Epeaver 60 amp tracer an .
Greg & Jax
Hi all .
I'm looking to replace our lead acid batteries with agm batteries and after having a look at our solar charger it doesn't have the agm option only flooded sealed gel and lithium and user .
I'm quite new to the solar stuff and at a bit of a loss with this .
Any pointers would be great .
Regards Greg.
Set the user profile up so absorption charge  is at 14.6 V and float at 13.6V.  You will need to experiment a bit with the duration of Absorption, depending on the solar output.
N
If the new AGM batteries can handle an absorption voltage of 14.9v as shown on the specs, then I don't think you'd have any issues leaving the solar controller set to lead acid, unless the absorption phase for LA is too long for AGMs?
I think BEngo is correct though, you'll be better off going to a manual setting.
By the way, absorption is called "Boost Charge" on the Epever.
Hi, I had agm batteries installed because I have a large number, plus not easy to access any of them.
So after four years they are still working g satisfactorily.
No technical info as the fitter did not leave any info, but there are approx six batteries in three banks, and I currently have to run engine about 7 to ten hours per week to keep them charged i have a 70amp rated alternator and 550w solar. No maintenance six months of the year.
I would not recommend having a complex system, but that is how it was designed from new.
Once upon a time there was a bow thruster and the boat was in a marina with shorepower.
I have Epever.
Edited by LadyG
