Tracy D'arth Posted December 2, 2020 Report Posted December 2, 2020 We ran a 24v truck alternator off the flywheel of an Ailsa Craig FR4 without any problem. That is a massive flywheel and the alternator was mounted back to front on the floor in front of the engine which was solidly mounted. Even with the very slow running engine it must of had thousands of rev on it. Charged well. 1
David Mack Posted December 2, 2020 Report Posted December 2, 2020 2 hours ago, frangar said: Yep still going...Alternator now changed from a A133 from a Jag to a A127 from a Discovery!!...used the same principle on a couple of other boats with large external flywheels...gives you a great charge rate at tickover and spins the fan fast enough to ensure proper cooling. Change belts every 3/4 years just because they get a bit polished and its easier to do planned maintenance than have to worry about it when it breaks. Was this using a single v or poly-v belt?
GUMPY Posted December 2, 2020 Report Posted December 2, 2020 Mine was a single v, the belt twists into the join between flywheel and ring gear.
frangar Posted December 2, 2020 Report Posted December 2, 2020 9 minutes ago, David Mack said: Was this using a single v or poly-v belt? Single v. Mine runs about 1/4 inch in front of the ring gear. Just on the flat face. No slip or tracking. Alternator is 70 amp and it regularly outputs that with inverters etc. 1
MoominPapa Posted December 2, 2020 Report Posted December 2, 2020 1 hour ago, frangar said: Single v. Mine runs about 1/4 inch in front of the ring gear. Just on the flat face. No slip or tracking. Alternator is 70 amp and it regularly outputs that with inverters etc. Same here on a Lister FR2. 70 amp alternator. 40A output at 400rpm tickover. Max output from about 700 rpm. Still using the same belt that was fitted when I bought the boat in 2008, though I do carry a spare. Had to tighten the belt to cure slipping for the first time this year. MP. 2
Peter Duddigan Posted December 2, 2020 Author Report Posted December 2, 2020 Great to read these stories. Using initiative to create a working idea.
GUMPY Posted December 2, 2020 Report Posted December 2, 2020 No initiative here I just nicked the idea from @frangar 1
Peter Duddigan Posted December 2, 2020 Author Report Posted December 2, 2020 That's what I meant by initiative??
ditchcrawler Posted December 3, 2020 Report Posted December 3, 2020 17 hours ago, Loddon said: No initiative here I just nicked the idea from @frangar I got a front garden seat like that 1
frangar Posted December 3, 2020 Report Posted December 3, 2020 6 minutes ago, ditchcrawler said: I got a front garden seat like that I wondered where that went......?
