RobinR
Everything posted by RobinR
No mention of the K&A!! Here some older "as built" locks have the overflow inlet within the lock. For these locks the requirement is to leave top gates open regardless. There are often C&RT signs with this instruction. These are being modified on an ongoing basis. Once a bywash has been constructed the normal canal practice to leave all gates closed becomes the requirement however the (BWB) signs to leave top gates open may be an element of a listed structure thus can not be removed!! Confused???? This was an explanation given when I visited three years ago. Gates swinging open indicates a good seal at the other end so don't worry.
Per the following from the 13th. March 2014 "Who do you Think You Are" newsletter, these can now be accessed for free. "The National Library of Scotland has announced a major new online resource for family historians - a collection of English and Welsh maps covering more than 100 years. The highly detailed zoomable maps of England and Wales from 1842 to 1952 allow anyone to browse through a catalogue of place names, modern street names, postcodes and grid references. You can access the maps at maps.nls.uk/os/6inch-england-and-wales/info1.html. Alternatively, you can look through a clickable graphic index at the site's Find by Place viewer here. The website compiles 37,390 sheets, including 35,124 quarter sheets of A2 size, and 2,236 full sheets at A0 size, which makes for a wide range of search options. The National Library of Scotland’s map digitisation work in recent years has been externally funded, leading to a recent expansion in map images beyond Scotland including a Victorian plan of London which was uploaded last year. The Ordnance Survey six-inch mapping system is the most detailed map scale to cover England and Wales and can record most man-made features in the landscape such as roads, railways, fields, fencing, streams and buildings. Smaller features such as letterboxes, bollards and mileposts can also be seen. For many of the towns featured, the maps show the detailed urbanisation and rapidly changing landscape from 1914 through to the 1940s thanks to 25 inch to the mile mapping. Although images can only be viewed individually, you have the option via the map group tool to look at an area from the 1840’s up until 1952." Apologies if this is duplicated information.
Is F1 FTA on other satellites e.g. Astra 1 and Hotbird? If so, use a small dish and a FTA (not Freesat / Sky / Freesat from Sky) box and listen to the BBC radio commentry. (FTA = free to air i.e not encoded)
Kent Green on the Macclesfield Canal at Heritage Narrow Boats. Narrow locks are MUCH easier than wide ones. Excellent choice of routes including the Caldon Canal (best in the UK) and in Cheshire (i.e. not Lancashire!!). I have a share in a 60 ft narrowboat and disabled wife thus work single handed from time to time. I continue to manage these canals single handed at 67 1/2 years young.
Help! Life without telly is unbearable :(
RobinR replied to Wild Is The Wind's topic in Boat Equipment
I have both the Maplin aerial with amplifier and suitcase satellite kit. All work from 12 volts (I use a power inserter to feed 12v to the amp) and the FTA satellite box also runs on 12v. and then to aim the dish at 142 degrees with the dish vertical (shows 19 degrees on the built in elevation scale). To find 142 degrees, initially look where dishes on houses are aimed then take a compass onto the towpath away from the boat and other large steel objects but stand as close to the dish mounting point as possible. Identify a distant object (tree, chimney etc.) at approximately 142 degrees and stand on an imaginary line between the dish and that object. If the previously identified object is no longer near the 142 degrees line, select another distant 142 degrees object. Align the dish to that distant object. The Maplin FTA satellite box (as generally with COMAG derived boxes) has variable tone (higher audio pitch equates to stronger signal) tuning feature which can be heard with the TV volume high or on earphones with an extension lead from the headphone socket of the TV. If using BBC1 London for set up, the box will also receive a German programme from the Hotbird or Astra 1 satellite. Astra 2 is a little further East and at a very slightly lower elevation. The smaller Maplin dish is less prone to signal loss however, before leaving the dish to watch TV ensure it is aimed at the mid point position for optimum reception both horizontally and vertically. Our mooring mallet or a windlass helps keep our dish secure in moderate wind! We place the dish inside the boat whilst boating and can now set it up more quickly than resetting the TV tuner and aerial where the previous terrestial transmitter is out of reception range plus we can watch our local area news etc from anywhere satellite reception is possible. The Freeview reception provides the "Red button" text and weather and our recently purchased COMAG HD Satellite box (also 21v) can record to a memory stick!! The FTA satellite box will also accept FTA signals from all satellites above the horizon thus usefull for those of us fluent in multiple languages or wishing to watch the BBC World News not on Astra 2. -
