philjw
philjw's Achievements
Proficient
Proficient (7/12)
74
  1. I had some form of plastic runners on a previous boat and although they were slippery the buckled badly in warm weather.
  2. Doesnt have the right angled upstands to the hand rails. These are a great bit of design that stops you bashing your fingers when moving down the handrail, especially when cleaning the boat. Agree that the fore end looks to be Minden.
  3. I weighed in four batteries at Daventry Non Ferrous Metals in 2022 and received just short of £50 by bank transfer. Take photo ID as said above. Unit 14 Everdon Park, Heartlands Business Park, Daventry, NN11 8YJ
  4. Has anybody used the additives which are around to help with the waxing issue? Example: https://www.stp.com/uk/product/diesel-winter-treatment-with-anti-gel/
  5. Could it be because the new battery is not fully charged and actually needs the boost from the A to B? If so then it ought to sort itself out given time. Did you measure the voltage before fitting the new battery?
  6. If you don't trust anti freeze testers you could put a sample of your coolant into a domestic freezer. I believe freezers are somewhere around -18 degrees Celsius. If the sample freezes then you may have a problem if the ambient temperature drops that low. I just use a tester like the one linked by Ditchcrawler.
  7. You can buy label sets from the electrical parts places E.G. 12V Planet https://www.12voltplanet.co.uk/blue-sea-systems-8214-black-60-label-set.html
  8. Concentrated Prestone is available at Costco if you have access.
  9. That's not the one. The shop in question is next door to the New Inn and is now part of a private house. The bit with the large window was the shop part I believe.
  10. The inlet for the system is on the edge of the spill weir. It was quite obvious when fitted. They must have some serious filtration.
  11. You could get the Andy Russell product from the 3P paint company in Stockport who actually made it for him but their website is not loading today so I'm unsure if they are still trading. Cheaper price too. 3p Paint Company (Stockport) Ltd opening times Hallam St, Hallam Mill, Stockport, Greater Manchester, SK2 6PT +44 161 477 4203
  12. Might bé also worth asking NABO and/or IWA if they know if him.
  13. If you really need to pay someone to look for the leak then ask at Calcutt Boats. They have a range of people who do various boat related tasks. However it would be worthwhile following the pipework from the tank via the pump and on into the cabin. The pipes may well be hidden behind the fit out. Look for a disconnected fitting as suggested above as it sounds like a major leak.
  14. There is a fuse on the panel it seems https://www.fischerpanda.de/content/C56375959C2659D556790F5E5F043A29/Fehlersuche_Flowchart_Marine_Rev2.1_eng.pdf
