robange Posted August 20, 2012 Report Share Posted August 20, 2012 Hi all, we are new here. Can anyone advise us which boat to buy? We are considering either a 32ft creighton cruiser or a 32ft dartline narrowboat, the creighton is £5100 the dartline £8k any advice will be very welcome. Link to comment Share on other sites More sharing options...
bottle Posted August 20, 2012 Report Share Posted August 20, 2012 Welcome. Sorry to say this but not really it is entirely up to you which boat you buy. No doubt someone will know the two boats you mention and particular good or bad points. Find the boat you are interested in, have it surveyed and barter, if it is not a colander case. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted August 20, 2012 Report Share Posted August 20, 2012 Welcome. Sorry to say this but not really it is entirely up to you which boat you buy. No doubt someone will know the two boats you mention and particular good or bad points. Find the boat you are interested in, have it surveyed and barter, if it is not a colander case. Sound advice, think of it as you would when buying a car, if one boat ticks your boxes more than the other then you have your boat (subject to survey) I suspect that given the price difference one may well be a better buy than the other but that is not always the case. Do you know any boat owners who could go with you when you view boats? Phil Link to comment Share on other sites More sharing options...
robange Posted August 20, 2012 Author Report Share Posted August 20, 2012 Sound advice, think of it as you would when buying a car, if one boat ticks your boxes more than the other then you have your boat (subject to survey) I suspect that given the price difference one may well be a better buy than the other but that is not always the case. Do you know any boat owners who could go with you when you view boats? Phil I understand that, but knowing nothing about boats which would be more economical to maintain a steel hull or GRP? Link to comment Share on other sites More sharing options...
Graham Davis Posted August 20, 2012 Report Share Posted August 20, 2012 How long is a piece of string? Without knowing the full details of the conditions of either boat it is impossible to answer. I agree with what Bottle says. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted August 20, 2012 Report Share Posted August 20, 2012 I understand that, but knowing nothing about boats which would be more economical to maintain a steel hull or GRP? I lived aboard a GRP boat for about 10 years and now into my 3rd year on a steel N.B, so to this question I can answer that GRP is less expensive to maintain. Phil Link to comment Share on other sites More sharing options...
robange Posted August 20, 2012 Author Report Share Posted August 20, 2012 That's useful to know as it has BSC to 2014 whereas the dartline is 2014. Link to comment Share on other sites More sharing options...
Grace and Favour Posted August 20, 2012 Report Share Posted August 20, 2012 That's useful to know as it has BSC to 2014 whereas the dartline is 2014. So - - both the same then............. And, seeking to be helpful . . . your point is? Link to comment Share on other sites More sharing options...
robange Posted August 20, 2012 Author Report Share Posted August 20, 2012 I meant dartline 2013, I just can't type Link to comment Share on other sites More sharing options...
RLWP Posted August 20, 2012 Report Share Posted August 20, 2012 The BSC is unlikely to be where any major costs come from. Expensive bits on steel boats are hull work, engines and gearboxes I don't know much about GRP ones, engines and gearboxes are still not going to be cheap though Richard Link to comment Share on other sites More sharing options...
bizzard Posted August 20, 2012 Report Share Posted August 20, 2012 The early Dartline narrow boats which is probably what your looking at is almost certainly an ex hire boat, that's good, but it probably has a GRP top and very likely an air-cooled Lister engine, very very reliable but noisy, however they were built with quite nice fine sharp bows enabling then to slice through the water with a minimum of power. A few years ago i delivered one from Leighton Buzzard to here, B.Stortford and it went like a bomb. Link to comment Share on other sites More sharing options...
bottle Posted August 21, 2012 Report Share Posted August 21, 2012 (edited) That's useful to know as it has BSC to 2014 whereas the dartline is 2014. Sorry but that tells you nothing except that when tested in 2010 and 2009 the fittings etc. were passed fit for use. It tells you nothing about the boats fitness now, a bit like an MOT on a car OK when tested but no proof it is OK now. It does not test for, for instance, the thickness of the hull (steel) or whether the GRP has osmosis problems, whether the engine or gearbox are knackered worn out. Do not buy a boat on the length of its BSS. Edited August 21, 2012 by bottle Link to comment Share on other sites More sharing options...
MtB Posted August 21, 2012 Report Share Posted August 21, 2012 Sorry but that tells you nothing except that when tested in 2010 and 2009 the fittings etc. were passed fit for use. It tells you nothing about the boats fitness now, a bit like an MOT on a car OK when tested but no proof it is OK now. It does not test for, for instance, the thickness of the hull (steel) or whether the GRP has osmosis problems, whether the engine or gearbox are knackered worn out. Do not buy a boat on the length of its BSS. Frankly the OP is doing it backwards. One either has to spend weeks and months learning the basics of a subject like boating then buy from an informed position, or take a chance, just buy one, and learn on the job so to speak. I disagree with the advice to get a survey on a boat priced at £5k. Far better to just buy it from a reputable dealer and ask for some sort of basic guarantee, then learn from experience. That way, some boating is getting done instead of interminable naval-gazing, and the most the OP stands to lose if he buys a total turkey is about £5k. Mike Link to comment Share on other sites More sharing options...