Fire Extinguishers Again. To quote BSS Chapter 6 "The requirements in this chapter have been informed by,and may refer to, the following technical references, codes and regulations." and then refereces BS5306-3:2003 which is now BS6306-3:2009. These further reference BS5306-8:2000 and a new Draft BS5306-8 has been published for public comment. Both exclude boats as needing to comply with their requirements: "This part of BS 5306 is not applicable to aircraft, caravans or marine craft. It is applicable to all other buildings." Does the BSS statement above overide this for inland marine craft? However, 1kg or 2kg ABC Powder extinguishers should be mounted on stands or wall mounted with the handle 1.5m above the floor. But is it now time to re-think extinguishers for use on boats per statements within the above draft viz: 4.2 The environment The impact of the discharge of the extinguishing medium on the environment should be taken into account. Extinguishing medium can cause collateral damage to many things such as, but not restricted to, food, machinery, building fabric, fixtures, fittings, artefacts and sensitive equipment. Expert advice on the impact of the discharge from a fire extinguisher on the local environment should be sought from competent persons. Advice on the impact of extinguishers (and their content) on the wider environment should be sought from extinguisher manufacturers and distributors. 4.5 Training in the use of extinguishers The competent person should bring to the attention of the responsible person the need for training. Every opportunity should be taken to instruct personnel in the use of extinguishers, and to demonstrate their performance. Extinguishers for different fire classifications will have different training requirements. 5.2 Fire ratings Fire ratings of extinguishers are determined during controlled tests by experienced users. When using the fire rating of an extinguisher to calculate the required levels of coverage, it is therefore important to take into account the total discharge time of the extinguisher, and its range of discharge, in combination with the levels of experience of the potential users. 5.4 Discharge 5.4.1 Distance and direction The distance over which an extinguisher can expel its content should be taken into account when specifying an extinguisher for a defined hazard. A jet type discharge will travel a considerably further distance than a spray type discharge. This affects both horizontal and vertical discharge distance and might be of particular importance in areas that have shelving or racking. Light or gaseous extinguishing media such as carbon dioxide or clean agent should not be specified where wind or draughts could adversely affect the distance of the discharge or unexpectedly change the direction of the discharge away from the fire. Such media should be specified where the media is required to search for the fire, e.g. through a vent or grille and into the shell of electrical equipment. 5.4.3 Use of powder extinguishers The discharge of a powder extinguisher can cause a sudden reduction of visibility, which could temporarily jeopardize escape, rescue or other emergency action. For this reason water-based extinguishers should ideally be specified for use indoors. 6.4 Travel distance Extinguishers should be sited in such a way that it is not necessary to travel from the site of any fire to reach an extinguisher further than the following maximum distances: • class A: 30 m; • class B: 10 m; • class C: 30 m; • class D: case by case basis, by expert advice; • class F: 5 m. Where the prospective operator is required to pass through doorways to reach the nearest extinguisher, the above travel distances should be reduced to maintain a short time between discovery of a fire and the moment at which the prospective operator is able to start fighting the fire with the extinguisher concerned. 8.4 Class C – Fires involving gases 8.4.1 General If a trained fire-fighter is not at the scene of the incident, the only safe method of extinguishing class C fires is to cut off the flow of fuel to the leak. Locating and operating the flow control valves is therefore the preferred method of extinction. These actions should be carried out as a matter of extreme urgency. If this cannot be done immediately, two opposing fire hazards are possibilities. These are: a) the jet of flame, contrasted with the filling of a volume with unburnt gas. A gas reservoir with free access of air will be liable to re-ignition at any time, possibly with explosive force. Unless the jet is playing directly upon some other combustible material, which should be covered with an appropriate extinguisher as recommended elsewhere in Clause 8, allowing the flame to continue is the least dangerous option until the flow can be stopped. 8.4.2 Minimum quantities of class C extinguishers required None are required unless a trained fire-fighter is available (see 8.4.1). ********************************** Should AFFF (Foam) now become the preferred choice with Class F coverage for the kitchen / cooking area? ********************************** 8.6 Class F – Fires involving cooking media (vegetable or animal oils and fats) in cooking appliances 8.6.1 General For these fires the first action should be to cut off the source of heat input to the cooking container, if this can be done in safety, as this reduces the chance of re-ignition. Types other than those suitable for class F fires should not be sited in areas where cooking oils or fats is the major factor in the risk analysis. WARNING. Failure to use class F media can make a fire involving cooking media in cooking appliances significantly worse and is likely to spread the fire to the immediate vicinity of the appliance concerned. ********************************** Time for a rethink???
