would have to be about a metre long and capable of bending through two 110 degree bends, so the "industry standard" is not always applicable. Retro fitting a sender unit would also involve major disruption, so we resort to the time honoured method of keeping a record of how many hours the engine has run since the last refill, and re-fueling when the calculatiions suggest that the tank is 2/3rds empty. It is quite easy to calculate an average fuel consumption figure by re-fuelling several times after comparatively short cruising periods and dividing the number of Litres consumed by the number of hours cruised to obtain average litres per hour figure. Subsequent calcuklations will help to confirm the average figure. On our boat this varies between 1.05 lph to 1.3 lph , depending on how hard we have been running the engine, and how deep the canal has been. That's pretty good, about 10 litres a day. Your engine is in good condition. Link to comment Share on other sites More sharing options...
LoneWolf Posted August 8, 2009 Report Share Posted August 8, 2009 I use a metal tape measure as a dipstick - already calibrated innit and compact to store And log the number of hours cruised, but i've only filled up twice so far so have no idea how big the tank is Link to comment Share on other sites More sharing options...
ditchcrawler Posted August 8, 2009 Report Share Posted August 8, 2009 Yep ! Me too. Although mines a nice piece of hardwood graduated at 20ltr stages. Alex Same here Link to comment Share on other sites More sharing options...
David Schweizer Posted August 9, 2009 Report Share Posted August 9, 2009 (edited) That's pretty good, about 10 litres a day. Your engine is in good condition. I would hope so, it is a BMC 1.5 which was completely re-built three years ago. It has just clocked up 700 hours. Edited August 9, 2009 by David Schweizer Link to comment Share on other sites More sharing options...
Bat & Frog Posted August 9, 2009 Author Report Share Posted August 9, 2009 Happy with a dipstick, as we have only been out 3 times I was wondering how low to go with the tank, don't fancy pushing her home and not sure RAC would oblige ! Link to comment Share on other sites More sharing options...
FadeToScarlet Posted August 9, 2009 Report Share Posted August 9, 2009 It depends where your outlet pipe for the diesel is. Mine is about 4 inches (which I believe is quite a lot) above the actual bottom of the tank, so that any muck and detritus doesn't get though to the filter. I can see the pipe coming out of the tank, which is built into the back of the counter. This is the most crucial thing to know, when running the engine! I've got a piece of dowel with a big slot marked in, to show the minimum level in the tank. I've also marked on the consumption between some local landmarks, and I know that going from, say, Upware to Cambridge will use nearly 2cm of diesel if I'm running the engine hard. Link to comment Share on other sites More sharing options...
rjs Posted August 9, 2009 Report Share Posted August 9, 2009 We have a duel use aluminium dip stick - diesel one side and WC on the other Richard Link to comment Share on other sites More sharing options...
ChrisPy Posted August 10, 2009 Report Share Posted August 10, 2009 We have a duel use aluminium dip stick - diesel one side and WC on the other Richard so that's where the diesel bug is breeding! Link to comment Share on other sites More sharing options...
