nigel carton Posted November 15, 2019 Report Posted November 15, 2019 Looking at freeing off a lister ST2. Was running fine 6 months ago but previous owner hasn’t run it since. I’m going to try and turn the crank shaft with cylinders decompressed , if no joy, remove injectors and squirt diesel in and leave for 24hours. Any thoughts?
RLWP Posted November 15, 2019 Report Posted November 15, 2019 Rings rusted into the bores Or worse - water in the cylinder. Richard
bizzard Posted November 15, 2019 Report Posted November 15, 2019 A few years ago someone here had left the air cleaner off on an ST2 for ages under a cruiser stern deck, filled to the brim with rain water and seized. Drained the oil and changed it. Injectors out and poured in traditional REDEX. Left it a bit and then barred the engine over and it unstuck and pumped out water at the injector ports. Then tried to start it, decompressors on and it started almost right away, pumping out a bit more water from the exhaust, then clouds of steam and black smoke which blotted out east Hertfordshire. It gradually settled down and ran well. She went off with it to the K&A Bathampton and it got there ok.
nigel carton Posted November 18, 2019 Author Report Posted November 18, 2019 On 15/11/2019 at 18:36, RLWP said: Rings rusted into the bores Or worse - water in the cylinder. Richard Worse than that Richard, pumped engine oil out, unfortunately not oil but a bucket full of water. The boat hasn’t sunk, I can only guess this was deliberate.
RLWP Posted November 19, 2019 Report Posted November 19, 2019 14 hours ago, nigel carton said: Worse than that Richard, pumped engine oil out, unfortunately not oil but a bucket full of water. The boat hasn’t sunk, I can only guess this was deliberate. Where's the exhaust outlet? Also, had water got half way up the block - there may be a tide mark
nigel carton Posted November 19, 2019 Author Report Posted November 19, 2019 The exhaust outlet is high up on the stern. No visible tide marks. Strange one this
sparrowcycles Posted November 19, 2019 Report Posted November 19, 2019 Water can run down the exhaust if the outlet is in a poor position, or if the stern got low in the water and then refloated, thus tipping a silencer full into the engine.
OptedOut Posted November 27, 2019 Report Posted November 27, 2019 Might I enquire if there is a hot air outlet on the side of the engine bay, if so, what is its position relative to canal water level
Jrtm Posted December 1, 2019 Report Posted December 1, 2019 On 16/11/2019 at 06:37, Boater Sam said: Tow start it. Works best with a long line and a good run up.
nigel carton Posted December 1, 2019 Author Report Posted December 1, 2019 On 27/11/2019 at 11:06, OptedOut said: Might I enquire if there is a hot air outlet on the side of the engine bay, if so, what is its position relative to canal water level Hi, it’s well above the water line. I’ve managed to un seize both pots, refitting cylinder heads tomorrow
OptedOut Posted December 1, 2019 Report Posted December 1, 2019 (edited) Just wondered if the the boat had been aground on the opposite side (due to a falling canal level) and shipped some water into the engine bay then said water was then pumped out by the bilge pump when the boat levelled on re-floating. Edited December 1, 2019 by OptedOut