Go get your licence back - sunspots rising. Had a number of great contacts last year and this year will bebetter!!
BSS Fire Extinguisher Requirement for Working Boat
RobinR replied to alan_fincher's topic in General Boating
Yes - if you count during the training I undertook in 1994 for the F.E.T. A. Certificate and on real test fires. Very messy. Carbon Dioxide is not suitable for Class A (wood etc) fires. Halon was much better before being unjustifiably banned. Halon was (and still is) very effective in the hands of an untrained user and unlike for its other former uses, extinguishers are designed for absolute minimum leakage if any. Halon is destroyed by fire - one means used for disposal and whilst some escaped to the atmosphere when used to extinguish a fire, the overall adverse effect is still less than for powder, foam, water and / or Carbon Dioxide because there is a higher probability that the fire will be extinguished and hence fewer combustion products released. Re pressure gauges, the needle is normally midpoint when pressurised at the factory or when refilled. Changes in ambient temperature will result in movement from this point because the pressurising gas expands when warmed and compresses when cooled. Leakage of the gas also causes the gauge to move to a lower value hence their reason for being there. I have also seen a gauge stuck at the midpoint reading with the valve assembly removed from the extinguisher!! -
Surely, Section 6 of the scheme is well overdue a full review and update because referenced standards have been revised substantially. BS5306-3 was reissued on 31st. July 2009 and now incorporates additional requirements including one for extinguishers to be commissioned by a competent person at installation and appropriate certification to be issued. BS EN3-1 to-5 have all been supersceeded e.g. by Part 7:2004+A1:2007 Characteristics, performance requirements and test methods and Part 10:2009 Provisions for evaluating the conformity of a portable fire extinguisher to EN 3-7 Extinguishers manufactured per BS6165 for small disposable fire extinguishers of the aerosol type are now only available as BC units and are not now sufficiently large to meet scheme requirements. Regarding Firemaster 1000PR B/C [brass/Chrome] models marked without the Kitemark being acceptable, the manufacturer ceased trading some years ago thus associated warranties are no longer applicable. All EN3 extinguishers require a pressure gauge. The wording in the scheme document is "The requirements in this chapter have been informed by, and may refer to, the following technical references, codes and regulations". Are the technical references, codes and regulations therefore mandatory or for guidance only? Do the outdated versions of the standards still apply to the scheme or are additional requirement within current versions applicable? All manufacturers specify service in accordance with 5306 e.g “This extinguisher must be installed and serviced to BS5306 Part 3 and Part 8.” Also “”An appointed person should visually check the extinguisher, preferably once a month, for damage and serviceability”. Also “This extinguisher should be serviced at least annually, and discharge tested every 5 years to check the actual functioning to BS5306 Part 3 and Part 8 by a trained, competent person.” are all extracts from the screen print on a Firechief 2kg powder extinguisher. A number of manufacturers have verified the absence of records verifying the annual service will nullify any warranty claims and thus they will have past any implied expiry date? The wording in the scheme document appears to reflect requirements of obsolete standards and codes of practice should it therefore be revised to reflect the current standards / codes of practice and should the requirements of these standards / codes of practice more clearly become mandated? -
This placed on the roof of the boat will suffice where a good signal is available but you will need an adaptor to connect a standard DAB radio and may be another for an FM Radio. Steel is a very good shield for VHF and UHF radio signals thus will only be effective inside the boat very occasionally e.g when in sight of the Sutton Coldfield transmitter whilst on the northern part of the Coventry Canal. Also, remember the signals from virtually all the many low power relay / infil transmittters are vertically polarised and for best results the aerial should both point at the transmitter and be correctly polarised. Freeview boxes allow the signal information to be accessed thus the aerial can be pointed in the optimum direction and if all channels are not present, another retune may capture them.
