Hi
just purchased a Refleks 2000K which has the ring around the top. I am struggling to find the correct fan that will surely sit across this ring and not on top of the hot plate. Any clues anyone?  Thanks
37 minutes ago, El Tel said:
Hi
I put a standard fan directly on the hotplate without any harm to fan or plate but you could extend the "foot" of and fan using a piece of steel or aluminium bar.
Yes my fan goes straight onto the hot plate of my Kabola.
I now have a Valiant fan but I recall that its predecessor (12+ years service) had a warning to keep it away from the hottest part, anywhere near the flue.
Hi
yes it seems they sit on the plate but i think i need to maybe check what heat the fan can take? Makes sense to mount as far back as possible. Thanks for the reply
2 minutes ago, JamesWoolcock said:
I wouldn't get a small casserole on with that.
Its bloody huge.
At 30cm tall and 18 cm square the actual footprint is less than most regular fans and certainly not 'huge'
Which kind of fan do you have where you can put it on a Refleks 2000 with a small casserole?
Tip = Take fan off to put Casserole on and vice versa.
I used an ALDI fan on our Reflex, similar to the Ecofan mentioned above but at a sensible price, it did the job very well.
They are currently available in their special buys Workzone Stove Fan £15.99.