RLWP Posted August 21, 2012 Report Share Posted August 21, 2012 Frankly the OP is doing it backwards. One either has to spend weeks and months learning the basics of a subject like boating then buy from an informed position, or take a chance, just buy one, and learn on the job so to speak. I disagree with the advice to get a survey on a boat priced at £5k. Far better to just buy it from a reputable dealer and ask for some sort of basic guarantee, then learn from experience. That way, some boating is getting done instead of interminable naval-gazing, and the most the OP stands to lose if he buys a total turkey is about £5k. Mike Not even £5K, they will be able to unload it to some other enthusiastic boater for something Sounds like a 'take a knowledgeable mate with you' job Richard Link to comment Share on other sites More sharing options...
MtB Posted August 21, 2012 Report Share Posted August 21, 2012 Not even £5K, they will be able to unload it to some other enthusiastic boater for something Sounds like a 'take a knowledgeable mate with you' job Richard Indeed. And take each for a test drive too, with the mate. Having read the OP again the real quandary really seems to be whether to buy a steel NB or a fibreglass cruiser. I'd go for the cruiser as a first purchase as its a lot cheaper and will be easier and less scarey for a newbie to handle. Mike Link to comment Share on other sites More sharing options...
Chris Pink Posted August 21, 2012 Report Share Posted August 21, 2012 Indeed. And take each for a test drive too, with the mate. Good advice. The OP hasn't stated what they want the boat for. Link to comment Share on other sites More sharing options...
deletedaccount Posted August 21, 2012 Report Share Posted August 21, 2012 Links to the boat adverts might help Link to comment Share on other sites More sharing options...
robange Posted August 21, 2012 Author Report Share Posted August 21, 2012 My linkMy linkis the link for the dartline and http://motorboats.apolloduck.co.uk/advert.phtml?id=259763 for the creighton thats if the links work Link to comment Share on other sites More sharing options...
deletedaccount Posted August 21, 2012 Report Share Posted August 21, 2012 Hang on, that cruiser is listed at 17k and the narrowboat at 11k. They both need a bit of work but personally I'd be more likely to go for the steel one because I know more about steel and they're better for living aboard (if that's what you're after), but with a boat that age you really need to know something about the hull imo. I know nothing about old fibreglass but that would be the same thing I imagine - fibreglass tops can be bad news but not always. What are you planning on using it for? 8k for a narrowboat that isn't about to sink, doesn't leak through the roof and has a reliable engine is a decent deal, especially with a new kitchen and bathroom. Those are the things to check. imo of course. Link to comment Share on other sites More sharing options...
robange Posted August 21, 2012 Author Report Share Posted August 21, 2012 (edited) My link[/url ] Sorry wrong boat it is this one. We intend to use it for weekends away and the odd week in the summer. Edited August 21, 2012 by robange Link to comment Share on other sites More sharing options...
OldGoldy Posted August 21, 2012 Report Share Posted August 21, 2012 (edited) My link Sorry wrong boat it is this one. We intend to use it for weekends away and the odd week in the summer. Please note that the Creighton has a PETROL inboard, so I should take pros/cons advice on that point plus the Dartline's cabin top is GRP. The GRP-to-steel join at the gunwhales often creates frustrating problems with rainwater ingress (I have an ex-dartline boat!) - most of mine has now been solved by the use of Marineflex at the joint - check the inner hardwood strip into which the brass screws fix, for rust staining. If it's painted over, be wary! These points I've raised are not to put you off, but possible cons to consider. Whatever you do, don't rush to buy - theres plenty out there! Good Luck! PS the Dartline is 'of that age' where welding to the bottom plate may be required, if not already done. (mine's a 1974 build and just been done) ETA reformed OP's ebay link. Edited August 21, 2012 by dave69700 Link to comment Share on other sites More sharing options...
robange Posted August 22, 2012 Author Report Share Posted August 22, 2012 Thank you everyone for your advice, We'll keep looking and you never know maybe we'll make a decision, probably neither of these but we will keep looking and then we'll be asking more questions about refits and actual boating etiquette etc. Thanks again Link to comment Share on other sites More sharing options...
bramley Posted September 14, 2012 Report Share Posted September 14, 2012 I think you should buy GRP its cheap and econimical Good luck in whatever you find my offer is still there should you wish to try it for a few hours Ross Link to comment Share on other sites More sharing options...
