Bewdley or bust...
matty40s
To be accurate:
It wasn't a Starline boat that got stuck. It was Starline that went out to recover the boat.
They'd have a job getting to Llangollen on the Severn; it goes nowhere near it!
At one time the Severn was navigable to Pool Quay, which is a couple of miles from Welshpool, and Severn Trows regularly got to Iron Bridge.
All that's needed is to make the Severn navigable up to Pool Quay, put a link in to the Montgomery Canal and reopen the closed bits of that, then you could get that way to Llangollen.
And while you're at it, put in a link to the Shrewsbury and Newport Canal as well.
8 hours ago, Captain Pegg said:
Did they make it further than you’ve ever been and if so does that mean you’ve got to back for another try? 😂
No, Mrs TNC here all the time now, she does not do that kind of stuff 🤔
On 03/05/2023 at 07:59, Neil TNC said:
Have CaRT replaced this with sign with something easier to read? 😄
I don't remember seeing that sign last year. I went a bit past the end of navigation out of curiosity and there was certainly nothing as clear as that.
Looks like they got stuck under the A456 bridge - not bad going really!
I didn't take any photos, so here's Lark (temporarily) stuck under Harrington Bridge on the Trent instead. 🙂
Edited by Francis Herne
Have you made it as far Clifton bridge?
Moored at the County Hall now, hopefully try this weekend. I did get a little past Wilford the other day but it was getting dark so turned back.
Update: yes.
Stopped there because water visibly swirling over obstacles of some kind; need to do some more poking about in the canoe and find a similarly daft crew member or two for contingencies.
