Timx
Morso squirrel stove chimney
16 hours ago, tree monkey said:
At one point I had 2, first bought for £30 second hand, 2nd taken from the old stove when I fitted a new one.
I did give one away to someone who had a mid winter glass crisis.
We have three squirrel doors on our boat, so there. One on each squirrel, and a spare from the squirrel we broke up a few years back, along with spare side, bottom and flue collar.
Share this post
Crikey, and I was impressed by the one I saw with a cat flap!
  • Haha 2
Share this post
Tin foil over the inside of the door works quite well as a temporary fix, if you rip it, replace. Ensure that the tin foil extends beyond the door seals.
Share this post
When replacing the glass, be sure to clean off any rust inside the lip, and don't overtighten the clips. There may be a very slight deformation of the door when heated up/cooled down that may crack your glass. Any ingress of air through the crack will reduce the fires ability to draw through the bottom vent, in exactly the same way as the top vent. You can check for spillage round the crack with a smoke match, or rolled up tissue which will smoke when lit. Holding this next to the crack will show any spillage or draw.
Share this post
Any movement is taken up by the rope seal between the glass and the door.
Share this post
The 2mm thickness of that seal can easily be nullified by corrosion .
Share this post
18 hours ago, CompairHolman said:
The rope seal on Morso Squirrel door is 6 mm diameter.
Yes, but the seal between the glass and the door is 2mm
Share this post