Which one? Watford Village near Watford Gap Services, M1 - or the one near the M25?? The hills either side of the gap were the natural barrier which was considered a North / Souty Divide!!
Moor up and operate my mobile amateur radio equipment.
Re the first response, the properties of AFFF foam solutions are the same for both gas cartridge and stored pressure extinguishers. Even without low freeze addative the foam will depress the freezing temperature and even then the ambient temperature within a boat will need to be below freezing for days rather than hours before the contents freeze and strees the can to the point of rupturing. If ruptured, the contents will generally be released slowly - more slowly for gas cartridge extinguishers. If the extinguisher shows signs of being stretched / deformed it will need to be replaced however, once the foam is fully un-frozen, it will perform normally. It may also clean your carpet!! LFA extends the lower operating temperature by up to -10c at the expense of the fire rating of the extinguisher whilst ABC Powder extinguishers generally operate to -20c. Canal boats are generally fitted with up to three 2kg ABC powder extinguishers to best meet Safety Scheme requirements however they make an unblievable mess when used in the confines of a narrowboat and are certainly high risk for asmatics especially in a confined space thus an AFFF or two can be quite a good idea as additional cover. The prime function of a fire extinguisher is to extend the window of opportunity to escape a fire e.g. by maintaining a fire free escape route for as long as possible. Saving a boat from damage is only of secondary importance thus it is sensible to have good quality Kitemarked extinguishers installed, comisionned by a competent person and serviced annually per BS5306-3:2009.
On this Sunday / Monday, 8th./9th. October the Discovery Shed channel 242 (Sky) is again running all 20 parts of the series in 2 parts from 10.00 am. to 5.00 pm and again from 1.00am to 5.30 am (i.e.during the night). Alan Herd is travelling the Stourport ring clockwise starting from Birmingham. The programmes do not seem to be in order however the first two and last two programmes for each session are the first two and last two of the series.
Were a standard to be set, then 27Mhz would probably be the better choice because the greater range and variable power output levels would be good for on-boat comms, local boat to lock etc comms whilst being able to get signals a little further when set at 4 watts out and if in general use could be used as a water / time saving tool by advising others when approaching locks. We generally use 446Mhz PMR which are ok to a nearby lock but not much further. Marine VHF requires a licence and exam pass but of very limited use on UK inland waterways at present. Recent and current Amateur equipment can generally be set to the frequencies, power levels and bandwidths for 27Mhz CB and 446Mhz PMR by selecting the relevant parameters within the set-up menus. My Yaesu FT817 HF / VHF tranciever has both in memories for listening purposes only and my TYT UHF1 VHF / UHF Handheld has the 446Mhz channels in memories (again for listening purposes only). There is a proposal for boaters to use Ch8 on 446Mhz but I have heard this in use only once over 6 years / 3 to 4 weeks per year!! With a pair of good handhelds on eBay from time to time for around £10 there is surely no good reason for there not to be more extensive use accross inland waterways?
Possible topics on which FAQ's could be created.
