RAP
Everything posted by RAP
  1. Again, steamraiser2 offers good and solid advice. The servicing of my injectors and pump was the last item on the long road to getting my old and worn out engine into a satisfactory running condition. What I lacked along this journey was others to compare my experiences with. I queried things on here, spoke to experts in the industry but it would have been great to have simply shared my trials and tribulations with other JP owners. To this day I still don’t know any other JP owners. It has been an expensive process but please do make some basic and cost free checks before shelling out. For me, the decisions were easy once I had made these basic checks coupled with the knowledge that my engine was quite knackered.
  2. I echo steamraiser2’s advice, had fitted their spring and cam, ensured free and lubricated movement of the governing gear, but I state again, that it wasn’t until I had the injectors serviced and the pump calibrated I achieved a smooth and beautifully running JP3. I should also state that I fully overhauled the engine prior to that which included crank regrind, remetalled shells, new liners, piston rings etc. I compare the servicing of the injectors and fuel pump to that of any old vehicle engine that uses spark plugs and contacts, replace with new and your engine is more likely to thank you for it.
  3. My 74 year old industrial JP3 had governing issues at low revs until I had the injectors serviced and the fuel pump calibrated. Ticks over at a steady 290 rpm and a decent cruising speed is achieved at 500 rpm with a 1:1 gearbox.
  4. I use yatch varnish from Toolstation, thinned with about 10% white spirits. It soaks in nicely, quick and easy to apply with a decent sized brush and provides comfort that the backing and edges are suitably protected and sealed.
  5. Canal water. Have done for the last 25 years.
  6. I expect you’ve realised that I am being provocative, but my point is we shouldn’t have to search this out. Their work should be made freely available, they are our elected reps.
  7. Thanks, but is this 1out of 4?
  8. Boaters’ group? What about the four CRT reps - never hear from them!
  9. Yes, always seal. Expect the unexpected!
  10. Is it this one?
  11. Here’s a couple of interesting engines on ebay: https://www.ebay.co.uk/itm/National-static-diesel-engine-and-generator-vintage-equipment/323084276387?hash=item4b3952d2a3:g:jcQAAOSwXt5aieUz https://www.ebay.co.uk/itm/1945-Lister-JP3-Diesel-Engine-Full-Working-Order-2800-Hours-Recorded/273061269555?hash=item3f93b85033:g:0SkAAOSw-PFafIvs Enjoy! RAP
  12. The objective of the video was to demonstrate how a single handed boater could operate the bridge with minimal physical activity. You will note that there is no running or jumping around the structure or any agile manoeuvres. It was a demonstration for mixed age and physical ability. Upon closing the bridge the operator untied the boat from the bridge and retrieved it by pulling from the towpath rather than take a precarious shortcut from the offside. The structure on that side coupled with the vegetation is not particularly inviting. The video was submitted to a planning inquiry to help stop the 440 houses that are now to be built on the adjacent green fields. The bridge will be replaced with a fully automatic two lane swing bridge twice the size of the current bridge, it being the primary access road to and from the new housing estate. The new bridge will have the usual 'brand new teething troubles' and in time will become as reliable as the others in CRT or council ownership. CRT has moved the controls to the towpath side and have done so to most of the electrically operated swing bridges in their ownership. The council owned swing bridges retain their offside controls.
  13. Not a new marina but a new housing estate is going to be built next to 199. We will see 440 new homes built here on green and lush land and to make access and egress manageable 199 will be replaced with a two lane double width swing bridge.
  14. I decided to purchase new inner and outer valve springs. Good job I did, you can see the comparison between old and new in the attached videos. https://youtu.be/ulsDuHuzQKs https://youtu.be/K6bmyw1-8QM
  15. Some great responses here, thanks. My boat is in the water and I expect keeping the steel below the waterline warm and dry will be impossible in December. I am surprised that Websters have not advised that this will be an issue. I will be postpone the job until warmer weather. Jddevel, what did you use to stick the celotex to the steel? Many thanks.
  16. Hello, Is it a good idea to have spray foam insulation applied to cold steel or should this be left until the weather is warmer? I have a quote from Websters, job provisionally booked in for December, where they state that the steel surface must be dry and to ensure that sufficient dry heat can be provided (no gas heaters) to heat the boat in order to prevent condensation forming on the surface. Keeping the boat well ventilated while heating will help considerably. This suggests that I would need to hire a reasonably decent electric heater/blower. Obviously, I am not an expert and spray foaming is a first for me, but I would be interested to hear from those who have experienced this and provide any useful advice. Many thanks, I appreciate the help.
  17. Hello, Does anyone know the specs to help me determine if the valve springs have weakened or is there a simpler 'engineers' method to measure this? Thanks.
  18. Done. All the best with this project.
  19. Thanks for the responses, most interesting, entertaining and educational. I'll do as the manual states and stagger them, but evenly at 90 degrees and let the engine do the rest. Regards, RAP
  20. Hello, According to the manual the piston rings are required to be staggered but it doesn't state what the offset should be. Given that there are four rings, 360 divided by 4 is 90; suggests that the offset should be 90 degrees between each piston ring gap. For example, bottom ring at 0, second ring at 90, third ring at 180 and fourth ring at 270, thus giving even distribution of the ring gaps. Is this logic correct or is there a more practicable answer? Thanks, RAP
  21. Great Haywood?
  22. Thanks, so no special tools other than a longer sturdy bar, preferably with a slight depression to help pein over the stem while whacking the head from the external side. Cheers, RAP
  23. Anyone know how the brass bands are riveted to the stack, in particular, not having the internal access to whack the rivet? Is there a special long reach tool needed? Thanks, RAP
  24. Thank you Peter, and for reference, the boat is a 58' Tim Tyler, and the engine is an industrial JP3, 'marinised' with a Paragon gearbox mounted at the back of the engine coupled via an R&D drive plate. I currently have the engine in bits while I make good the rather worn crankshaft, which I believe has been with the engine for the last 72 years. Regards, RAP
  25. Some useful leads here to follow up. I appreciate your help. Thanks, RAP