RobinR replied to DHutch's topic in Frequently Asked Questions
Television reception - aerial selection, satellite options, and all else re this technology. Variations on these themes seem to be asked over and over and over ... ... ... again!! -
I don't normally quote my earlier posts, but I wish to supplement the information in the light of more recent posts! 1) We have a 25 gallon tank - thus not a huge volume - this equates to approximately 5.5 cassettes. 2) We are using an aerated bacteria treatment process 3) The output is an ouderless slurry 4) There are none of the harmful components found in blue 5) The flush water is recycled from the hand basin in the shower room (too small for a bath) 5) Post pumping the tank contents, flushing water (previously used in the hand basin) can be diverted to flush through the pipes used for tank emptying. Another (obscure) thaught, if all boaters converted to cassettes (e.g. carrying three per boat to ensure adequate capacity) would BW start to charge for the use of Elsan type units??? (Unlikely I know - but a possible input to a process risk assessment)
We recently installed a macerator system and incorporated pipework to enable the pump to additionally empty the holding tank via an outlet within the shower fitting. By using a short flexible pipe attachment into a porta potty casette, we can empty any number of casset fillings into the elsan disposal facilities along the waterways (we carry a porta potti for emergencies). Where self pumpout is allowed, we have a long hose which can reach most elasan units. We have also converted to an aerobic bacteria treatment system thus no blue used.
Station Attenuation
This scenario strengthens a point of view I have put forward both here and elsewhere - All boats on BW and EA waters should carry and be required to use a common 2-way radio e.g CB or 446mhz PMR. Processes could then be established to optimise lock usage and minimise unecessary water usage especially at times of shortage.
Maybe time to invest in a shared ownership scheme - much more cost effective! Our 4 weeks this year (1 in March and 3 in June) have cost under £1000 all in!!
We cruised the Leeds side of the L&L in June this year. Most manually operated swing bridges had a chain to pull from the towpath side to close the bridge but one was broken and another was held fast on the bed of the canal - I suspect a heavy object. Two could be accessed from the offside. I opened the bridges from the towpath side using the pole to push them open and boated through on the engine. For the two bridges not able to be operated by a chain, I was fortunate enough for them to be operatede by another crew. There were at least 4 bridges where operation was only possible with the presence of a person eg to push the operating buttons whilst the electrics and hydraulics operated the barriers and bridge movement. Here I waited for another boat and explained the challenge facing me. I am very thankful to the crews who aided me through these bridges.
As I perceive the situation, the best action appears to be: 1)Prepare to allow an approaching boat pass any obstruction where there is doubt as to who will get there first. 2)Learn and use the sound signals. The first boat using a sound signal puts the onus on the other boat to take action to avoid collision (according to BW By-Laws), so get yours in first! My way of remembering how many Blasts? is: 1 short blast - turning to starboard (ie turning right) ... this is how two boats approaching in the middle of a sufficiently wide waterwaay will normally manoever anyway!! ie, one blast is what I would normally do on a boat!! 2 short blasts is thus indicating my intention to pass in the non-standard way by turning to port (left) 3 short blasts is therefore for going (attempting to go) astearn 1 long blast is for turning around followed by short blasts as above to indicate the direction of turn. Thus when, for example, when appproaching a blind "T" junction, being the first to give 1 short blast to turn right or two to turn left will place a greater obligation on another boat approaching the junction to do more to avoid collision. I am not claiming this approach will prevent collisions, only that by following these practices, I have done all I am able to avoid a collision by communicating my intentions to other boats, whilst accepting I can do nothing regarding the lack of knowledge of other boaters.
We purchased a budget Bush 12 volt TV from Argos 6 years ago. It lasted a year (on a shared ownership boat). The refund funded a Freeview Toshiba TV (customer return) less its 12 volt power supply, mains lead, instructions etc. The Argos refund funded the replacement and made a contribution to an Amperor regulator which continues to supply 12 volts even with the input below 11 volts!!. It is still working fine and we fitted a 9dB gain masthead amplifier to the aerial to feed a second TV in the back bed area.
But this is a festival not primaraly a Crick style boating event. I go to Crick to browse equipment and buy goods and go to the National for an enjoyable family day out. To me they are different types of event.
